2nd gear wheelies - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 40 (permalink) Old 04-11-2006, 04:04 PM Thread Starter
Skyhighsami's Avatar
Motorcycle: 2006 Suzuki GSXR 1000
2nd gear wheelies
I have heard that these bikes are really easy to bring up in second. I can not seem to do it and carry it very far. I do have the suspension set up for more track settings so I am sure that it is stiffer than delievered but what technic is widely used to get the 1000 up in 2nd. The bike is all stock and I am thinking about this week ordering a -1 front sprocket. Not just for wheelies just to have more grunt coming out of the corners.
Skyhighsami is offline
post #2 of 40 (permalink) Old 04-11-2006, 04:08 PM
fatlip's Avatar
Re: 2nd gear wheelies
Get to about 5k and clutch it up.
fatlip is offline
post #3 of 40 (permalink) Old 04-11-2006, 04:14 PM Thread Starter
I tried clutching maybe I didn't do it right but it sounded really violent to me like it was causing alot of damage. I might have been doing it wrong, how would you suggest doing it? When you clutch it up how smooth does it come up?
post #4 of 40 (permalink) Old 04-11-2006, 04:16 PM
On hiatus...
Anthony D's Avatar
i would start with just rolling on the throttle with about 5 grand on the tach. it will come up.
once you get comfortable with that, you will know at what rpm it will get to the balance point. once you know that, you can begin clutching it up.
edit: don't forget to cover the rear brake in case you start to go too far...
Anthony D is offline
post #5 of 40 (permalink) Old 04-11-2006, 04:17 PM
98srad750's Avatar
give it a little bounce
98srad750 is offline
post #6 of 40 (permalink) Old 04-11-2006, 05:04 PM
jdub0204's Avatar
Motorcycle: 04' Blue and White gixxer 1K
bounce it by being around 5k rpm in second gear wack the throttle and make the weight shift to the rear of the bike, then let off of the throttle quikly and compress the front forks, then wack it again and it should come up rather easily, play like that for a while and then u can start practicing clutching the bike up, while in second. On my bike I can just wack the throttle in second gear at about 6-7k rpms and it comes up usually, the only drawback is the fact that u will be running around 70-80 mph. Lower your rear tire pressure to about 25psi this will help u balance the bike better.
Whoa what just happened?
jdub0204 is offline
post #7 of 40 (permalink) Old 04-11-2006, 05:09 PM
jdub0204's Avatar
I have found that clutching the bike up in second is alot smother and you can be running slower mph. Just be running about 45mph or so pull in the clutch tach it up to about 7-8k and dump the clutch, I usually don't get any weird sounds when I do this so I don't know what u are hearing. It can be a little intimidating at first so it takes alot of practice, and remember if you set the bike down hard you will run the risk of popping a front fork seal.
jdub0204 is offline
post #8 of 40 (permalink) Old 04-11-2006, 05:14 PM
loves oldgixxer and Anthony D
JohnyCakes's Avatar
Motorcycle: 2012 Harley Davidson Road Glide Custom 2007 Yamaha Raptor 700R/ AK's, AR's, M4's
This isnt the stunt forum you damn squids!!!! Go and break the law somewhere else you damn delinquents!!
j/k
JohnyCakes is offline
post #9 of 40 (permalink) Old 04-11-2006, 05:27 PM
Supersport
.:1k:.'s Avatar
Motorcycle: 06 1000
j/k
HAHAHAHAH beat me to the punch!
You shouldnt have to clutch 2nd gear, are you sitting/leaning back?
