05 GSX-R 600 "Rebuild" - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 9 (permalink) Old 11-14-2012, 10:13 PM Thread Starter
Kekoa's Avatar
Motorcycle: '05 600
Iʻve had my bike for a year and itʻs age is showing. If it being two motorcycle generation old doesnʻt surprise you enough, here is a list of references to show what times were like when the motorcycle left the factory:
-Gas was $2.30 a gallon (US)
-Hurricane Katrina flooded New Orleans
-President Bush began his second term
-It had been 3 years since OIF
-Valentino Rossi had been with Yamaha for 1 year
-Star Wars: Episode II was released in theaters
Like most sport oriented motorcycles, theyʻre primarily bough either a) by military service members who thrash them till they get married or are discharged, or b) a person from the upper middle mid-income class going through a mid-life crisis. My bike was born from the former, meaning that the bike was fundamentally untouched, maintenance wise. What does this all mean? The old gal is due for an over haul.
Iʻll be posting on this thread partially as a way for me to ask questions when I get stuck, and for others to learn from my mistakes now that this motorcycle has passed the sub $4k mark on craigslist. Making is more appealing to income challenged individuals like myself.
Iʻm concentrating on my tool list for black Friday, but stay tuned as Imma lay out my plan of attack for the next few months. Deadline being the ides of March, when my safety check expires.
BRB!
Kekoa is offline
post #2 of 9 (permalink) Old 11-21-2012, 09:05 AM
meat_whistle's Avatar
Motorcycle: '04 gsx-r 600
Not gonna lie. I read this post on Friday and made the same exact realization. I had a gang of parts stored up in my house that I've. Been meaning to throw on....brake pads, wheel bearings, fairings, new hardware etc. also wanted to degrease all of the bearings, and check the valves. With the realizations you pointed out, I realized it was long overdue given the long, fuckedup life my bike has undoubtedly had.
Sent from my iPhone using Motorcycle.com Free App
meat_whistle is offline
post #3 of 9 (permalink) Old 11-23-2012, 10:54 PM Thread Starter
Kekoa's Avatar
Motorcycle: '05 600
Re: 05 GSX-R 600 "Rebuild"
@meat_whistle: 7 years might not seem like a lot for a car, but that's acient in motorcycle years.
UPDATE: Got my new tools, tool box, some supplies and such. Just ordered the last few things I needed and they should be coming in sometime next week, so once they do I'll start taking pictures and cataloging. Below is the current to-do list. I'll post the "lifetime" list later that has everything that needs to be checked, but the items below are the most important right now.
To-Do List:
_Change front and rear tires
_Vinegar "flush" and replace coolant
_Re-wire R/R wire harness
_Get forks and shock rebuit
Kekoa is offline
post #4 of 9 (permalink) Old 12-01-2012, 07:41 AM
Motorcycle: 2006 gsxr 750
Couldn't agree more. I bought an 04 gsxr 600 with a 750 motor.... Had no idea what was maintained... I did coolant oil brakes thermostat water pump battery and switched to kn air filter only thing I think I need to do is flush the brake fluid
Sent from my iPhone using Motorcycle.com App
Dcgixxxerguy is offline
post #5 of 9 (permalink) Old 12-20-2012, 01:56 AM Thread Starter
Kekoa's Avatar
Motorcycle: '05 600
List of threads tracking my progress so far.
Front Wheel Removal
Front Wheel Removal and Install
Rear Wheel Removal
Rear Wheel Removal and Install
Shock Removal and Install
Fairing Removal and Install
Front Damper Removal and Install
Mounting and Balancing Tires
Regulator/Rectifier Repair
Regulartor/Rectifier Repair
Like my other thread showed, I didn't get the shock rebuilt. Wouldn't be worth the effort really, so I skipped it. Kinda wish I knew before I had to go out of my way to remove it and take it to a stealership. But glad I got a chance to get the linkage all greased up.
Shock rebuild kit
Shock rebuild kit
Next job is to zip tie stich fairings. It's cooler than it sounds. I've got it almsot done, just need pictures of the motorcycle as a whole so you can see the effect.
Kekoa is offline
post #6 of 9 (permalink) Old 12-20-2012, 01:59 AM Thread Starter
Kekoa's Avatar
Motorcycle: '05 600
Kekoa is offline
post #7 of 9 (permalink) Old 12-20-2012, 05:21 AM
GS220's Avatar
Motorcycle: 06 GSXR 1k, 07 CRF 450r
Front Wheel Removal
Rear Wheel Removal
Shock rebuild kit
Shock rebuild kit
I really don't think this is the forum that needs useless threads on these things like removing tires, fairings etc. If you don't know how to do that, you shouldn't own a motorcycle.
GS220 is offline
post #8 of 9 (permalink) Old 12-20-2012, 11:34 AM
kevin.g's Avatar
Motorcycle: K6 600
I think you should have kept your progress in one thread, now there's two dozen to follow and for you to update my k5 is not in that bad of shape. It's really not that old, just needs some TLC every now and then. Only thing that comes to mind which is bothering me on it right now is that the fast idle isn't working... other than that and some cosmetic blemishes it's tip top
kevin.g is offline
post #9 of 9 (permalink) Old 12-23-2012, 04:18 PM
edgezr's Avatar
Motorcycle: gixxer 600 k4
at this point this year production bikes need some replacements, specially ruber parts cause get old really fast...
edgezr is offline
