How's my Dyno chart look? - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 36 (permalink) Old 12-18-2012, 06:55 PM Thread Starter
OnThaMove's Avatar
Motorcycle: 2007 GSXR 750
This is my first time getting a dynotune. Bike seems to perform better now. Is this the kind of results I should expect from my mods? Or can I get a better line?
2007 GSXR 750
m4 shorty slipon (motomummy)
Factory Pro Velocity Stacks (motomummy)
K&N Air Filter (street version, not racing filter)
Power Commander 5 (motomummy)
OnThaMove is offline
post #2 of 36 (permalink) Old 12-18-2012, 07:12 PM
hand-eye coordinator
MacBayne's Avatar
Motorcycle: K6-600
Re: How's my Dyno chart look?
it looks like your "tuner" did 3 runs and tuned for max power. you paid $150?
MacBayne is offline
post #3 of 36 (permalink) Old 12-18-2012, 07:26 PM
K6trackday's Avatar
Should have at least flattened that dip between 3-5k rpm
K6trackday is offline
post #4 of 36 (permalink) Old 12-18-2012, 07:28 PM
2007gsxr600's Avatar
Motorcycle: L1 750
What happened to the air/fuel ratio????
2007gsxr600 is offline
post #5 of 36 (permalink) Old 12-18-2012, 07:46 PM Thread Starter
OnThaMove's Avatar
Mac: I paid $200...kinda glad he tuned for max power...I can always change to old map to save gas right?
trackday: I agree about that dip...wtf
2007: not sure what you mean??
post #6 of 36 (permalink) Old 12-18-2012, 07:57 PM
Well, it depends, how much time do you typically spend in the 13-15,000rpm range.
If this is a racebike I would imagine more often, if its a streetbike I'd guess hardly ever right?
SPL170db is offline
post #7 of 36 (permalink) Old 12-18-2012, 08:00 PM
MAD_ARAB's Avatar
Motorcycle: A revamped K6 liter
The last run looks really good for a slip on. What the hell was wrong with the first two runs?
MAD_ARAB is offline
post #8 of 36 (permalink) Old 12-18-2012, 08:15 PM
tas1100g's Avatar
Motorcycle: 1986 GSX-R1100 & 1979 GS 850GN
I'm wondering what exactly was done between the 3 runs to gain over 36 HP.
tas1100g is offline
post #9 of 36 (permalink) Old 12-18-2012, 08:50 PM
Lets go racing!
Chugs's Avatar
+2 where's the afr log?
Chugs is offline
post #10 of 36 (permalink) Old 12-19-2012, 04:42 PM
Blazen244's Avatar
When you received the Power Commander from MM did it come programmed for your mods or no? Why did it need a dyno tune if it's programmed for the bike and mods, not knocking just asking I'm adding a PC-V next month just gathering info and wanting to do it right the first time..
Blazen244 is offline
post #11 of 36 (permalink) Old 12-19-2012, 05:00 PM
Dick/Vagina Embracer
Spook155's Avatar
Motorcycle: 2014 Yamaha FZ-09
It may come programmed with your bike and mods in mind, but every bike performs differently, and therefore a tune is recommended. I don't even have a power command or any air/fuel mapping device, but know that nothing will be perfect even if preset to run with existing mods/bike.
Spook155 is offline
post #12 of 36 (permalink) Old 12-19-2012, 06:13 PM Thread Starter
OnThaMove's Avatar
Uhhh....from what I understand the reason the first two runs are lower is because they were making modifications to the map through the process. and gaining power each time.
hey when you say air/fuel ratio...Im not really sure what you mean? The map? like the fuel table you can see in Power Commander software...? or...?
They also took out the baffler in my M4 slipon....Im gonna put it back in though because it backfires. Is that something they should have "tuned" in the process? the backfire? It doesnt backfire with baffler in
post #13 of 36 (permalink) Old 12-19-2012, 06:37 PM
I am a tater tot; young, not stout. Here is my baby face whoa did a pube just sprout?
Tater Tot Wee Woo's Avatar
Motorcycle: 2007 GSXR 600
baffle won't cause it to backfire or not backfire. It's only there for sound control. If you're popping or backfiring, try plugging the pair valve. You're just getting to much air in the mix and blocking that should prevent it from happening.
Tater Tot Wee Woo is offline
post #14 of 36 (permalink) Old 12-19-2012, 06:49 PM Thread Starter
OnThaMove's Avatar
Word up PeeWee, thats good news to me...but uh...whats a pair valve and how do you plug that bad boy up
cheers
post #15 of 36 (permalink) Old 12-19-2012, 06:50 PM
In order to make modifications to the map they stick a probe into the exhaust to measure the air/fuel ratio in the exhaust gasses. This tells them if the bike is running lean or rich throughout the rev range and different throttle positions.
Usually a dyno printout will include the a/f ratio tracked along a line on the graph as well.
SPL170db is offline
post #16 of 36 (permalink) Old 12-19-2012, 06:52 PM
Rectum Rupticus
coopgt1's Avatar
Motorcycle: 2003 GSXR 750
I'm thinking they were adjusting the dyno to show you the bike was making more HP each run. You bike stock makes better than 96 hp at the rear wheel. I hate to say this but I think they sold you some snake oil . Not to burst your bubble but the mods you have aren't really going to gain you that much HP over stock. You may have realistically gained 3 or 4 hp .
coopgt1 is offline
post #17 of 36 (permalink) Old 12-19-2012, 06:54 PM
cheers
Just do a quick search on the site, you'll find all about it. Lots of threads regarding it. basically just a hose from the air box that is used to add air to the exhaust (i think). All you have to do is locate the hose, disconnect it, and shove something in there like a marble or something that will plug it up, and then put it back together. It's designed to work with the cat, and if you removed that to put on the slip on, it's adding more air than needed, causing the popping.
post #18 of 36 (permalink) Old 12-19-2012, 06:56 PM
Word up PeeWee
dammit
post #19 of 36 (permalink) Old 12-19-2012, 07:02 PM Thread Starter
OnThaMove's Avatar
Pee wee doesnt like how I talk...but uh..alright cool I did remove the cat and I probly know which hose your talking about...ill search for it to be sure
Coopgt...damn that sux...but dude only told me I gained about 6 hp which I thought was kind of high...only expected a few like you said....I really wasnt only looking for hp just wanted that custom map.
post #20 of 36 (permalink) Old 12-19-2012, 07:03 PM Thread Starter
OnThaMove's Avatar
I dont know why they didnt give me air/fuel....this was my first time so I didnt know to ask....live and learn
