making my own petcock - Page 3 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > Water Cooled Gixxers
Old 11-08-2012, 05:57 AM   #41
cody5127
cody5127's Avatar
Motorcycle: 1995 gixxer 750
Re: making my own petcock
Big brass balls.
cody5127 is offline   Reply With Quote
Old 11-08-2012, 05:59 AM   #42
Knight2211
Unstable SuperMod
Knight2211's Avatar
Originally Posted by cody5127 View Post
Big brass balls.
No always too big, esp if you're a BallsintheAss kinda guy.
Knight2211 is offline   Reply With Quote
Old 11-08-2012, 06:21 AM   #43
Cody,Im gonna check my shelves&see if I have an old petcock laying around;if I do just pay for the shipping and its yours. Dont really wanna see a "My bike caught on fire&burned to the ground after I made my own petcock" thread lol
Old 11-08-2012, 06:46 AM   #44
cody5127
cody5127's Avatar
If you find one just pm the cost and I can send cash
Old 11-08-2012, 08:36 AM   #45
Medcoxo
Medcoxo's Avatar
Motorcycle: 2007 750 GSXR Blue/Black
I have an 07, and was considering adding one as a fuel shut off, that way if someone tries to ride off on the bike, it will shut off on them!!! They would never figure it out!!!
Medcoxo is offline   Reply With Quote
Old 11-08-2012, 09:12 AM   #46
Not a very wise decision to interrupt fuel pressure on a fuel injected bike with an added-on petcock.In general thats a recipe for disaster. There are more effective ways to safeguard your bike
Old 11-08-2012, 09:26 AM   #47
cody5127
cody5127's Avatar
Kill switch. I've seen a couple threads about it
Old 11-08-2012, 11:14 AM   #48
THE SRADIATOR
Sent Flowers to Algernon
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
Come on Old...where's your spirit?
THE SRADIATOR is offline   Reply With Quote
Old 11-08-2012, 11:23 AM   #49
THE SRADIATOR
Quote: "Honestly srad, I don't really care if you like it or not:
Well...That works for me!
I have found 6-7 possible places for your frankenpetcock to leak from.
I hope you never try to reinvent the wheel, after seeing this venture it will undoubtedly be square!
So many cheaper/easier ways to have gone about this that it boggles the mind that this is the best you could come up with?
I have found that sometimes a little tough love here preserves life/limb/property and that's what I am hoping for here with you as well.
Carry on then...
Old 11-08-2012, 11:27 AM   #50
THE SRADIATOR
More of your handiwork?:
Old 11-08-2012, 11:33 AM   #51
THE SRADIATOR
The easiest and the cheapest thing would have probably been to modify the stock petcock for free flow then install an in line interrupt like the ones from ebay.
With the time & $$$ you have invested in brass fittings you could have done better for yourself.
Pingle and "pingle style" petcocks have the propensity to leak from their mounting plate and I have always wondered about their appeal?
Old 11-08-2012, 11:33 AM   #52
cody5127
cody5127's Avatar
Srad I have only spent about 30 on this project, if it ask works I'm Hobbs solder it all together so it can't leak. And why you gotta be the negative Nancy on this thread? If it works it works if not then at least I will learn for next time.
Old 11-08-2012, 11:36 AM   #53
THE SRADIATOR
I prefer to think of myself as "Realistic Roberta" rather than "Negative Nancy"
If learning and experience is what you are seeking then I am sure you will find some with your "frankenpetcock" project.
If a smooth running, leak free fuel valve that doesn't look like a 3rd grade science project is what you seek, you may need (you definitely need) to go back to square 1.
Old 11-08-2012, 11:38 AM   #54
THE SRADIATOR
PS...Threaded joints don't get soldered, that's the point of it having threads.
Use some teflon tape on the threaded couplers to ensure they are leak free.
Old 11-08-2012, 12:21 PM   #55
cody5127
cody5127's Avatar
I'll do it my way, srad, don't reply again unless you got some helping advice instead of trying to make me look like a fucking retard. Its all gonna be out of sight under the tank so who honestly gives a shit what it looks like as long as it does its job. And how would you recommend modifying the oe petcock for free flow and then put in two shutoff valves and it still not look like a "3rd grade science project"?
Sent from my EVO using Motorcycle.com Free App
Old 11-08-2012, 12:31 PM   #56
THE SRADIATOR
In my eyes...you already "look like a self inflicted retard" but if that's part of your normal learning curve, so be it.
The petcocks biggest problem seems to be they get frozen from the knob staying in 1 place (on position) for too long.
When you go to turn the vale to reserve/prime, it shears off the plastic nibs inside that engage the knob to spin it.
I would have moved that to the prime position for free flowing fuel then installed a "T" fitting with an in line fuel shut off as seen in those eBay auctions.
Obviously you have the mechanical aptitude as you have disassembled and presumably reassembled your carbs correctly.
While you motivation may be in the right place, your choice of hardware is not.
All those joining points lend themselves to leaks not to mention the physical space that monstrosity takes up.
Necessity, they say, is a mother and this is case in point I suppose.
Hope that helps and if not...Just call me "Nancy"
Old 11-08-2012, 12:37 PM   #57
cody5127
cody5127's Avatar
Ok Nancy. I'm trying to figure out a cheaper solution than the high priced replacements. I'm not trying to make a piece of art as its never seen but trying to make something that does its job better than you
Old 11-08-2012, 12:42 PM   #58
Please do not try&solder the brass NPT fittings. Im a plumber by trade&have been for the last 25yrs.
Old 11-08-2012, 12:48 PM   #59
cody5127
cody5127's Avatar
I guessed, and according to Nancy I'm retarded so my argument in invalid, but I guessed that solder would hold up a lot better than tape, but I'm gonna look onto modifying the OEM one and see if I can figure anything
Old 11-08-2012, 12:57 PM   #60
Actually I would use a small amount of teflon pipe dope vs the tape. Just a little bit on the first 3 threads on each joint is all you need.
