Camera mount - GoPro - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 32 (permalink) Old 02-26-2011, 09:45 PM Thread Starter
IronGSXR35's Avatar
Motorcycle: 04 750
How does everyone mount their GrPro's? Basically looking for pics of the mount and camera itself or similar. I want to get a couple locations set up for this season.
Does the suction cup hold up on its own say handing on the side of the fairing or does it need to be safety wired?
IronGSXR35 is offline
post #2 of 32 (permalink) Old 02-26-2011, 09:49 PM
I'm Kinda Like A Big Deal
Gixxer357's Avatar
Motorcycle: K6 & K8 750
Re: Camera mount - GoPro
I use these http://forums.13x.com/showthread.php?t=270523
Gixxer357 is offline
post #3 of 32 (permalink) Old 02-26-2011, 09:55 PM Thread Starter
IronGSXR35's Avatar
Motorcycle: 04 750
Thats not bad at all, will look into them
post #4 of 32 (permalink) Old 03-05-2011, 07:13 PM
fustyd's Avatar
Sportbike camera mount for sale at www.motodracing.com
Fits over the motorcycle center bolt and attaches iPhone sportbike.
Lightweight sportbike camera mount, very secure.
fustyd is offline
post #5 of 32 (permalink) Old 06-14-2011, 09:36 PM
MOTO-D's Avatar
Motorcycle: 2006 GSXR 750
Nice review above, thanks!
Another shot of the GoPro.........
MOTO-D is offline
post #6 of 32 (permalink) Old 06-15-2011, 05:11 AM
say my name bish
DemonRR's Avatar
Motorcycle: 2007 GSXR 600 track/some street
some mount on the front fender mounting bolts, on the top of the tail section, on the pass pegs, where the mirrors would be when you remove them. top of your lid (but causes head drag and wobble (lol), and on the frame sliders.
DemonRR is offline
post #7 of 32 (permalink) Old 06-15-2011, 07:58 AM Thread Starter
IronGSXR35's Avatar
Motorcycle: 04 750
I have a few locations set up so far, but with the 04 750's tail I haven't quite figured out how to get the right angle. The tail has a curve right down the center and if I mount to either side the angle will be off. Whats the trick with this particular tail? I need to look at it again tonight
post #8 of 32 (permalink) Old 07-04-2011, 08:47 AM
MOTO-D's Avatar
If your looking for a GoPro mount please consider us from MOTO-D
MOTO-D is offline
post #9 of 32 (permalink) Old 07-04-2011, 10:15 AM
Supersport
wuzup76020's Avatar
Motorcycle: 2008 GSXR 600
the suction cup on the bike doesnt seem to work to good. the additional weight of the camera and the wind against it made my fairings "flex" and it was very bumpy looking in the vid. The do stick to helmet very well though. Mine has never came off my helmet(up to 100mph) but you better believe you can feel the drag of it on anything over 60mph
Gave a girl a ride for a group ride i went on and made her wear it.
wuzup76020 is offline
post #10 of 32 (permalink) Old 04-01-2012, 06:30 AM
MOTO-D's Avatar
Contour Camera Mount from MOTO-D
GoPro or Contour Camera Mount from www.MOTODRACING.com
MOTO-D is offline
post #11 of 32 (permalink) Old 04-01-2012, 08:27 AM
I have five of the go pro sticky mounts on mine.
Windscreen
Tail
Both sides of the fairings
Swing arm
And my helmet
Never had an issue. 3m > suction cup
Lean With It is offline
post #12 of 32 (permalink) Old 04-01-2012, 08:38 AM
say my name bish
DemonRR's Avatar
lean, you do you have these on an 06/07 600? if so, on the top of the tail section its curved. did yo mount the gopro mount sideways to compensate for the curve?
DemonRR is offline
post #13 of 32 (permalink) Old 04-01-2012, 09:02 AM
For any section that's curved, sideways, upside-down, you have to compensate when you make the bracket. Like an erector set.
post #14 of 32 (permalink) Old 04-01-2012, 09:11 AM
say my name bish
DemonRR's Avatar
yup, did that and used a couple small hinged pieces to make it work. hope it turns out some nice forward facing bp shots when at the track.
DemonRR is offline
post #15 of 32 (permalink) Old 04-05-2012, 06:56 PM
smittyl31's Avatar
Motorcycle: 06 gsxr 600, 07 gsxr 750 track bike, 96 Honda F3
heres mine... 50$
smittyl31 is offline
post #16 of 32 (permalink) Old 04-05-2012, 08:01 PM
I did mine like this and it worked perfect.
I basically offset the standard mount to the right of the tail section and used this other mount config that came in the box for the camera box and adjusted the angle.
Last Week is offline
post #17 of 32 (permalink) Old 11-06-2012, 04:14 PM
MOTO-D's Avatar
The GoPro has a tripod adapter which simply screws into the mount.
Ever seen a GoPro come hurdling at you down the straight???? - NOT FUN
Rock solid for trackdays and protected behind the screen.
Full tuck no issue.
Available from www.MOTODRACING.com
MOTO-D is offline
post #18 of 32 (permalink) Old 11-06-2012, 04:30 PM
Supersport
wuzup76020's Avatar
For us trackguys the motoD camera mount is a bad idea...we loose the ability to use a front neck stands ( i use one between every session for my warmers). even if you dont use it on the regular you will have to remove it for any fork maintance. I love motoD and use yall's tire warmers but you guys need a model that doesnt go all the way through the stearing stem.
post #19 of 32 (permalink) Old 11-06-2012, 04:50 PM
MOTO-D's Avatar
Thanks Wuzup and this is good info. If you don't use a headlift stand not so much an issue but our mount does secure through the triple so it may not be for every bike or rider.
www.MOTODRACING.com
MOTO-D is offline
post #20 of 32 (permalink) Old 11-14-2012, 10:10 AM
design-engine's Avatar
Motorcycle: 2009 GSXR 600
I ground down my hotbodies and re-fiberglassed a flat spot there for the gopro sticky mount.
design-engine is offline
