Of course when I was taking my front tire off I stripped my pinch Bolt. After days of trying easy out vice grips and everything else that I can think of I want up drilling it out and obviously wasn't straight. I wound up doing this.
Here's my question. So with the three other pinch bolts is this safe to ride with. Don't have the funds right now to buy a new Fork and that black casting at the bottom of the floor does not look like it can be changed without changing the whole Fork. And being that all the way from the bike is on the top of the axle shaft not the bottom where that hole is now do you think it would be safe to ride.
If not I was thinking about drilling a quarter inch hole through the casting and through the shop itself so that it does not move or maybe having a welder weld a washer at the end of the axle shaft so that it cannot slide through the other hole.
What do you guys think?
