last resort before i take it into the shop - Page 2 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #21 of 31 (permalink) Old 10-31-2012, 06:12 PM
berencam's Avatar
Motorcycle: 07 gsxr 600
Originally Posted by mannyb600 View Post
oh sorry its at 14.3v and yes its a new battery also took the battery in to get tested and battery life is at 100%
And the issue is the bike stalls after decelerating? Are we sure this is a charging issue?
berencam is offline
post #22 of 31 (permalink) Old 11-01-2012, 04:46 PM
Motorcycle: 07 Suzuki Gsx-r600
Re: last resort before i take it into the shop
Check your non-led light if they are blown then more than likely you probably got a bad R/R. Is your gauge resetting(rpm needle jumping up and down like when you first turn the ignition on)?
Also, if you are reading 10v+ on the battery and its not starting then its the surface discharge on the battery.
yuephengchang is offline
post #23 of 31 (permalink) Old 11-02-2012, 08:45 PM
Motorcycle: 05 gsxr 600/06 gsxr 600
batt. is reading 14.2v at 5k rpm
bike does die upon deceleration
upon trying to restart batt. voltage reads 12.5v, starter button is pressed and voltage drops to 9v
if bike sits voltage will slowly climb back up to 12v.(takes about an hr)
6gix99 is offline
post #24 of 31 (permalink) Old 11-03-2012, 12:23 PM
berencam's Avatar
Replace the battery.
berencam is offline
post #25 of 31 (permalink) Old 11-03-2012, 01:29 PM
Motorcycle: 2008 GSX-R 600, 1988 RGV-250, 2004 SV650, 2005 SV650, 2004 Honda Cbr600, 2007 Yamaha R6
come to california.. i'll fix it for you.
NEMES1Sx1st is offline
post #26 of 31 (permalink) Old 11-03-2012, 09:52 PM
new gel batt.
6gix99 is offline
post #27 of 31 (permalink) Old 11-03-2012, 10:26 PM
berencam's Avatar
Originally Posted by 6gix99 View Post
new gel batt.
Replace the battery again.
berencam is offline
post #28 of 31 (permalink) Old 11-04-2012, 03:35 AM
replacing the battery will only allow the bike to operate due to the battery charge level. it will still start draining and is not solving any problems.
gotta figure out what is draining the battery down to 9 volts
post #29 of 31 (permalink) Old 11-04-2012, 07:14 AM
berencam's Avatar
He has already said the battery charges (14.2 @5k rpm), and when he trys to start the bike the battery dips to 9 volts. Its only after the battery sits it regains voltage. His battery is failing a load test, and his issues are likely stemming from a faulty battery. Replace the battery.
berencam is offline
post #30 of 31 (permalink) Old 11-04-2012, 07:36 AM
if your new batt is one of these :
http://www.ebay.com/itm/Bikemaster-T...013da9&vxp=mtr
throw that shit in the garbage- mine came showing 13.5v but goes to 0 with any load
-right outa the box
very happy with this tiny, light, and powerful little bastard:
http://www.ebay.com/itm/EVO2-8-Cell-...a8bc3b&vxp=mtr
chronicboy is offline
post #31 of 31 (permalink) Old 12-02-2012, 05:58 PM
well i found out that my problem was not the charging system at all. it was the secondary exhaust butterflies being open constantly and somehow a 4in hole in my air filter. pretty much no back pressure upon deceleration and too much air and the bike dumping fuel in to compensate for it. so it would die and not restart because it was flooded out and once it dried out it would restart.
hope that kinda makes since. so new filter and reconnected exhaust servo and all is fine in gixxer world.
6gix99 is offline
