05 1000 unable to start : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-10-2012, 12:51 AM   #1
mlissa2007
Wants Robert Pattinson to explore his Twilight Starfish
mlissa2007's Avatar
Motorcycle: 06 kws gsxr 1143 stroker track, 11 gsxr 600 street, 09 drz400sm street/dirt
A friend of mine has a 05 gsxr 1000 and has turned it into a race bike. He has removed all the taillights and headlight. After that the bike started fine. Well today he cut the harness (wires) that lead to the left handlebar pod(?) Where the horn and turn signal switches are. Since then the bike wont turn over. You can hear the fuel pump, however the bike won't start up. Could this be the clutch position sensor? All the problems started after he cut the wires or harness that leads to the left side. Any ideas? When you push the start button theres nothing. No click sound. New battery as well
Thx
J
KWS1143 Stroker: CP 3mm pistons,4mm falicon stroker crank, Carillo H beam Rods, Web cams,Ported head, Valve job, new valves,cam sproket, cam chain, Bearings,gaskets, Falicon clutch, akra evo2 exhaust, Bmc race filt,Bazzaz z-fi Qs, jsd2, Penske shock, ss lines, Pads, brembo m/c, vortex rearsets, ohlins forks spring,penske fork valves,woodcraft covers, crg mirror,gpr damper,asv/pazzo levers;205hp/103ftlbs pump/ 214hp/107ftlbs on race gas
mlissa2007 is offline   Reply With Quote
Old 11-10-2012, 12:54 AM   #2
mlissa2007
mlissa2007's Avatar
Re: 05 1000 unable to start
He was lazy to remove it properly but decided it would be easier to cut it lmao
J
Old 11-10-2012, 04:06 AM   #3
Lol,you/he already know the answer to this: re-connect the wires that were cut&see if that fixes it
Old 11-10-2012, 04:20 AM   #4
mlissa2007
mlissa2007's Avatar
I'm just posting this as he is too embarrassed to make a post about this. Who cares we all f... Up. So oldg should their be a reason why it won't start? I don't believe their are any wires on the left pod (that's what I'm calling it) that will stop the bike from starting; unless I'm wrong. I'm no mechanic by any means but i can do most things on a bike. However I have never had to cut any harnesses on my bikes so I'm lost on this one and highly doubt he is going to rewire 12wires. Lazy wanker lol
Old 11-10-2012, 07:29 AM   #5
K6trackday
K6trackday's Avatar
clutch switch...
K6trackday is offline   Reply With Quote
Old 11-10-2012, 08:45 AM   #6
mlissa2007
mlissa2007's Avatar
K6tracjday you were right. Wired in the black and yellow and black and white wires from the clutch switch and it worked. He's happy now and vows to never cut wires again
Thx
J
Old 11-10-2012, 08:57 AM   #7
K6trackday
K6trackday's Avatar
Another thing to take into consideration, when the clutch switch is active some of the suzuki models actually run the neutral ignition map timing. The ECU ignores the gear position sensor. I have the yosh kit wire harness and ecu on my bike so didnt have to deal with this but its something to look into when getting rid of the clutch switch on bikes.
To clarify, you will lose hp.
Old 11-10-2012, 11:00 AM   #8
cirsory
cirsory's Avatar
Motorcycle: 06 600 track
I cut the wires to my clutch switch too, is there more information on what bikes this effects or how to work around it?
cirsory is offline   Reply With Quote
Old 11-10-2012, 12:00 PM   #9
spike52
"Will donate money to GDC for the cheap bastards who won't.. "
spike52's Avatar
Motorcycle: 2011 1K...'04 1K MM eddy(for sale)..'04 Kawi 636 trackwhore
clutch switch...
Ding-ding-ding..
spike52 is offline   Reply With Quote
Old 11-10-2012, 12:04 PM   #10
njyork42
Tennessee Hot Pocket Champ
njyork42's Avatar
Motorcycle: 05 GSXR 750
He cut off the clutch switch..
njyork42 is online now   Reply With Quote
Old 11-10-2012, 02:16 PM   #11
mlissa2007
mlissa2007's Avatar
His clutch switch is wired and taped already and the bike runs normal. So its back on but I removed the blinker/horn pod that holds it if that makes sense. So we did not eliminate the clutch switch just rewired it so he still has to pull in the clutch. Lazy guy.
Thx for all the help
Old 11-10-2012, 03:01 PM   #12
MotoMummy
Parts Bitch
MotoMummy's Avatar
Motorcycle: Mummy Bike
You can put a toggle switch on the clutch wires as well.
MotoMummy is offline   Reply With Quote
Old 11-10-2012, 03:41 PM   #13
mlissa2007
mlissa2007's Avatar
Thanks Corey will let him know. Ya'll are awesome
Cheers
J
Old 11-10-2012, 03:56 PM   #14
K6trackday
K6trackday's Avatar
Most Suzuki EFI sytems do this, and by lose hp I mean up to 10% in some cases. There was a lot of info on this going around some years back.
Here is a link: http://wotid.com/tls/content/view/18/56/
As in the link you can either jumper out the switch and cut the wire to the ecu (lose the startup map) or wire in a relay. Note the link talks about the TL1000 so wire colors will be different bike to bike.
Old 11-10-2012, 11:26 PM   #15
mlissa2007
mlissa2007's Avatar
Like they said wire in a toggle switch. Or just keep the switch and cut the other wires. That's what we did. Keep black/yellow and black/white wires. Not sure if its the same color on your bike. Then we zip tied the wires and ran electrical tape around it and bamm back in business. Well we didn't do what he wanted which is removing the switch. At least the pod harness is gone so it looks more like a race bike. I told him to keep the clutch sensor and also told him about possible power loss if you remove the clutch sensor.
That was convincing enough lol
Well off to bed for me as I have to be up in a few hrs for work
Thanks again fellas
J
Old 11-11-2012, 01:03 AM   #16
cirsory
cirsory's Avatar
thanks for the info. I'll wire in a relay.
