Gsxr k6 cams : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 10-28-2012, 02:50 PM   #1
mad k9
Talking Gsxr k6 cams
Hi all,after some advice! Just gone from yam to Suzuki engine for my race outfit,what would the best cam combo I could try for low to mid range torque,I don't expect any trade secrets on timing,just the cams ie intake cam on exhaust side or gsxr 750 cams,thanks for your time.
mad k9 is offline   Reply With Quote
Old 10-28-2012, 09:18 PM   #2
mpp12
Motorcycle: K6 and a xz12r
Re: Gsxr k6 cams
What bike do you have?
mpp12 is offline   Reply With Quote
Old 10-29-2012, 02:46 AM   #3
mad k9
Re: Gsxr k6 cams
Hi it will be fitted into a custom grasstrack sidecar frame,the same as the Australian 1000cc sidecar except with rear suspension,so want to use the k6 torque for grass rather than all out bhp.
Old 10-31-2012, 09:33 AM   #4
mpp12
Re: Gsxr k6 cams
use then K3-4 cams, you will have the low end mid range you need
Old 11-02-2012, 01:12 AM   #5
JP1143
JP1143's Avatar
Motorcycle: K4 1143
Re: Gsxr k6 cams
I concur.
JP1143 is offline   Reply With Quote
Old 11-03-2012, 04:05 AM   #6
mad k9
Re: Gsxr k6 cams
Hi thanks very much for your reply,much appreciated,will try and post some pics up of the outfit when finished,my gixxer 600 is only standard so won't show her off yet
Old 11-03-2012, 04:10 AM   #7
mad k9
Re: Gsxr k6 cams
Ahhh damm forgot to ask,wil the k3 k4 cams work ok with standard cam sprockets or will they need to be timed in using adjustable ones,thanks again for your time.James.
