Short or long stroke : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-11-2012, 12:17 PM   #1
hardtail750
How can you tell the difference between the two
And how much different are they
Thanks Danny
hardtail750 is offline   Reply With Quote
Old 11-11-2012, 02:31 PM   #2
Intguy
Intguy's Avatar
Motorcycle: 1989 GSX-R 7/11, 1992 ZX11, 2000 FLHTC
Re: Short or long stroke
Visibly there is no difference. The engine numbers will tell you what the year, hence stroke it is.
The short stroke were 748 cc's vs the long stroke 749.
Here is a good reference site.
http://www.gsxr711.com/content/navi.html
cheers
Intguy is offline   Reply With Quote
Old 11-11-2012, 06:56 PM   #3
Hootguy
Motorcycle: 89gsxr-rk,(2),,86 GSXR LTD,,86 gsxr-750 rd/blk,,85 GSXR 750,, 96 gsxr 750/rf900,,98 gsxr 750,,99yosh 750 superbike..86 RG500 Walter Wolf,,86 RG500 blue/wht,,
the 88 89 short stroke have a dot on the head,,
Hootguy is offline   Reply With Quote
Old 11-12-2012, 12:53 AM   #4
GarrettSR5
Motorcycle: Yes.
Visual difference is a long stroke has a "bump" on the clutch cover.
GarrettSR5 is offline   Reply With Quote
Old 11-12-2012, 02:05 AM   #5
hardtail750
Thanks all
Looks like i got the short stroke
So is that better?
Old 11-12-2012, 04:13 AM   #6
gotgixers
Superbike Racer
gotgixers's Avatar
Motorcycle: 1986 GSXR 7/12
One will say 748ccm2(short stroke) the other will say 749ccm2(long stroke) right on the jugs ......
gotgixers is offline   Reply With Quote
Old 11-12-2012, 07:04 AM   #7
Hootguy
actually,,the 90 91 has a bump on the clutch cover too,and they are long strokes,,the engine code is the easyest and surest way...if it's a 707 it's ashort stroke,,,anything else and it's a long stroke..
Old 11-12-2012, 07:13 AM   #8
Intguy
Intguy's Avatar
As is common with these bikes, covers ,even heads can and sometimes are changed for various reasons. Unless your 100% sure of it's history you just never know.
The engine number will indicate the cases, the 748cm2 will indicate the jugs and the dot on the head (pictured below) will indicate the short stroke head.
cheers
Old 11-12-2012, 07:43 AM   #9
GarrettSR5
Motorcycle: Yes.
^ very true
Old 11-12-2012, 07:53 AM   #10
Intguy
Intguy's Avatar
Originally Posted by hardtail750 View Post
Thanks all
So is that better?
Depends on who you talk to.
Look at it this way, all oil cooled 750's were long stroke except for the 88-89, and even then the 89 RK was a long stoke for racing.
cheers
Old 11-12-2012, 08:52 AM   #11
tonyc9928
tonyc9928's Avatar
Motorcycle: you know the kind. the ones with wheels. I don't care how many wheels. 1 will do.
I think all the short stroke GSXR motors have a clutch cable that hooks to the clutch side cover instead of the output drive side of the motor.
all Katana are short stroke too. I think they have the DOT head too but I am not sure.
tonyc9928 is offline   Reply With Quote
Old 11-12-2012, 12:16 PM   #12
jpnjim
jpnjim's Avatar
Motorcycle: GSXR1100J in progress, neglected GSXR1100H & ex-racer GSXR750F in pieces
I think the 750 Kats went long stroke in 1998
I believe they also went to silver engine cases that same year.
jpnjim is offline   Reply With Quote
Old 11-12-2012, 04:53 PM   #13
Sharkboy521
Sharkboy521's Avatar
Motorcycle: 88 GSXF600, 09 GSXR600, 86 GSXR750, 97 GSXR750
Correct
Sharkboy521 is offline   Reply With Quote
Old 11-12-2012, 04:58 PM   #14
ricks041k
ricks041k's Avatar
Motorcycle: 2004 1k..stolen now 06 1k..and 90 750
short strokes generally known for softer low/ mid and punchier top end rush as well as a higher red line than 85-87 long strokes
long stroke better low/ mid range pull. 90 and later same high rpm red line and easier to tune. def like the long stroke for a street bike. if its a track bike and going to keep in high rpm really no diff except short strokes are more finicky tuning
ricks041k is offline   Reply With Quote
