front brakes locking up - Page 2 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #21 of 32 (permalink) Old 05-29-2012, 08:04 PM
Re: front brakes locking up
This has also helped me thanks! still need to test ride but pretty sure it was the problem
92sc300tt is offline
post #22 of 32 (permalink) Old 12-03-2012, 08:23 PM
kirk750's Avatar
Originally Posted by Eatfacenukka View Post
I had to replace that lever recently... maybe thats my same problem.
*edit*
So I just went out to look at my lever, and to my surprise I didn't put the rod into the little toggle either. I took it off and readjusted it and will find out tomorrow if it also works.
Same problem. SAME SOLUTION! Simply didn't get the rod all the way into the receiving ball, it had rotated slightly so that it was out of line. Good deal guys.
kirk750 is offline
post #23 of 32 (permalink) Old 12-03-2012, 10:07 PM
Ass Packer
TeflonTrout's Avatar
Motorcycle: '99 GSX-R750-SOLD for '13 Kawasaki KLR-650
Yet another nugget of wisdom tucked away for the future. Glad none of you did a surprise front tire inspection.
TeflonTrout is offline
post #24 of 32 (permalink) Old 12-03-2012, 10:19 PM
zvenkruspe's Avatar
I'd always suggest Brake Lever first. Sometimes you'd think they use the same parts for the same generation of bike, ou just never know. I've had friends who did a quick repair by borrowing a spare lever off a buddy where the parts looked similar but in the end the fluid would warm up and expand, braking.
I doubt air would ever cause stiff brakes if the master cylinder and brake lever were 100% good.
Air gives a spongy feeling, compressing when pulling the lever. I can't have my brakes stiff enough for a light and quick response. Short thin fingers, girls thing.
zvenkruspe is offline
post #25 of 32 (permalink) Old 04-20-2013, 07:21 PM
I just got my 05 750 and we have no probs with it I knew it was a fixer upper so I bought it bad tires and a few other kinks. . . so we get new tires noticed by accident squeezed the front brakes when tire was off the front and the pads didn't really clinch together me and my buddy were scared so we put the tire back on and bled the all the points notices a lot of air coming out the thing was before we discovered this i was using the brakes and they were "working" for an inexperienced rider prob didn't recognize yes i noticed it was choppy but i assumed bc the tires. either way so order new M/C and we take old one apart and notice the spring is a lot cruntched as the new one so im assuming its because that's old been used worn down so we do everything bleed brakes so no air in btw we clean out all the lines everything. so my guy helping me says let me go for test ride and about 2-3 miles brakes lock on him and he tried reengage the brakes and the wont budge he bleeds them and they work again so we come back and thinking pistons might need lube we bleed again and again and i go out 6-7 miles in i start smelling odor my front start bobbing and i pull to side and my brakes lock again . I m confused ive read this post from beginning to end and yes i do have after market levers from previous owner just ordered new rotors bc mine are black/brown now im just asking for suggestions might be the case we are checking the lever later today but if that's not the issue what would prob be the next thing to check
THSlay21 is offline
post #26 of 32 (permalink) Old 04-20-2013, 07:31 PM
AKA Pee Wee Herman
1/4milecrazy's Avatar
That was almost impossible to read. Try using some punctuation. It goes a long way around here.
As for your problem. I bet you have cheap chinese aftermarket levers, replace them and your problem will be gone.
1/4milecrazy is online now
post #27 of 32 (permalink) Old 04-21-2013, 06:09 AM
Your right about the bad grammar I was just in a little bit of a rush. But as of right now I'm concerned in the fact my bike never acted that away before. Now this happened after we put the new stock guts for the M/C. What is bad the guy I bought it from I know as a Co worker and he said that the whole M/C ass. is nissin and the lever is yana shiki but the guy I working on it with says the M/C is stock, and he says the lever does look like it but we tried searching for those specific levers couldn't find them. Come to find out he bought the whole set on ebay so I don't know. . . . Im about to go on bike bandit see about some levers and brake pads hoping that is the case. If not would it be smart to buy caliper piston rebuild kit or just piston seals kit? We've narrowed it down to either lever or calipers if those fail we don't know what is going on.
