HOW TO: Headers swap 600 vs. 1000 (PICS) - Page 13 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #241 of 268 (permalink) Old 04-13-2012, 03:12 PM
phillipse's Avatar
Motorcycle: K4 GSX-R750
Re: HOW TO: Headers swap 600 vs. 1000 (PICS)
So does anyone have a 750 map for 01-04 1k header with an 05-06 1k M4 GP.
phillipse is offline
post #242 of 268 (permalink) Old 05-02-2012, 09:56 AM
just browsing's Avatar
Motorcycle: K4 750
The dynojet website doesn't have something similar to your setup? I have a feeling the only way you'll be able to get a map made specifically for your parts is to get some dyno time.
just browsing is offline
post #243 of 268 (permalink) Old 05-02-2012, 09:57 AM
Motorcycle: K4 750
And for you clowns that are too lazy to read through this entire thread or use the search...
FAQ: 1k Header Swap
post #244 of 268 (permalink) Old 07-29-2012, 04:30 PM
I have a k5 750... Could I fit a full system for a k5/k6 1000 onto my k5 750? I was looking at a
Scorpion GP Exhaust full system...
Please reply before i order and f things up..
myk5750 is offline
post #245 of 268 (permalink) Old 08-09-2012, 01:47 PM
kevin.g's Avatar
Motorcycle: K6 600
Originally Posted by mikeeg02 View Post
05 1k headers will fit your bike. I used 05 1k headers on my 05 750. You would buy the exhaust that fits your header. So if you now have 05 1k headers, you buy a slip on for an 05-06 1k. (as 05 and 06 were the same on the 1ks.)
Looking to do this, will I have to mess with the fairings or anything or should it be a straight forward swap with no modifying? I have a k5 750 just for clarification.
kevin.g is offline
post #246 of 268 (permalink) Old 10-19-2012, 01:39 PM
can any one see the pictures?? its not displaying on my laptop or pc
jrai is offline
post #247 of 268 (permalink) Old 10-19-2012, 02:27 PM
FlaGatorL's Avatar
Motorcycle: 2004 GSXR 750
It will burn the bottom unless you trim them a little. Not a big deal
Sent from my iPhone using MO Free
FlaGatorL is offline
post #248 of 268 (permalink) Old 10-23-2012, 05:00 PM
I just did the swap was pretty painless but this is the issue I ran into. Anyone else ran into this or know what I can do to fix it? Its not like you can just push this away its very tight up against the plastic.
Then this didn't line up either.
Here are a couple more pics of the process.
stoney667 is offline
post #249 of 268 (permalink) Old 11-04-2012, 01:31 AM
Just to know.... Did someone run on a dyno??
Excluding the weight gain. Are three any performance loss due to different lenght, form, and measures???
Sent from my iPhone using Motorcycle.com Free App
simone.campo is offline
post #250 of 268 (permalink) Old 11-04-2012, 01:44 AM
My suggestion?? Bring the pipe to someone that CAN CUT the valve and replace the pièce soldering a new steel pièce without the valve. Actually your ECU does not support that valve so is a nonsense keep it
post #251 of 268 (permalink) Old 11-07-2012, 06:13 PM
schnezy's Avatar
Motorcycle: 2005 GSXR600
For the people who have done this, did you use the old gaskets or use new ones? If you used old is it working out and for how long has it been since you swapped?
schnezy is offline
post #252 of 268 (permalink) Old 11-08-2012, 12:00 AM
Lets go racing!
Chugs's Avatar
Going on 2+ years using old gaskets.
Chugs is offline
post #253 of 268 (permalink) Old 11-08-2012, 09:09 AM
FlaGatorL's Avatar
Mine too
post #254 of 268 (permalink) Old 11-08-2012, 06:04 PM
LexusGSXR231's Avatar
Motorcycle: K5 GSXR 600
On my swap ... I used zip ties on the midpipe bolt.. I didnt put a bolt thru there.. just 3 big zipties.. and then jb weld the hole on the midpipe..
EDIT: Where your pipe is touching the plastic.. you need to add spacers aka (Washers) in between the fairings and bolt... so the midpipe wont burn ur fairings up.
LexusGSXR231 is offline
post #255 of 268 (permalink) Old 05-15-2013, 04:38 PM
g1xxerbro's Avatar
Motorcycle: 2004 gsxr 600
Exclamation Re: Headers swap 600 vs. 1000 (update more pics)
WHY CANT I SEE THE PICTURES??? WRITE UP IS GREAT BUT WANT VISUALS
Originally Posted by I'm-a-punk View Post
Hello! Hello!.. Welcome to the thread of Headers! I am going to be teaching you today on a HOW TO:
The 05 STOCK Headers+midpipe 600 is heavy.. The 03-04 GSXR1000 headers is light.. I was surprised.. I cannot believe the frickin diffrence from STEEL headers VS. Titanium headers. The weight advantage is a big huge diffrence... You shaved off maybe 15-20 lbs. in weight.. I don't know. Just using my head.. I don't have a weight scale to check.
