Steering stems. : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 11-03-2012, 12:48 PM   #1
jarvis
Steering stems.
I've read the post re compatible parts and understand the best way of fitting a late model front end is to press the stem out of existing yoke and press back in to late model's triples.
This I have no problem with, thing is I'm starting with nothing so all I need is a suitable stem to fit the slingshot head.
So basically the cheaper the bottom yoke the better, well why not, going to be throwing most of it in the bin.
So heres my list of probable donors.
GSX600/750 (tea pots here in uk)
All GSX1100 inc R up to and in wn
GS550/650/750/850/1000/1100 (inc Powerscreen)
GSXR750/1100 F-M
There maybe a few others but I reckon that gives me a wide range to look for bargains
Please feel free to tell me I'm wrong on any of above choices
Of course if any member has any suitable yokes I'm prepared to pay for part and delivery.
Thanks for your time
jarvis is offline   Reply With Quote
Old 11-05-2012, 07:58 AM   #2
Tillerpilot
Motorcycle: Tillerpilot
Re: Steering stems.
You did not say what MODERN triple you planned on using, but why not use a 91 GSXR 750 lower triple. Then you can bolt on whatever USD GSXR fork you would like.
Tillerpilot is offline   Reply With Quote
Old 11-06-2012, 02:55 AM   #3
jarvis
Re: Steering stems.
Pref K series simply because they will be the youngest therefore the least likely to need to much cleaning up etc before fitting them. (the way I see it is that any money saved on purchase can soon be swallowed up on new seals, re chroming etc)
I read some where that k's will slot straight in to the 91 yokes with only spacers for the wheels required to finish the job. Would this be the same for all slingshot usd yokes or just specific to the 91's
Old 11-06-2012, 01:14 PM   #4
ghostrider.1127
ghostrider.1127's Avatar
Motorcycle: few gsx-r
Re: Steering stems.
750 90-91 -92 (us model) are 50-54 like most of usd till 04-05
and steering stop are the same for slighy slabby
750 W 92(europe) 93-94-95 are 50-54 BUT steering stop are diff
1100 90>92 are 52-56 same steering stoper
1100 93-94 52-56 diff st.st.
1100 95>98 50-54 diff st. st.
not all usd are 50-54 also tl 1000 and busa are 50-55 for few model years market
(also for k6-k7> forks are 50-53)
for pass between 214 mm dist fork legs (sacs -w-srad busa-tl)
to 207 mm (k series )
need two spacer for brake disk
here triple stem
here my number 6
91 750 lower triple
abm superbike upper
k4 wilbers fork
busa wheel
srad axle -spacer
320 mm abm disc
2 disc spacer
yama r1 caliper
ghostrider.1127 is offline   Reply With Quote
Old 11-06-2012, 04:47 PM   #5
awasson
awasson's Avatar
Motorcycle: 1985 GSXR 750, 1986 GSXR Limited, 1989 GSXR750 RR (being assembled), 1973 GT-750 (no longer have, looking for another)
Re: Steering stems.
@jarvis: What year GSXR are you working on and what sort of riding are you doing? As mentioned, you can swap across a number of new front ends right into your bike without too much trouble.
The big advantage of getting a front end like the one Ghostie has on his bike is that you can then have radial brakes. You'll have be reasonably competent with machining or sourcing the right parts and making sure that you don't cause any trouble to the steering/suspension with your mods. Definitely spend some time on your rear suspension if you upgrade the front.
Andrew Wasson
they start saying things like" it really hits when you hit 8000rpm"
just another way of saying"the jetting is fuct untill you get on the mains"
~ chronicboy
awasson is online now   Reply With Quote
Old 11-07-2012, 09:44 AM   #6
jarvis
Re: Steering stems.
here triple stem
here my number 6
91 750 lower triple
abm superbike upper
k4 wilbers fork
busa wheel
srad axle -spacer
320 mm abm disc
2 disc spacer
yama r1 caliper
Thanks for info, would have taken months to find all that on lime.
Nice work by the way.
Have gsxr 750 m frame, 750 srad arm with 5.5 rim, busy looking for suitable shock on flea bay .
Riding style......fast road and this causes me a bit of a delema re choice of engine. Do I go for light weight 6. That I can thrash.everywhere or the brute force of the 1127.
Old 11-07-2012, 01:10 PM   #7
ghostrider.1127
Re: Steering stems.
rear shock from k5>k8 gsxr 1000
i have one but in EUROPE
Old 11-07-2012, 02:09 PM   #8
jarvis
Re: Steering stems.
The k series shock has a fixed resivior , will this clear the bracing on the srad arm. Also do You know the length between hole centres.
Sourcing one not problem. Several on ebay.
Also.have hagon adjustable knocking around somewhere so will see if that lines up
Old 11-07-2012, 06:06 PM   #9
ghostrider.1127
Re: Steering stems.
already fittedk shock with srad/busa swingarm
no problem
GSXR 750 00-03 325 mm
GSXR 600 01-03 325mm
GSXR 600 -750 04-05 332.5 mm
GSXR 1000 2001-2002 329.5mm
GSXR 1000 2003-2004 332.5mm
GSXR 1000 2005-2006 325.5mm
GSXR 1000 2007-2008 315mm
oem is 315-318 mm
possibile aslo use few from honda fartblade 600-1000 rr and kawa 600-900 or yamaha 600-1000
http://gsxr-sacs-air-oil.forumieren.com/
Old 11-07-2012, 09:47 PM   #10
jpnjim
jpnjim's Avatar
Motorcycle: GSXR1100J in progress, neglected GSXR1100H & ex-racer GSXR750F in pieces
Re: Steering stems.
Don't you also need an offset engine sprocket for chain alignment with the 5.5" SRAD rear wheel?
jpnjim is offline   Reply With Quote
Old 11-08-2012, 02:06 AM   #11
jarvis
Re: Steering stems.
Not sure re rear sprocket off set but chose 5.5 to prevent tire/chain rubbing ,well that's the theory.
If the kawasaki shocks fit then I recon the hagon's going to get the job providing the length's not to far out.
While were on subject of rear. Anyone fitted a small twin piston caliper ( preferably from another bike.not paying silly money for isr etc)
Old 11-08-2012, 05:37 AM   #12
ghostrider.1127
Re: Steering stems.
on short s front sprocket shaft (750 85>89 1100 86>89) yes 5 mm
and shave a little rear sprocket drum
Old 11-08-2012, 08:27 AM   #13
jpnjim
jpnjim's Avatar
Re: Steering stems.
Thanks ghost
So for a 5.5" SRAD wheel
1989& earlier engines need the 5mm offset front sprocket & a shave of the rear sprocket carrier
1990& later just need the shave
Old 11-08-2012, 10:53 AM   #14
ghostrider.1127
Re: Steering stems.
Thanks ghost
yes
Old 02-06-2013, 06:27 PM   #15
4153stavros
4153stavros's Avatar
Motorcycle: GSX-R 1100 1992, Hyabusa 2001 KTM 520 2002
Re: Steering stems.
Get some more info Thanks guys.....
4153stavros is offline   Reply With Quote
