How long until your voltage regulator rectifier takes a shit? 06-07 gsxr 600 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 78 (permalink) Old 09-03-2010, 01:40 AM Thread Starter
How many miles do you have on your bike with the stock voltage regulator rectifier? I had about 5k when mine took a shit. I am suprised the damn thing didn't catch on fire. All the wires were melted and the back of the regulator was roasted. I had to spend $130.00 on a new one + a new battery. Seriously.. fuck suzuki for not recalling that shit! I hear this is a very common problem.
Does anyone know of a solution to fix the problem?
lyono22 is offline
post #2 of 78 (permalink) Old 09-03-2010, 10:03 AM
nick49's Avatar
Re: How long until your voltage regulator rectifier takes a shit? 06-07 gsxr 600
As a motorcycle shop owner and tech with decades of experience, I was shocked to see it mounted in the hot air stream exiting the radiator. The reason it has fins on it are to keep it cool. The way it works is to change excessive voltage into heat. Heat is it's enemy. I thought about moving it or making a deflector for it. I'm no engineer, and don't know how much heat and for how long will take it out, but I don't think it makes sence to mount it behind the radiator.
nick49 is offline
post #3 of 78 (permalink) Old 09-03-2010, 10:21 AM
MAD_ARAB's Avatar
Motorcycle: A revamped K6 liter
My girls 07 750 had the same mileage when hers went out. The stator was fried as well.
MAD_ARAB is offline
post #4 of 78 (permalink) Old 09-03-2010, 10:29 AM
Adsuzukiboy34's Avatar
Motorcycle: 1996 Gixxer 750 + 1997 TL 1000s
JESUS, what do you guys do to your bikes?
My SRAD 750 (96) has 50,000km, orig reg/reg...
athough I have had the usu melted plug issues, hot start issues etc.
Cheers, Ad
Adsuzukiboy34 is offline
post #5 of 78 (permalink) Old 09-03-2010, 10:36 AM
MAD_ARAB's Avatar
Cheers, Ad
My 06 1000 has 87k miles, not kilometers, and hasn't had any isssues whatsoever. The 600's and 750's mount the rectifier right behind the radiator so they soak up the heat.
MAD_ARAB is offline
post #6 of 78 (permalink) Old 09-03-2010, 10:48 AM
reg/rec's on SRAD's are under your left thigh, away from heat sources, but still prone to frying...
I also hear that CBR's are prone to frying them too.
Is is related to heat?
someone hear mentioned in a SRAD forum to get a later model mofset r/r. What is this and what is the diff?
Cheers, Ad
post #7 of 78 (permalink) Old 09-03-2010, 10:54 AM
MAD_ARAB's Avatar
Yes it has to do with heat. I've yet to hear of anyone replacing one on a K5-6 1000 yet.
MAD_ARAB is offline
post #8 of 78 (permalink) Old 09-03-2010, 07:08 PM
Motorcycle: 600k7 SOLD
My R/R went at 17k miles and I live in vegas.
LatinKraze is offline
post #9 of 78 (permalink) Old 09-03-2010, 07:33 PM
flzrider's Avatar
Motorcycle: 2006 GSXR600
Mine went out at about ~7k. Bike is all stock.
flzrider is offline
post #10 of 78 (permalink) Old 09-03-2010, 07:54 PM
Nittany Lion
Motorcycle: Track - 99 SRAD 600, Street - Blue/White K8 750
Gixxers aren't the only bikes commonly with this problem. For one, the Zx's it's common, with even very low miles. It's not the bike. It's the heat. A big factor is where you live or how hot it is the day you ride. Sitting in traffic on a hot day, I am sure is a factor as well. They go out on cruisers also. I think an additional factor is the rider. Maybe some people with this common problem are for example wrenching on their throttle (building up engine heat around the rectifier) in city traffic, coming to a lot of stops and the rectifier doesn't have the air or time to cool properly.
pearljam724 is offline
post #11 of 78 (permalink) Old 09-03-2010, 09:46 PM
42,000km (26,000+ miles) and no reg/rec problems. Used in all weather, rarely used for commuting, mostly ridden in the twisties covering decent distances at a time.
A large number of forum threads may only represent a very small percentage of bikes with a problem, unfortunately this model seems to have quite a few of these issues. (H/J, waterpump seal, reg/rec, etc)
OutOfMyDepth is offline
post #12 of 78 (permalink) Old 09-04-2010, 01:41 AM Thread Starter
How the hell can you fry a gsxr 600 stator at 7K? I didn't think that the regulator rectifier would/could cause your stator to go bad. Should I just replace both of them to save myself from droppin another $200.00 on another stator? The guys at the shop I go to are retards and I wouldn't know the first thing about testing a stator.
lyono22 is offline
post #13 of 78 (permalink) Old 09-04-2010, 01:50 AM
lopeman's Avatar
Motorcycle: 2007 GSX-R750
Mine went at about 16000 Km (10000miles).
Do yourself and replace it with a heavy duty one, DONT buy another from suzuki or the same thing will happen
lopeman is offline
post #14 of 78 (permalink) Old 09-04-2010, 10:27 AM
NightbatŪ's Avatar
Motorcycle: GSX-R 750k6
Mine went at roughly 20k
This was a few K after my stator blew, which may as well have sped up the R/R's demise
(and the battery)
My bike isn't handled with velvet gloves
Commuting, short rides, rain, heat, cold, salt, etc.
These things are mass-produced by the lowest bidder, some will last a lifetime, others will fry at the mere sight of a charge
NightbatŪ is offline
post #15 of 78 (permalink) Old 09-04-2010, 10:53 AM
this might be a stupid question, but how do you know if your voltage regulator rectifier has gone bad?!
I had a battery/electrical issue a couple days ago and I just replace my 4 yrs old battery and hopefully everything will be fine. here is the my post if anyone and chime in.
bike dies at red light...electrical problem? Help Please!!
Thanks
eatmydust is offline
post #16 of 78 (permalink) Old 09-04-2010, 03:43 PM
NightbatŪ's Avatar
Thanks
1: Starter appears 'lazy' for a few days/weeks
-then in quick succesion
2: bad smell
3: puffs of smoke
4: bike dies on the spot
post #17 of 78 (permalink) Old 09-04-2010, 03:52 PM
Superstock
toy_spd's Avatar
Motorcycle: 2006 GSXR 600
40k miles then it went out on mine.
toy_spd is offline
post #18 of 78 (permalink) Old 09-04-2010, 07:15 PM
MaxSmoothRed's Avatar
Motorcycle: K7 600 Gixx
13,000 miles and no problems with either yet. I ride 68 miles each day to and from work.
MaxSmoothRed is offline
post #19 of 78 (permalink) Old 09-04-2010, 07:16 PM
post #20 of 78 (permalink) Old 07-10-2012, 01:18 PM
So if the RR is supposedly working ok....should it be as hot as the motor???
willum is offline
