whats the correct mosfet rectifier and wire harness to order - Page 2 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #21 of 30 (permalink) Old 01-23-2012, 12:43 PM
Re: whats the correct mosfet rectifier and wire harness to order
Originally Posted by essaysee View Post
The rectifier displaces excess electricity in the form of heat. Suzuki placed the RR right in front of the engine....lots of heat....rectifier is also sensitive to melting and really high heats. By relocating it you can keep it cooler and increase longevity.
Thanks for the response...
Another member relocated his and this is what it looks like:
It looks too bulky and would probably stick out way beyond my liking... any other way to mount this bad boy without it looking like a mole?
2movethesoul is offline
post #22 of 30 (permalink) Old 01-23-2012, 01:39 PM
streetdawg's Avatar
Motorcycle: 07gsxr600
can u remount before they go bad or is that just one of those things u deal with.
streetdawg is offline
post #23 of 30 (permalink) Old 01-23-2012, 06:39 PM Thread Starter
say my name bish
DemonRR's Avatar
Motorcycle: 2007 GSXR 600 track/some street
sure, why not.
DemonRR is offline
post #24 of 30 (permalink) Old 11-13-2012, 10:21 AM
ZorroX's Avatar
Bumping this thread. Although I relocated my stock unit it just crapped out at about 9500k. I'm about to order the reccommend parts on page 1. I will let you guys know how it goes and if I run into trouble.
ZorroX is offline
post #25 of 30 (permalink) Old 11-13-2012, 06:24 PM
wisegunner's Avatar
Motorcycle: CBR1000rr '06(sold), GSXR600 K7
Please do. What bike is it for? k6 or k7, 600 or 750?
wisegunner is offline
post #26 of 30 (permalink) Old 11-14-2012, 08:24 AM
ZorroX's Avatar
k7 600
ZorroX is offline
post #27 of 30 (permalink) Old 02-10-2013, 09:36 PM
Motorcycle: k7 GSX-R600
i have a k7 600 and believe that my rectifier is crapping out. Put a multimeter on the battery and shows 14.5 volts when running @5k. Checked the stator and its showing 65v @ 5k. Using the multimeter on the rectifier checking resistence all the plugs check out fine except for one leg on the 3plug if i remember correctly. I'm guessing the rectifier is bad, but why does it only act up sometimes?? I first noticed electrical was screwing up when i had HID's installed they would turn on and off intermittently. I figured loose ground but that wasnt the case. Put the halogen in and it worked, so i guess the ballast was protecting and shutting off when not seeing required voltage. Now when i ride at night the halogen seems dim at stops and then brightens up while riding but then dims while riding also. When a rectifier goes bad, can it still function? Or do they just not work at all anymore?
gsxr5o4 is offline
post #28 of 30 (permalink) Old 07-06-2015, 03:16 PM
Just completed my new set up. It's a little bulky but s lot better than the OEM one
ImageUploadedByMO Free1436210181.664451.jpgImageUploadedByMO Free1436210192.066952.jpgImageUploadedByMO Free1436210201.298938.jpg
Sent from Motorcycle.com Free App
thomas42 is offline
post #29 of 30 (permalink) Old 05-09-2016, 12:58 PM
Just call me ThunderCunt,the thought of $15 gets me butthurt
Attachment 391522Attachment 391530Attachment 391538
Did you go with the parts mentioned on page 1 of this thread?
ThunderOne is offline
post #30 of 30 (permalink) Old 05-12-2016, 07:28 AM
Motorcycle: K1 1000, K7 750
You can see printed on the top of the rec/reg "FH020AA". This is the updated model that supersedes the FH012AA on the first page.
kwaka10r is offline
