Chain adjustment - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 12 (permalink) Old 12-29-2004, 07:52 AM Thread Starter
Chain adjustment
Is it necessary to have a rear stand when you adjust the chain?
Texasgsxr600 is offline
post #2 of 12 (permalink) Old 12-29-2004, 08:44 AM
fugitiveorphan's Avatar
Motorcycle: RC51, R6 Racebike, DRZ 400
Re: Chain adjustment
not absolutely necessary...but helps a helluva lot!
fugitiveorphan is offline
post #3 of 12 (permalink) Old 12-29-2004, 09:35 AM
gimpsta's Avatar
Motorcycle: race 04 600/'06 gix 1k/'03 KX65/'06 R6/'07 750 #315
na, just loosen the axel nut a tad, loosen the two nuts on both sides on the adjuster screws, and then turn the screw ever so slightly till she tightens where you want her.
gimpsta is offline
post #4 of 12 (permalink) Old 12-29-2004, 03:13 PM
rraiderr's Avatar
Motorcycle: Stretched and slammed Busa
Suzuki service manual does it with the bike on the kick stand.
On race bikes with no kick stand I used rear stand and it worked well. Make sure you re-check the tension when the bike is back on the ground. To tight is very bad.
rraiderr is offline
post #5 of 12 (permalink) Old 12-30-2004, 03:37 AM
gimpsta's Avatar
yes recheck on the ground. your actually suppose to be sitting on the bike, and have a friend adjust the chain with you in full gear. If its ona stand, it is being pushed against the swingarm making the tightness of the chain change.
gimpsta is offline
post #6 of 12 (permalink) Old 12-30-2004, 11:14 AM
Luper's Avatar
What size is the rear axel nut? I'm going to have to buy one that f'ing big... Do you guys just reuse the cotter pin or pick up a new one. Thx.
Luper is offline
post #7 of 12 (permalink) Old 12-30-2004, 11:42 AM
Motorcycle: b m
That nut is 36 mm I think. Socket on 1/2 drive flex bar works good and retorque to 78 foot pounds. I use a cheapo floor jack to lift the back wheel to adjust the chain and then its easy to spin some lube on. But like someone else mentioned the tension should be checked with a full load on bike. I use a clip like retainer that I can reuse. I hate trying to bend the cotter pins so I can get them in and out.
beeboy is offline
post #8 of 12 (permalink) Old 12-30-2004, 01:47 PM
Here is your "R"
Ibidu1's Avatar
Motorcycle: Ibidu1
When adjusting the chain make sure you have your weight on the seat, when you check it. You want about 1.5-1.75 inches of play gixxers need a loose chain for them to handle right. The trick on gixxers is to have it loose to about 2 inchs so when you tighten up the axle nut it should tighten to 1.5
Also its a good idea to buy stands, if you cant afford them. Try buying handy stands 99 bucks you get both.
Ibidu1 is offline
post #9 of 12 (permalink) Old 12-30-2004, 02:00 PM
gimpsta's Avatar
you should have the proper tool in your tool bag in the trunk.
I didnt' read the other posts but, reuse the cotter pin if you want. or get another. sooner or later it will break
gimpsta is offline
post #10 of 12 (permalink) Old 12-31-2004, 02:06 AM
Luper's Avatar
Thanks gimpsta, I didn't even think to look in the tool bag. Doh!
Luper is offline
post #11 of 12 (permalink) Old 12-31-2004, 03:17 AM
gimpsta's Avatar
haha
I've been there. I didn't have any clue about a single thing. I was so lost when I bought my 2002 600, that I probably shouldn't of even owned the bike in the first place. But look in your bag. Its goes look like any orndinary tool. Its pretty much a handle attached to what would be a cut out of your rear axel nut.
gimpsta is offline
post #12 of 12 (permalink) Old 05-22-2007, 02:15 PM
Motorcycle: Blk&Yel Rocket Sled!!
I just adjusted the chain tension on my 05 1k so that when I am sitting on the bike with all my gear on I have 1" of chain play halfway down the swingarm.
Am I in the ballparck for my tension?
tj1971 is offline
