Suzuki GSX-R600 K6 bixenon projector retrofit - Page 2 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #21 of 36 (permalink) Old 11-06-2011, 11:43 AM Thread Starter
Re: Suzuki GSX-R600 K6 bixenon projector retrofit
yes, outside diameter. it is a very tight fit
kabalza is offline
post #22 of 36 (permalink) Old 03-02-2012, 01:28 PM
FloridaGSXR's Avatar
Motorcycle: 2006 Gsxr-600 Blue/White
Is there any company that builds something like this so I don't have too?
FloridaGSXR is offline
post #23 of 36 (permalink) Old 03-02-2012, 02:47 PM
06gsxr600368's Avatar
Motorcycle: 2002 gsxr 1000 red/blk/slvr
here is mine I have been working on this week, Dual mini h1 4.1, I`m going to finish installing it this weekend
06gsxr600368 is offline
post #24 of 36 (permalink) Old 03-02-2012, 02:55 PM Thread Starter
interesting that you made a bracket for the low beam. guess you will have a lot more clearance inside the headlight, but how does this affect the rear.
more pics of the housing please
kabalza is offline
post #25 of 36 (permalink) Old 03-02-2012, 03:07 PM
yeah I have the mini gatling shroud on the upper Mini, and it wasn`t going to fit, the head light lens wasn`t going back on , so I had to move it back more, there is just enough clearance for my bracket inside the housing, the first below is just my crappy headlight housing it has to broken tabs, I used it to mock everything up, I still need to pull off my good headlight off my bike and use that one.
previous bikes, 2000 TL1000R, 2002 katana 600, 2002 GSXR 1000, 04 GSXR 600/ with 1000 motor
,2003 DL1000 v-strom,2005 DL1000 V-Strom, 06 gsxr 600, current 2002 gsxr 1000 red/blk/slvr
post #26 of 36 (permalink) Old 03-02-2012, 03:45 PM Thread Starter
wow dude!!! amazing job!!
I wish I saw yours before I did mine
could you measure the height/depth of the brackets?
gonna be a tight squeeze with 2 ballasts?
kabalza is offline
post #27 of 36 (permalink) Old 03-02-2012, 05:30 PM
thanks yeah I will get you the dims. in about 30 mins, yeah I bought a set of AC ballasts from a guy on ebay from here in michigan, they, are even smaller than DDM tuning ballast, I have a harness relay from the same guy that I will wire to the battery and has a heavy duty relay that powers both small ballast I will post up the size difference between the 2 and I should no problem running the 2 ballast
post #28 of 36 (permalink) Old 03-02-2012, 05:42 PM
Supersport
wuzup76020's Avatar
Motorcycle: 2008 GSXR 600
I have a light housing from my wreck that someone could easily use the parts for and do this mod ..its from my 08-600 if someone wants to make me an offer. I just want it gone
wuzup76020 is offline
post #29 of 36 (permalink) Old 03-02-2012, 06:07 PM
the upper bracket is .500" step back with .250" of washer between the bracket and the headlight bracket. the lower bracket is 1.875" step back. below is the ballast comparison, these I think are small enough I think I found a perfect spot for them on both sides of the bike . I will find out this weekend
post #30 of 36 (permalink) Old 03-03-2012, 05:04 PM
here is the headlight put back together with the Dual Bi-xenon mini H1 projectors
post #31 of 36 (permalink) Old 03-03-2012, 06:12 PM
JixCer's Avatar
Motorcycle: 2005 Gsxr 600
Looks good man i went with the same setup on my k5
Sent from my Motorcycle iPhone app
JixCer is offline
post #32 of 36 (permalink) Old 12-07-2012, 09:01 AM
Motorcycle: Suzuki gsxr k6 750 and gsf 600
Hi folks. Currently I am trying to fit a bi xeon to my k6 750. I have the mori moto bi xeon projector from the retro for source. I am a little stuck trying to mount the projector to the existing reflectors. I have started dremeling the refloctor so the projector can sink in a little. Does any body have a good bit of knowledge on how to fit them that could give me some help. Do you need to cut the bottom of the reflector so the Solonoid on the new projector fits in??. Very stuck. Hope some 1 can help, thanks folks
Rusti is offline
post #33 of 36 (permalink) Old 12-07-2012, 09:03 AM Thread Starter
^^^^ did you read the thread?
kabalza is offline
post #34 of 36 (permalink) Old 12-07-2012, 09:06 AM
Yea I read the thread. Thot I had it all figured out til I started.
Rusti is offline
post #35 of 36 (permalink) Old 12-08-2012, 10:10 PM
Motorcycle: 2008 Gsxr 1000 2007 Gsxr 600 2007 R6 2008 Husqvarna 610Sm Supermoto
so nice
K81K is offline
post #36 of 36 (permalink) Old 12-09-2012, 12:14 PM
Where did you's source a shroud?. Got a plain black cup bit looks plain and rubbish. Any ideas. Thanks
Rusti is offline
