Clutch switch, removed? - Page 2 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #21 of 25 (permalink) Old 01-10-2017, 02:24 AM
Likes Diiiiiiiiiiiiiiicks
Re: Clutch switch, removed?
Originally Posted by NZSpokes View Post
Im using a riser clipon and it fouls with the riser part of the bar.
Ive checked the voltage at the relay and it stays at .3v untill the starter switch is hit. Ive changed back to the switch system to see if the fault is still there.
I understand the riser part, but I have never seen a riser clip-on that causes this issue.
post #22 of 25 (permalink) Old 01-10-2017, 03:13 AM Thread Starter
NZSpokes's Avatar
If I could just use the stock switch in the stock place I would. My other bike has the switch so Im used to holding the clutch into start.
NZSpokes is offline
post #23 of 25 (permalink) Old 01-10-2017, 05:55 AM
I used a relay fired by the starter switch.
So one side of the relay is routed to the Y/G wire coming out of the starer button and the other to some ground point? And you're seeing 3.5V on the terminals of the relay even when you're not pushing the button? What ground point are you using?
post #24 of 25 (permalink) Old 01-11-2017, 12:00 AM Thread Starter
NZSpokes's Avatar
No Im seeing .35v. But thats not when it is faulting. Putting the switch back in and the relay out the bike is back to normal. Ground is to the battery.
My think the starter line is the cause. So when I get time I will power the relay from the brake light circuit. Need to pull the tail off and work out which wire it is. This will mean I have to pull the brake on when I start it but thats what I do anyway.
For the next few days I will just ride it.
NZSpokes is offline
post #25 of 25 (permalink) Old 01-16-2017, 01:55 AM Thread Starter
NZSpokes's Avatar
So re-visiting this. Ive set the relay up again. This time fired by the brake light circuit.
Starts fine, will see tomorrow how it rides.
NZSpokes is offline
