Throttle mod hard facts R1 vs R6! (pics) - Page 25 - Suzuki GSX-R Motorcycle Forums Gixxer.com
 2Likes
post #481 of 550 (permalink) Old 08-17-2012, 12:09 AM
Wears Girly Gear
Re: Throttle mod hard facts R1 vs R6! (pics)
Originally Posted by Zippysport View Post
Get as much slack from every adjuster as you can. I had to grind down the lock nuts to get enough slack at full lock. I have the same combination you do. I have a 2007 750 and the R6 throttle tube. Some people have put both lock nuts on the same side of the adjuster down at the throttle body, but I wanted to be a little more professional and proper about it. Having a throttle that snaps back properly seems to me to be pretty important.
I was getting very frustrated with mine as I almost gave up trying to get any slack from the adjusters. FINALLY, at the very end of the adjustment with both cables backed ALL THE WAY OUT, there was a little bit of slack. I was almost on the verge of putting stock back on.
Another problem I had is I couldn't put my grip all the way at the end of the tube. Since there isn't a second cam for the grip to rest on outside of the housing, the grip would stick.
Brian2006 is offline
post #482 of 550 (permalink) Old 09-25-2012, 11:24 PM
Motorcycle: 2007 GSXR750
Is this the same throttle tube?
Motion Pro Throttle Tube Yamaha R6S YZF R6S 2006-2009
I want to do this mod but want to make sure its the write tube. Thanks
4BTS12 is offline
post #483 of 550 (permalink) Old 11-19-2012, 02:59 PM
ErikGSXR's Avatar
avoid r6s i think. i just did this and got a 2007 R6 tube and its a noticable difference
ErikGSXR is offline
post #484 of 550 (permalink) Old 12-10-2012, 10:41 AM
Olkka's Avatar
Motorcycle: GSX-R 1000 K7
Received my R6 throttle and gonna do this mod to my GSX-R 1000 K7 next spring. Thanks a lot for this awesome thread!
Olkka is offline
post #485 of 550 (permalink) Old 01-21-2013, 10:57 PM
great write up i just ordered a R1 tube today for my K7 750
j23a45m is offline
post #486 of 550 (permalink) Old 01-22-2013, 09:15 PM
Taught Goatsee everything he "knows"
nitrous36's Avatar
Motorcycle: K4 GSXR 600
FWIW I think its worth rementioning that, if you want your new grips to stick well, use CA glue. Most bar grip adhesives dont work well and take hours to dry, and/or can become undone again. I tried first using grip adhesive a few times with no luck, as did others. Just wouldnt bond well, or if it did bond it wasnt long. That was my experience.
So if anyone encounters this problem, then head down to your local hobby shop and get CA glue. Its usually used to bond R/C tires to rims. It bonds strong and dries fast. So you can be out riding and not waiting 6 hours for something to set up.
I could be wrong.
Don't quote me on that.
Originally Posted by I Fuck My Mom and Love It View Post
Ban me, that shit makes me fuckin hard!!!
Originally Posted by Ceiling Cat View Post
Prepare to get hard then.
nitrous36 is offline
post #487 of 550 (permalink) Old 01-28-2013, 07:46 PM
would this throttle tube work on my 06 gsxr 1000.. is it the same as the oem part. anyone have any experience?
http://www.ebay.com/itm/Motion-Pro-T...8ccb6e&vxp=mtr
vaser21 is offline
post #488 of 550 (permalink) Old 01-28-2013, 08:42 PM
hand-eye coordinator
MacBayne's Avatar
Motorcycle: K6-600
"OEM Replacement," so i would vote yes.
MacBayne is offline
post #489 of 550 (permalink) Old 01-28-2013, 11:03 PM
-JK750-'s Avatar
Motorcycle: K5 1000
R6S tube is like R1 tube. R6(R) has 40mm...
-JK750- is offline
post #490 of 550 (permalink) Old 01-29-2013, 12:32 PM
thank you very much will go ahead and just order the oem part
vaser21 is offline
post #491 of 550 (permalink) Old 02-27-2013, 05:00 PM
did a R1 tube today and wow what a difference
j23a45m is offline
post #492 of 550 (permalink) Old 03-21-2013, 10:54 PM
I did a r1 too, thought I did an r6 lol. just took mine back apart and its a 36.5 mm cable pulley .
stariondriver is offline
post #493 of 550 (permalink) Old 04-02-2013, 07:57 PM
Lindr6's Avatar
Motorcycle: 07 r1, 11 Gsxr 750, 08 Zuma
I did the 06 r6 tube. Thanks to this thread I dremmeld the housing works great. On my 07 r1 I have the motion pro revolver throttle kit. But this feels way better then that one. Thanks
Lindr6 is offline
post #494 of 550 (permalink) Old 04-03-2013, 12:14 AM
-JK750-'s Avatar
Motorcycle: K5 1000
You must be joking? Or your R1 has some weird throttle system compared to a GSXR.
-JK750- is offline
post #495 of 550 (permalink) Old 04-15-2013, 04:15 PM
update. r6 tube is in and works great. the housing did not need modified on my k4 gixxer, but the threaded extension did. I cut with a dremel and the slotted it so it came off nicely.
post #496 of 550 (permalink) Old 04-16-2013, 02:37 AM
DAKKAD's Avatar
sticky
DAKKAD is offline
post #497 of 550 (permalink) Old 05-10-2013, 08:29 AM
TwistedMister's Avatar
Originally Posted by DanielSVT View Post
Did mine last night along with vortex clip-ons and crg levers and OMG... Night and day difference with throttle control. Seriously, I highly advise this. I got mine for like 15 bucks shipped from bikebandit.com
did you have to mod the housing?
I ordered one off ebay from an 07, I was just riding on the freeway the other day and entering I was like jeez this thing could use a shorter throw, no problems taking off from a stop?
TwistedMister is offline
post #498 of 550 (permalink) Old 05-14-2013, 06:25 AM
Olkka's Avatar
Did the R6 tube mod to my K7 GSX-R 1000 with -1/+2 sprockets. What a difference! Just a bit Dremelling needed. Bang for buck mod, highly advised! Thanks!
Olkka is offline
post #499 of 550 (permalink) Old 08-03-2013, 04:45 PM
Islandtsi's Avatar
Motorcycle: K9 750
Upgraded my tube the other day from the R1 Tube to the R6 on my k9 750. The difference is massive. Not just in how easy to get to WOT, but in the rate of throttle pick up. At first I though my clutch was slipping the revs were building so fast
Islandtsi is offline
post #500 of 550 (permalink) Old 08-05-2013, 09:06 AM
did this also, and love it! Great cheap mod that anybody can knock out in no time.
MassAppeal16 is offline
