Oil leak at water pump fix - Page 3 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #41 of 63 (permalink) Old 11-29-2011, 04:04 PM
Re: Oil leak at water pump fix
Originally Posted by SuperMotoRuss View Post
The blue stuff is Loctite medium strength threadlock/sealant. Don't put silicone on the bolts and be sure you torque them to spec w/torque wrench, very easy to strip the threads in the aluminum.
Yea thats what I meant... I just couldn't think of the word so I said silicone lol Thank you
Eric Noa is offline
post #42 of 63 (permalink) Old 12-20-2011, 04:54 AM
Hey guys Im getting ready to change to o-ring and Im a bit confused about the Permatex UltraCopper RTV. Do I put 1/16 bead in front and behind the o-ring or just behind it? how far apart from the o-ring? Looks like the previous owner had sealed it and got a little too crazy with the RTV because it had a lot when I removed the pump.
Eric Noa is offline
post #43 of 63 (permalink) Old 11-25-2012, 03:43 PM
Motorcycle: 2001 GSXR 1000, 1975 Honda CB125s
I know this is old but thanks for the info. I just did all this today so we will see how it works.
RyanEJ25 is offline
post #44 of 63 (permalink) Old 11-26-2012, 05:25 PM Thread Starter
Motorcycle: K7 GSXR 750, 06 DRZ400SM
I hope it works, if not, just replace the pump assy. Mine worked for awhile then start leaking from the internal seal at only 1400 miles.
Gonna catch h3ll for bringing up a zombie thread.
SuperMotoRuss is offline
post #45 of 63 (permalink) Old 11-30-2012, 12:51 AM
Hahaha im surprised i havent yet. I changed the o ring but still leaked. So i re did it with the rtv and will see how it goes. If it still leaks im getting a new pump
RyanEJ25 is offline
post #46 of 63 (permalink) Old 05-25-2013, 12:26 PM
WraithBlade993's Avatar
Motorcycle: 2005 Suzuki GSX-R750
So the internal seal you speak of is the Oil Seal inside the Pump? See link from Babbits: http://www.suzukipartshouse.com/oemp...adb/water-pump
Is so it seems the most viable and long term solution is the entire pump replacement I guess right?
Just narrowed mine down to this area this morning. Got 48,000 on my baby. Orig 2,292!
WraithBlade993 is offline
post #47 of 63 (permalink) Old 06-19-2013, 03:30 PM
FEDXBOX's Avatar
Motorcycle: 2006 SUZUKI GSX-R 600
I know this is old, but I need help, looks like I have the same problem oil leaking from water pump or somewhere in that area, but also I found some coolant leaking from the hose that connects to the radiator, I tided the clamp on that hose and seems to be fine now, but I' am thinking maybe there is a problem with water pump or some problem in the cooling system, maybe some preassure, the bike never overheted, any help?
FEDXBOX is offline
post #48 of 63 (permalink) Old 09-06-2013, 01:52 PM
Motorcycle: GSXR1000 k4
Thank you for all informations, I have actually same problem, I had changed my Head Gasket And all thing, but I have the same problem the leak the oil in water and the same, anyway I will change my water pump and I hope the problem resolving
dj-psycho is offline
post #49 of 63 (permalink) Old 09-06-2013, 03:30 PM
Motorcycle: GSXR 750K6, 2007 Kawasaki Z1000, Aprilia SXV550, DR650
I think you are saying that you have oil in your water?
The first thing to check is the oil cooler. They crack internally and oil and water can go either way.
rv6john is offline
post #50 of 63 (permalink) Old 02-19-2014, 11:24 PM
I'm having the same problem as the first picture, it drips like a drop or two of oil somewhere near or around that bottom bolt. anyone know if its the #9 o-ring? i don't wanna order the o-ring when its something else? sorry to bring back the old thread
eesespieces is offline
post #51 of 63 (permalink) Old 04-02-2015, 12:49 PM
I ordered the #9 installed it, still leaked. Did the new #9 with the sealer, still leaked. New water pump, no leak. It's easy enough to do, but the pump is $184.00.
Mine wasn't a drip here and there, it was 2 quarts on the drive in front of work one day.
WB450 is offline
post #52 of 63 (permalink) Old 02-27-2016, 04:05 AM
I just got done fixing this problem...
amidst all 3 pages of ideas on how to do this, there was one dude on page one who said "why not put a fatter O-ring in there".
so after the sealant attempt failed, I did just that...so far no leak...I'll report back in a week or so if it's still not leaking...and sooner if it fails.
If it holds up, then I'll do a step by step of how I did it...
Mine's a K2 1000.
K2Lee is offline
post #53 of 63 (permalink) Old 04-10-2016, 10:55 AM
Hi guys. So I need a little help with this issue. So it's happened to me now and I replaced the O ring and followed the steps however it is still leaking oil.
I felt underneath the water pump a day I found that between the pump and engine there is a small gap. Should the pump go all the way up against the body? Or is the gap normal? If the gap is normal the O ring isn't working. If it isn't normal, then the O ring is preventing the pump from going all the way in.
So anyone know the answer? Gap or no gap?
VengefulRat is offline
post #54 of 63 (permalink) Old 10-15-2016, 10:27 AM
flipmode007's Avatar
Motorcycle: gsx-r 600 2006
I have posted a little video of mine
I'm going to change all the seals.
flipmode007 is offline
post #55 of 63 (permalink) Old 10-17-2016, 09:27 AM
GSXR-BR's Avatar
Originally Posted by Eric Noa View Post
Hey guys Im having the same problem with my k6 750! Its been leaking oil and it seems like its coming from the water pump but Im not completely sure.
Im going to attach a diagram of the water pump assemble just to make sure that what Im going to buy is what I need to solve this problem!
I need o-ring 8 & 9?
I can see some oil behind the water pump... I thought it could be oil coming from the chain after lubing it... Now i see this thread, i think it is coming from the water pump itself... But looking at this drawing, part No5 seems the responsible for sealing oil, isn't it? Or it is part No9 I should be replacing??
GSXR-BR is offline
post #56 of 63 (permalink) Old 10-21-2016, 08:10 AM
GSXR-BR's Avatar
Does anyone know this o'ring dimensions?
GSXR-BR is offline
post #57 of 63 (permalink) Old 10-22-2016, 02:44 PM
Check the service manual but I dont think they mention the dimension of it.
Suzuki GSX-R 750 2006 Service Manual | Service manuals for Suzuki GSX-R Motorcycles
GSXR-BR likes this.
post #58 of 63 (permalink) Old 10-22-2016, 04:13 PM
GSXR-BR's Avatar
Removed water pump and it was that bad 👆
I found a rounded 3mm thick o'ring and just installed (ID 32mm), let's see now what happens... OEM was oval, 2mm width and 1,5mm height... It was little harder to slide the water pump back in, it seems to be tight fit now... So it is not supposed to leak...
GSXR-BR is offline
post #59 of 63 (permalink) Old 10-22-2016, 04:21 PM
GSXR-BR's Avatar
Painted water pump black too.
GSXR-BR is offline
post #60 of 63 (permalink) Old 10-22-2016, 08:01 PM
Im having issues with coolant getting into my oil, not much by the looks of it but im thinking either seals in water pump or oil cooler. Bot actually getting any oil dripping out of the bike tho, any ideas?
Gsxroy is offline
