» Site Navigation
» Motorcycle Forums
10-30-2012, 10:10 PM
#61
Motorcycle: 93 GSXR 750
Re: update
Originally Posted by
cody5127
blew cleaner through the, idle (?) Jet, the one that comes out on the float sides
A little confused by this statement...your idle (or pilot) jet is the one shown in the picture.
Other than that, sounds like you're good to go
10-31-2012, 05:27 AM
#62
Motorcycle: 1995 gixxer 750
Re: update
My bad, pilot jet. Like I've said before, I don't know shit about carbs
10-31-2012, 03:21 PM
#63
Re: update
I an going to be seriously disappointed if this doesn't fix anything... I'm going out tomorrow after work to install. I'll give an update then.
11-02-2012, 06:02 AM
#64
Ok, update... Ran great for about half hour then started sputtering and eventually died, but last glance the fuel lines were dry. And yes there was gas about two gallons. Took off petcock looks to be ok. When I had the tank off no fuel came out even on prime
Sent from my EVO using Motorcycle.com Free App
11-02-2012, 10:01 AM
#65
Re: update
Fuel should flow freely from the PRIME position.
In the ON or RES position, no fuel should flow unless vacuum is applied to the vacuum outlet...
11-02-2012, 10:04 AM
#66
Re: update
So what usually causes this issue? Replace petcock?
11-02-2012, 06:25 PM
#67
Petcock all tore apart...
11-02-2012, 08:24 PM
#68
Motorcycle: 1995 Gsx-r 750
Re: update
I would buy a new pingle valve or a rebuild kit. That diaphragm looks terrible, which could be an indication that the rest of the seals are in bad shape. I just purchase a new rebuild kit for $30 off of a local shop.
11-02-2012, 08:30 PM
#69
Isn't the plastic in the middle of the valve shot? our am I thinking of something else that breaks with our valves?
11-02-2012, 08:31 PM
#70
And all of the o rings look to be in great shape, no cracks or signs of wear
11-03-2012, 01:06 AM
#71
Re: update
The plastic piece is known to seize up...
The metal prongs from the handle piece then snap off if you try to turn it (happened on mine)...terrible design. If your petcock is in fact shot, get a Pingle as mentioned above. The part # should be in a sticky in this forum...
Why don't you try rigging up an auxillary tank to see how she runs?
11-03-2012, 09:46 AM
#72
Talking about the tabs on this? Our where they should be?
11-03-2012, 11:16 AM
#73
Re: update
Can't really see them from the size of the pic. But yes at the base of that pin there should be two metal tabs. They almost look to be broken, in that case a replacement petcock is needed.
11-03-2012, 12:04 PM
#74
Re: update
what would a pingle run me, with the base and valve, i cant seem to find anything on my phone.
11-03-2012, 12:05 PM
#75
Re: update
and no stealerships
11-03-2012, 03:02 PM
#76
Motorcycle: 1995 GSXR750W
Cody i just ordered a pingel and the adaptor for 108 Canadian shipping and taxes included from a seller on ebay.
Sent from my SGH-I727R using Motorcycle.com Free App
11-03-2012, 03:54 PM
#77
Re: update
I don't have an Ebay account, let alone a bank account. Haven't had one for about for years or so. Don't need one when all my money is gone to bills as soon as I cash my checks.
11-03-2012, 03:59 PM
#78
Motorcycle: 07 gsxr 600
Paypal loadable cards, and ebay.
11-03-2012, 04:01 PM
#79
Re: update
That's great, but still no money, just gotta save up what I can.
Linear Mode
