Cant seem to ftgure out what i did wrong : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-14-2012, 04:00 PM   #1
draccocain
i replaced head gasket on my 98 750 and the bike ran before i opened her up. now i have her all together and it wont fire . sounds like timing but i did everything according to manual. can any give me somre suggestions as to what i might have done wrong. i ve pulled apart five time already to redo timming chain so i am stumped. heres a copy of the instructions on how to. am i missing somthing
File Type: txt Suzuki_GSXR_750_96-99.txt (8 Bytes, 12 views)
draccocain is offline   Reply With Quote
Old 11-14-2012, 04:23 PM   #2
SVS
Brofessional Viking Super Moderator
SVS's Avatar
Motorcycle: '08 KTM SuperDuke R, '03 GSX-R750, '99 SV650S, '84 XL600R
Re: Cant seem to ftgure out what i did wrong
Sure you didn't time the cams a full turn wrong? I've seen that happen before.
SVS is offline   Reply With Quote
Old 11-14-2012, 04:39 PM   #3
GSXR-Freak
GSXR-Freak's Avatar
Motorcycle: 99 GSXR 750
So the motor will crank but never fires up?
Do you get a Fi code on the dash?
GSXR-Freak is offline   Reply With Quote
Old 11-14-2012, 06:06 PM   #4
97grnrs
97grnrs's Avatar
Motorcycle: 98 750 turbo
its prob the timing marks . make sure they are dead on. make sure any grounds are on. also make sure u got the ignition coils it the right spots. they can be mixed up and not fire in right order
97grnrs is offline   Reply With Quote
Old 11-14-2012, 11:18 PM   #5
draccocain
i've tried with timming the marks on both turns still no.
had to replace the speedo with a 97 model and it doesnt give Fi code.
Old 11-14-2012, 11:22 PM   #6
draccocain
ok the timing marks coinside w position of chain in picture of manual,what grounds specifically could i have missed? and with ignition coils how do i know witch one goes to what cylinder, is that what u mean?
Old 11-14-2012, 11:41 PM   #7
draccocain
all great suggestions. thanx . i'm pretty sure i've got marks dead on . i've tired aligning marks then fully rotating crankshft and aligning marks still no. i've got spark. and fuel pump kicks on. so if i installed coils outa order what do i reference to find the position where each coil plug needs to b. and just to make sure i have the timing marks aligned on the right turn off the crankshaft, what do i do to make sure that the position of the crnkshft is correct. pictures would b helpful but i can get thru it weith a good description
Old 11-15-2012, 12:28 AM   #8
as someone mentioned before, its easy to get them 180 off, doesn't the cam rotate twice on the gear before it makes fires a full sequence?
Old 11-15-2012, 12:51 AM   #9
Sounds like timing is out. Did you replace the timing chain? The old chain may have stretch slightly and therefore the marks will not be spot on.
Old 11-15-2012, 01:37 AM   #10
he would have had to remove the timing chain to replace the head gasket, no?
Old 11-15-2012, 06:29 AM   #11
tmp
tmp's Avatar
Motorcycle: 99 SRAD 750
It is possible that the problem is using a 97 dash in a FI bike?
tmp is offline   Reply With Quote
Old 11-15-2012, 06:37 AM   #12
We have already been down this road with a carbed instrument cluster on a FI bike........ Recently, didn't work then either, bike fired up when right instrument cluster installed.
Old 11-15-2012, 06:42 AM   #13
tmp
tmp's Avatar
Gotta love F.I...
Old 11-15-2012, 06:54 AM   #14
97grnrs
97grnrs's Avatar
ignition coils should have small numbers on the harness where they plug in. also should be 15 pins from mark to mark on cam gears for chain. some books say 14 which isnt right. if the coils are in wrong order also the harness wont fit as it should it will be long in some spots where it should be short
Old 11-15-2012, 11:15 AM   #15
draccocain
Originally Posted by tmp View Post
Gotta love F.I...
i ve been running this speedo cluster for over a year, so i dont think thats it. and the bike was running great except for the water in oil thats why i replaced head gasket. now i do wish i'd a done compression check b4 i started but at time i didn t have the tool. it may not of been head i recently replaced mechanical and oil seal in water pump which may have been the culprit the whole time but as far as a timing chain being stretched i d like to run thru my options b4 i purchase more parts.
Old 11-15-2012, 11:19 AM   #16
draccocain
ok i've got the book that says 15 pins so i've been doing that. and how do i tell which coiol goes to which cylinder i've got the harness part right
Old 11-15-2012, 02:58 PM   #17
Maj750
Does not matter which tdc you use, as the cam is the reference point to what is firing stroke , you cannot be 180 out
if you harness is right the coils are all the same
any fault codes ?
you could put a splash of fuel down each throttlebody crank it and see if it fires
if it does look at your fuel supply /pressure
Maj750 is offline   Reply With Quote
Old 12-08-2012, 09:47 PM   #18
draccocain
Ok, update on what i know so far. i've been busy with school so just got a lil time b4 my finals to troubleshoot this issue. after checking cams, crankshaft. coils n wiring order, timing chain all that is good i found out my num 1 cylynder has no compression, any ideas where to go next?
Old 12-08-2012, 10:14 PM   #19
Wogger
Douche Nozzle
Wogger's Avatar
Motorcycle: 09 GSX-R 600, 09 DR-Z434SM, 82 CB750F, 05 CRF50F
Time to rip her apart again.
Wogger is offline   Reply With Quote
Old 12-08-2012, 10:29 PM   #20
Check valve lash, make sure you don't have a valve that isn't closing. Then do leak down, see if you are losing compression past a bent valve or bad seat interface, past rings, etc. Don't tear down aimlessly without reference.
Sent from my DROID3 using Motorcycle.com App
