06/07 upper triple tree clamp,clip ons, master cylindar swap. - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 9 (permalink) Old 08-18-2009, 12:00 PM Thread Starter
Together_Rising's Avatar
Motorcycle: K5-600
Anyone know if this is possible?
I'd want to swap my dull and somewhat scratched upper fork clamp with one off an 06 or 07. I know the forks are the same dimension so if I can get an 06/07 upper, clip ons, brake reservior and brake/clutch handles would the swap be possible?
I like the throttle/brake lines to run under as well for a more clean look. What problems would I run into?
Thanks!
Together_Rising is offline
post #2 of 9 (permalink) Old 08-18-2009, 11:32 PM
Lets go racing!
Chugs's Avatar
Re: 06/07 upper triple tree clamp,clip ons, master cylindar swap.
looks like its possible but u might run into some clearance issues
Chugs is offline
post #3 of 9 (permalink) Old 08-19-2009, 01:23 PM Thread Starter
Motorcycle: K5-600
That's what I was thinking... Anyone else?
Thanks for the input!
post #4 of 9 (permalink) Old 08-20-2009, 07:05 AM
You'd be better off just getting a newer 04 triple. There's no advantages to the setup you suggest, and its more of a PITA than its worth.
po-po 5.0 is offline
post #5 of 9 (permalink) Old 08-23-2009, 07:52 PM
AnotherBend's Avatar
Motorcycle: 2004 GSX-R 600- Race bike without the race aspect :)
You mean like this?
AnotherBend is offline
post #6 of 9 (permalink) Old 08-23-2009, 08:24 PM
Lets go racing!
Chugs's Avatar
+1 on pita, just depends how much work u want to put into it, if u got time and patience go ahead, if u don't, then don't bother
Chugs is offline
post #7 of 9 (permalink) Old 09-04-2009, 10:09 PM
HANS's Avatar
Motorcycle: K4 GSX-R 750, 95 Kawi 1100, 03 XR 50
Anotherbend..... what setup is that?? 1k forks??
HANS is offline
post #8 of 9 (permalink) Old 12-20-2009, 08:59 PM
HANS's Avatar
HANS is offline
post #9 of 9 (permalink) Old 12-26-2009, 06:16 PM
shittygsxr's Avatar
Thanks!
I think anotherbend is just showing off with nothing to add. Fork size and offset is the same between models but the steering stem diameter is different (smaller on the 04/05) if you have a friend with a lathe it is as simple as a brass bushing
shittygsxr is offline
