c28 - Page 3 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #41 of 44 (permalink) Old 01-21-2012, 06:02 PM
Re: c28
Hey guys, so have the same FI and C28. Took apart the STVA, fixed all the soldiers, and put link wires, checked all the gears, and put it back together.
Weird part is that is tested fine on the bench when checking the pins. It also always made a sound but the butterflies just twitched and never went through their cycle. What exactly are the butterflies supposed to do on start-up? Anyways after reinstalling it does the same thing. Also with the motor out of the housing it would spin freely when plugged in and ignition on. Could it be bad STPS instead of the soldier issue? This on an 04' 600
Thanks for your help in advance!
Seth
Sethron71 is offline
post #42 of 44 (permalink) Old 01-22-2012, 12:26 AM
Stupid. Who's with me?
TheGeek's Avatar
Re: c28
You probably just installed it wrong.
TheGeek is offline
post #43 of 44 (permalink) Old 01-22-2012, 12:28 AM
TheGeek's Avatar
Re: c28
Originally Posted by gggplaya View Post
so ur saying u can swap an 06/07 stepper motor into the plastic housing of an 04/05 stepper mktor and install it on ur 04/05 throttle body?
Yes, the motors are interchangeable. The only difference is the sensor and the housing.
TheGeek is offline
post #44 of 44 (permalink) Old 11-12-2012, 12:59 AM
Re: c28
I wish I had come across this thread before I spent about 16 hours troubleshooting my wiring. I knew something was wrong. This bike wouldn't pull over 9k RPM. After digging for days I found a wiring schematic. Found a bunch of bastardized wiring and fixed it (headlight bypassed cause starter button failed and all the lights were Mickey Moused). Then found voltage problem at STVA. Called local Ride Now and they wanted to sell me a whole rack for something like $800. I looked on EBay and couldn't find just an STVA, so I tore it apart and found a burned trace and 2 broken solder joints from plug to PCB and the pcb was cracked. I hard wired it all back together and left a bit of slack in the wiring, took about 5 minutes. Ran down to Ace Hardware and got some 3mm screws and teflon lock nuts. Installed it back on the K5, No more F1 code, It will pull 14k RPM now with no problem, no flat spots in the throttle anymore. I was almost to the point of thinking the problem was that this thing had been rode hard and put away wet one to many times (which is probably the case knowing the previous owner), but it actually runs damn good. Geek, you rock man, I should check the forums before I try to fix any more gremlins in this bike. Would've save me a hell of a lot of time.
durtmvr is offline