This mod is 6 on scale of 1-10 easy to hard. It should last you prolly 1-2 hrs. depends on how fast or slow you want to do it. All i did was take my time and everything went smoothly. After everything is done, you will have to modify your fairings, so the exhaust wont touch and melt it.. If you go to the second page on this forum, you will see how i modify my fairings. It don't take much to do and it works real good. Bolt nuts and washers.
Taking old headers off-
You take BOTH fairings off.. Alot of room.. You can use "PB Blaster" or WD-40 to the headers bolts.. let it soak in for like a mins, so you can unscrew those ungodly, nasty, rusted 6mm allen bolts off.. You can skip this step if you want. But, they are hard to get off, if you dont. Take a Long torque bar at it. Then you can unscrew the 10mm at the lower part of the radiator. take the screw out. then you UNscrew the 2 top 10mm bolts on the upper radiator,. Don't take them out.. just loosened it up to where you can move the radiator out towards your front fender. Then grab something you can put in between the radiator and its mounting bracket to keep it coming back down on ya, when your unscrewing the allen bolts off the headers. I grabbed a lil fuse box i found in the garage and used that for this part.. you can see in the pics.. It gave me enough room to unscrew all the headers ALLEN BOLTS out.. I did this very very carefully.. "GO SLOW, TAKE YOUR TIME". dont hit your radiator FINS.. you can bend them easily.. You can always use a small flathead screwdriver to make them straight.. After you take all 8 Allen bolts out, But, before you take your 600 HEADERS OFF.. You need to go where that 12mm bolt is right by your FOOTPEGS and take that off first. before you drop the headers down... THEN "Slowly drop your 600 headers down and SLOWLY pull it out".. Feel How heavy that Son of a bitch IS.. DAMN!
Putting the NEW Headers on..-
I got some extra GASKETS i found in my garage from when i had my 03 600, i was putting full exhaust on.. So i grabbed 4 new GASKETS.. I took 4 of the old ones out.. You can put 4 new ones in or you can keep your old ones you have now, and reuse them.. Then you take the Titanium Headers and "SLOWLY put it up to the gaskets". I put "BLUE" Loctite on the allen bolts When i put them back in.. You can do this, if you want to.. You dont have too. But, in the future they might loosen itself up from all the riding and WOT. Exhaust LEAKS sucks. So, After You put all the bolts back in and hand tighten all of them til the headers seats to the gaskets you put in.. Once all that is done, You proceed to tighten all the allen bolts starting from the middle and work your way out.. i tightened them all down to 16.5 ft. lbs. when i did it, cause thats what the OWNERS MANUAL says to do.. OR you can handtighten them yourself or whatever.
Thats it..
how it should look when both right and left fairings are off the bike..
OEM 600 headers + midpipe
Your 600 headers + midpipe together vs. 04 GSXR 1000 headers only- no midpipe.
the fuse box i use to space it out.. (You can use whatever you want to space that out)
Old Gaskets which is kept. and (8) headers allen bolts
The 04 GSXR1000 Titanium headers on the bike.. (How it should look after everything is done)
Your Gixxer owners manual, old gaskets on bottom, new gaskets Vesrah on top (if bought)
g1xxerbro is offline
post #256 of 268 (permalink) Old 05-12-2014, 05:07 PM
Jut did this swap today and liking it so far. Just one quick question. Does the butterfly have to be removed from the header?
krnbk1 is offline
post #257 of 268 (permalink) Old 06-16-2014, 07:28 AM
If doing this swap could I use my existing 600 midpipe or would I need a 1000 midpipe to go with the headers? Thanks
Kylinder is offline
post #258 of 268 (permalink) Old 07-02-2014, 06:31 PM
I bought a 2013 Gixxer and would love to do this mod. But will it work and if so, what year headers would I be looking for? Thanks in advance.
dontnvme is offline
post #259 of 268 (permalink) Old 07-17-2014, 01:41 PM
rcarson15's Avatar
Motorcycle: K3 600
And as I understand it, 03/04 headers DO NOT have fairing spacing problems?
rcarson15 is offline
post #260 of 268 (permalink) Old 08-21-2014, 03:26 PM
Motorcycle: 2005 R1
Hello, I have searched/posted today and cant find an answer.
I have a 2005 750, will a 2001-2004 Gix 1000 Akra full system fit my bike?
Thanks
R1@150 is offline
