So after I got home today I noticed I had a foam on topof my oil, few days ago it was overfilled and sprayed oil in the airbox, well I drained some and it fixed that issue but now I notice this, any suggestions? Not eengine was 135F and I rev it a few times and the foam appears, Its doesnt look white and foamy like blown head gasket though
Okay so both my coolant Reservoir and radiator are the same levels as before. Wouldn't that mean I'm not losing any? Also saw water drip from my exhaust slip on area this morning after I started and Rev a few times to check the oil, doesn't that mean water is getting into cylinders because of a blown gasket? And could that cause coolant in oil? In traffic headed to auto zone for compression test, I'd if I could a leak down requires me to remove head and get to cylinders... never done before. This bike had 3.5k miles when I got it and now has 6 5k and has been a huge hassle....
No, you can't tell by the levels. It would have to be a huge leak for it to show up there.
Do those tests yourself. Get a factory service manual and the testers, and go from there. You can get the test equipment from Pep Boys or AutoZone or any parts store.
Mind If I could get some help on what tools and adapter I need. Went to Autozone, Advanced, and Pep boys and all 3 said they don't have that and didn't know what I was talking about...
