bout to panic, please help - Page 2 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #21 of 44 (permalink) Old 12-03-2012, 05:51 PM
He Who Touches Himself
Bagherra's Avatar
Re: bout to panic, please help
dropping the engine is not that hard at all.
you definitely dont want any metal shaving inside the cylinder...
Bagherra is offline
post #22 of 44 (permalink) Old 12-03-2012, 06:10 PM
zvenkruspe's Avatar
How easy does one of the old plugs screw in? That way you know if it's just the new spark plug.
Worst thing I had happen to me unexpectedly on a TL1000: Spark plug broke off the metal part you screw in. Just twisted off and I slowly screwed it in with the wrench, no force required, just like I did with the other one before until I torqued one down.
I never had a spark plug cross threading so far.
zvenkruspe is offline
post #23 of 44 (permalink) Old 12-03-2012, 06:28 PM
Originally Posted by LynnM View Post
You may be able to thread a cleaning tap down the hole. Worth a shot It is possible to put a heli coil in the head too!!
Not on the bike. It will put metal in the cylinder and likely destroy the engine.
Moto_Joe is offline
post #24 of 44 (permalink) Old 12-03-2012, 06:30 PM
Originally Posted by crypta View Post
thanks moto joe, So drop engine is less /complicated/work than just remove head? I would have thought not but by your reply I guess I am wrong. If I drop engine, will I hafta completely seperate rest of bike from engine in order to perform work or can I do it by just lowering engine to floor? This is a major undertaking fo rme and I hate to be doing that kinda invasive work on my baby as I really dont know a whole lot and I'm afraid of something else going wrong in process, but I dont have the income means to just up and take it to shop... I bet thatd be expensive job. What? ballpark 500 bucks?... I dont have that . thi ssucks
Dropping engine is far easier than pulling head. Yes. And the head can't.be pulled engine in the bike anyway (no room) so dropping it then pulling the head is the natural progression regardless
Moto_Joe is offline
post #25 of 44 (permalink) Old 12-03-2012, 06:42 PM
GS220's Avatar
Motorcycle: 06 GSXR 1k, 07 CRF 450r
Originally Posted by MotoMummy View Post
start threading it by hand always.
Yup always.:
GS220 is offline
post #26 of 44 (permalink) Old 12-03-2012, 07:01 PM
Rectum Rupticus
coopgt1's Avatar
Motorcycle: 2003 GSXR 750
Always thread the plugs by hand and I always turn the plug counterclockwise about a turn and a half until I feel the plug drop into the threads correctly .
Op did you try putting one of the old plugs back in ? Could be the new spark plug has bunged up threads to start with .
coopgt1 is offline
post #27 of 44 (permalink) Old 12-03-2012, 07:45 PM
macka's Avatar
Motorcycle: 09 gsxr1000
you dont need to remove anything at this point i would try putting back in one of the original plugs to rule out a odd thread on the new plug, also srart up the engine on the three cylinders give it a good revvv to blow the hole out clean then c if the old plug scews in. if it doesnt go and buy a intermediate tap at trade tool shop just give them the plug to match in might cost 8 or 10 bucks, and buy a bolt and weld it to the tap so you can wind it in a couple of turns thats all you need then just start it up give it a revvv and well its fixed
macka is offline
post #28 of 44 (permalink) Old 12-03-2012, 08:16 PM
Starting the engine with a plug out is a terrible idea. It is just as likely to.suck something in as blow out.
And tapping the threads with the head on is a terrible idea as well. Metal shavings on the motor is not good.
Stop giving shit advice.!
Moto_Joe is offline
post #29 of 44 (permalink) Old 12-03-2012, 08:24 PM
Viking Foreign Affairs Attaché
Minibull's Avatar
Motorcycle: 1998 GSXR 750
Just start it up give it a revvv and well its fixed.
Reading quotes out of context = brilliant
Minibull is offline
post #30 of 44 (permalink) Old 12-03-2012, 08:52 PM
I read everything in context.
Read where he first said start it on three cylinders
Neither of the ways he said to start are good. On three cylinders with a plug out nor after dropping metal shavings from tapping into the cylinder.
Moto_Joe is offline
post #31 of 44 (permalink) Old 12-03-2012, 09:35 PM
Minibull's Avatar
Uhhh......ok?
I had no idea I'd directed anything at you Joe...
Minibull is offline
post #32 of 44 (permalink) Old 12-04-2012, 09:31 AM Thread Starter
crypta's Avatar
Motorcycle: 2008 GSXR 600
yeah i tried putting old plug back in and same issue
crypta is offline
post #33 of 44 (permalink) Old 12-04-2012, 02:53 PM
Rectum Rupticus
coopgt1's Avatar
Although I'm with the others on dropping the engine and removing the head to fix the threads . You can get a Tap and put some axle grease on it so that the tap catches the metal bits . It's not 100 % though in catching everything .
coopgt1 is offline
post #34 of 44 (permalink) Old 12-04-2012, 04:51 PM Thread Starter
crypta's Avatar
what about this? http://www.amazon.com/BikeMaster-Spark-Plug-Hole-Rethreader/dp/B0068FUR1I/ref=sr_1_fkmr2_1?ie=UTF8&qid=1354652610&sr=8-1-fkmr2&keywords=BikeMaster+Spark+Plug+Hole+Re-threader+10mm+%2F+12mm+Thread+Chaser
will this cut new threads thus produce lots of metal shavings or will it just fix the damaged threads, and just folllow the existing threads to bottom? ? I ordered this today and gonna try it. will this work?
crypta is offline
post #35 of 44 (permalink) Old 12-04-2012, 05:07 PM
It is chasing the threads but that involves some cutting. Use at your own risk.
I would not do it on the bike.
Moto_Joe is offline
post #36 of 44 (permalink) Old 12-04-2012, 05:37 PM
tinsnips's Avatar
Motorcycle: 2010 GSXR 600
Inspect the plug for damage or cross threading first. Get a new plug if that one has any signs of cross threading. Use your fingers or the rubber tube. Insert the plug and slowly rotate it backwards listening for the click as the beginning of the thread on plug drops over the beginning of the thread in the head. Gently turn it the right way and see if the thread catches. Be real nice and gentle...if it helps put a tube on other plugs too so you can see the proper angle easier.
tinsnips is offline
post #37 of 44 (permalink) Old 12-04-2012, 06:17 PM Thread Starter
crypta's Avatar
yeah man ive tried. it refuses to go in. the other three went in no problems at all. gonna try the chaser. the very top is what is damaged, it didnt even turn really, just wont thread in true before acting like it wants to cross thread as soon as i start to turn it. and i have tried and tried to find the "sweet spot" its just not there.
crypta is offline
post #38 of 44 (permalink) Old 12-04-2012, 06:18 PM Thread Starter
crypta's Avatar
thanks man
crypta is offline
post #39 of 44 (permalink) Old 12-04-2012, 07:03 PM Thread Starter
crypta's Avatar
thanks man
crypta is offline
post #40 of 44 (permalink) Old 12-04-2012, 10:35 PM
Motorcycle: gsxr k7 1000
I have don this several times on crossed plug threads, grease up the tap with some reel heavy grease and start the tap into the hole 2-3 turns and remove, clean the tap and regrease, continue till yer all the way thru.. worked for me..
Luck.
john kinzell is offline