THSlay21 is offline
post #28 of 32 (permalink) Old 04-21-2013, 06:38 AM
Viking Foreign Affairs Attaché
Minibull's Avatar
Motorcycle: 1998 GSXR 750
1 ellipsis
2 full stops
Holy fuck that was hard
Like 1/4milecrazy said, dodgy levers for you sir. If the lines were full of air before, I don't think the shitty lever would have been able to do the usual thing they seem to do, which is where the brake drags as the MC plunger doesn't sit properly in the pivot hole. The fluid heats up and the brakes drag and eventually lock.
Go here Brakes locking up when riding? New LEVERS? Read here PUBLIC SERVICE ANNOUNCEMENT!!
You bled it, go for a ride with proper working brakes, and the front locks up.
Being that you say something about getting levers off Ebay, I would say it is the levers causing problems. Get a nice set of levers from a reputable company like FP, Pazzo, ASV, CRG, etc.
Nissin is the stock MC btw
1998 GSXR 750: Titanium Yoshimura Tri Oval Exhaust System, Lindemann Engineering Forks (Superbike Revalve), Nitron NTR R3 Shock,
K&N Filter, A.P.E MCCT, Matris M4R Damper, Factory Pro Case Covers, Renthal Clip Ons, Robby Moto Rearsets,
Goodridge Steel Lines, Brembo RCS Master Cyl, Nissin 6 Pot Calipers, Brembo Clutch Perch
Yoshimura Triple Clamps, Sato Exhaust Hanger, Carbon Fender, Yoshimura Pillion pegs.
Minibull is offline
post #29 of 32 (permalink) Old 04-21-2013, 09:49 AM
AKA Pee Wee Herman
Buy some factory levers, or a high quality pair of aftermarket levers. I suggest Motomummy or Sportbiketrackgear. The stock Suzuki master cylinder is Nissin, Yana Shiki is defintely one of the cheaper lever comapanies, they are better than the crap you find for $30 on ebay, but still, I think you should spend the money on good levers, The quality and dependability are worth the cost.
Take your time assembling and make sure the pin coming out of the master cylinder is lined up properly.
post #30 of 32 (permalink) Old 10-03-2014, 02:27 PM
Stupid. Who's with me?
TheGeek's Avatar
Take a look at your aftermarket lever. Pull the hinge pin out and see if you have to compress the brake MC pistion slightly to get it to go back in. If so, you can slowly drill out the hole until that condition is corrected.
TheGeek is offline
post #31 of 32 (permalink) Old 02-10-2015, 11:38 AM
Thanks to the OP for the solution. My bike fell over during the high winds and I could not figure out what had gone wrong, everything looked perfect!
I struggled to understand how the lever could be the solution but it was! New lever on and the difference is instantaneous. I had the original lever on the bike, and now presume it got damaged/bent in the fall. Picked up a pattern part from Saltire Suzuki in Edinburgh, back to normal brakes!
Thanks!
wmckin11 is offline
post #32 of 32 (permalink) Old 08-16-2015, 09:01 PM
Originally Posted by cheekymonkey View Post
Alrighty folks. I think I've figured this one out. On mine at least. I had an aftermarket brake lever on, which is when the problem started. I thought it might be a bad master cylinder but since it was fine before, I guessed it had to be something I did. Well, I had the old lever (OEM) on and it did the same thing. The curious thing was, when I set the adjuster so the lever was closest to the handlebar it would pull back all the way, but "bottom out" halfway to the handlebar. Normally the lever would practically touch the handlebar. I found out the hole on the lever where the m/c piston rod goes in has a small "roller" in the bottom. If you rotate that roller, you'll see another drilled out hole in it. The m/c piston rod end has to fit all the way into this hole to allow the m/c piston to FULLY extend and allow the brake fluid to return from the calipers. I haven't test ridden it yet, because of a thunderstorm, but I'll post the results by the end of today. Fingers crossed!!
Wow, I actually dropped my bike trying to make it out of the way of oncoming traffic when my front brake locked up. This was the fix. It's an expensive lesson I wish I would have learned earlier.
Thanks for the post, saved me hundreds.
BrokenGSXR is offline
