So I swapped a decat for my bike and it started. The RPM build up is super fast at idle and the bike runs fine at cruising speeds but immediately after I twist the throttle to full it bogs and does not gain speed. Could my machine be running lean when I open it to full throttle? It also has a yoshimura GP evo2 exhaust and a stock air filter. Can a decat cause the bike to run too lean? 02 and pair valve disabled also.
Ok, so I fitted a AFR meter to my exhaust and it showed reading from 16.6 to even 20 afr when accelerating to full throttle. My bike runs leans so I quess its dyno time!
There is one thing I can't wrap my head around. I should richen the mixture in the 6th gear and rpms over 6000rpm. If I richen the mixture in that rpm range, does this affect the lower gears as well if I drive slower but with a smaller gear in that rpm-range?
