front suspension : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Racing & Stunts > Stunts & Tricks
Old 05-26-2012, 05:50 PM   #1
BAAGSXR6
front suspension
for stoppies, should you run the frnt suspension stiffer than stock from the factory?
BAAGSXR6 is offline   Reply With Quote
Old 05-27-2012, 02:59 AM   #2
Graveyard
Rectally Assaulted on a Regular Basis
Graveyard's Avatar
Motorcycle: 06 Gixxer 1000, 06 gixxer 600
Re: front suspension
This guy runs the suspension on his 04 gixxer on the stock settings and it seems to be working for him!
Graveyard is offline   Reply With Quote
Old 06-06-2012, 08:30 PM   #3
sawiddy
Motorcycle: K7 Gsxr 600 -1 +2
Can you make the front suspension bouncy? or rigid? And for you OP i'd stick with stock settings. Get that down then start tweaking to find which way is better. FOR YOU.
sawiddy is offline   Reply With Quote
Old 06-20-2012, 12:43 AM   #4
Incantation
Incantation's Avatar
Motorcycle: r6, f4i, k7 600, k6 750
^ nonsense from a noob. shouldn't be giving advice if you don't know.
i'm no stoppie master, but from the guys that i know that roll crazy ones:
compression: up all the way and back a bit
rebound: up all the way and back a bit
preload: down all the way and back a bit
24psi in the front tire
you want your shit stiff so your brake lever input shifts your bike angle, and doesn't bounce the suspension, but not so stiff that your tire locks up before all the weight can transfer to the front of the bike
Incantation is offline   Reply With Quote
