Hey guys!
Question 1)
So last night I finally got a marble to plug my pair valve, but while I was removing the air box I saw liquid specs and coat on top of the airbox. I open it up and on top of the airbox by the throttle bodies is gas residue,
there is also residue on the throttle body ports but only 2-4
I have read this could be caused by too much oil? I just changed the oil 2 days ago, I put in 3 full quarts of Mobil 1 4T 10w-40 oil, normally I only put about 2.6 - 2.8 but It drained for like 4 days so i figured Id add some more, the oil is also already black and is a little above the Full line.
Question 2)
So after noticing all of question 1 I inspected my fuel injectors and noticed one of the top first injectors had gas residue. It happens to be the one with no gas residue in the port.
Could the seal go bad? or what different things could cause this?
Question 3) So my throttle body butterflys are looking different and idk if this is normal wear or whats going on, you will see like rectangle lines on them that is a different shade of material, ill post a picture of them,
Question 4) (Last one sorry)
Iv been having random lose of power when at cruising rpms and speeds, the power just kicks off even though throttle hand stays the same then bam just kicks back in random, now this doesnt effect me to much i always ride 10k above normally but when im not its very frustrating and almost through me off bike other day because it happened over a bump.
I have read O2 sensor, and also set-valve which I have both on my bike, by removing both of these should fix the problem or should i be looking at something different?
Cheers! Jay
photo links in one: Imgur: The most awesome images on the Internet
Question 1)
Question 2)
Cheers! Jay