.:1k:. is offline
post #10 of 40 (permalink) Old 04-11-2006, 08:06 PM
If you dont no how to clutch wheelie your gixxer in 2nd gear then dont even try. That front wheel will come up on you so fast, next thing you know, your on your ass wishing you never tried. Its obvious that you need to learn more throttle control before you go clutching that wheel up.
pinoy_what_da is offline
post #11 of 40 (permalink) Old 04-11-2006, 08:09 PM
MichaelGsxr's Avatar
Motorcycle: K5 Gsxr1000
just crack it open at 7000 rpm and keep it open, it takes a second for it to come up... or bounce it a little by rolling on and off the throttle, then cracking it open. she will come straight up no worries mate
MichaelGsxr is offline
post #12 of 40 (permalink) Old 04-11-2006, 08:09 PM
Originally Posted by jdub0204
I have found that clutching the bike up is alot smother and you can be running slower mph. Just be running about 45mph or so pull in the clutch tach it up to about 7-8k and dump the clutch, I usually don't get any weird sounds when I do this so I don't know what u are hearing. It can be a little intimidating at first so it takes alot of practice, and remember if you set the bike down hard you will run the risk of popping a front fork seal.
I dare you to do that on 1st gear??!?!?!
post #13 of 40 (permalink) Old 04-11-2006, 08:34 PM
SLOk6's Avatar
Motorcycle: blue/white k6 1000
just how "hard" is "hard" when you're talking about bringing the bike down and popping fork seals?
The reason I ask is because my bike is having a fork seal replaced right now and suzuki is telling me that they're only going to warranty this one time and suggest that i stop riding wheelies. The only problem is that I've never rode any big wheelies. I mean, its impossible to ride this bike and not bring the front up when you're on it hard, but is coming down from small power wheelies enough to break a fork seal?
SLOk6 is offline
post #14 of 40 (permalink) Old 04-11-2006, 09:18 PM
mikeinnc's Avatar
Motorcycle: 06 k6
From what I hear suzuki can be a bully... Damn yakazumi
mikeinnc is offline
post #15 of 40 (permalink) Old 04-11-2006, 10:58 PM
jdub0204's Avatar
I ride wheelies all of the time in first gear, what are u scared of first gear?
jdub0204 is offline
post #16 of 40 (permalink) Old 04-11-2006, 11:01 PM
jdub0204's Avatar
Hard means getting scared when the bike come up really high and just completely letting of of the throttle and letting the front slam down. Normal small power wheelies shouldn't damage a fork seal.
jdub0204 is offline
post #17 of 40 (permalink) Old 04-11-2006, 11:06 PM
jdub0204's Avatar
j/k
Hey I got a great idea, lets slap a moderator label on your arse and let u go around patroling each thread for squids. And FYI I am not a sqiuid, wheelies are not my thing.
jdub0204 is offline
post #18 of 40 (permalink) Old 04-12-2006, 12:13 AM
Supersport
.:1k:.'s Avatar
Motorcycle: 06 1000
Hey I got a great idea, lets slap a moderator label on your ass and let u go around patroling each thread for squids. And FYI I am not a sqiuid, wheelies are not my thing.
No need to be a thug. He was kidding.
.:1k:. is offline
post #19 of 40 (permalink) Old 04-12-2006, 12:14 AM
I have no problem at all clutching 1st and riding it through. i just dont think its necessary to bring the rpms that high (7k-8k) when using the clutch method for 1st gear. When i said " i dare you to do that on 1st gear" thats going towards people trying to nail the clutch method that have never nailed it before. The person asking about clutching up second gear from what i can tell has never got his front in the air at a decent hight on his preview bike and kept it up in the air. Now why would you even try clutching up a new gixxer 1000? Its a no brainer, you dont learn how to clutch your wheel up on 1000cc bike, thats just nuts and your asking for trouble. Majority of riders on this forum replying to your post giving you advice on how to bring that bitch up w/ the clutch have learned on a smaller bike. yeah your going to learn how to clutch wheelie your bike by reading and all these great advise from riders. It only takes a second or less for that front wheel to come up to balance point, i just hope your brain is ready to execute what you have read within that second.
post #20 of 40 (permalink) Old 04-12-2006, 12:23 AM
Supersport
.:1k:.'s Avatar
Motorcycle: 06 1000
+1
But you dont need to clutch to bring up a 1k, in 3rd and 4th yes.
.:1k:. is offline
