Frozen valve? - Suzuki GSX-R Motorcycle Forums Gixxer.com
  • 1 Post By Just_Nick
post #1 of 5 (permalink) Old 01-06-2017, 05:05 AM Thread Starter
springfall2008's Avatar
Motorcycle: 2014 GSXR1000
Frozen valve?
It was around -3 degree Celsius yesterday morning but I had to use the bike as the car was in the garage. I took it out of the garage and turn the ignition to on and it came up with the red FI light right away (I hadn't even started it at that point). I tried turning it on and off again but the fault was still there (solid light not blinking). I rode it to work just fine and the fault was there when I rode home (it was around 0 degrees when I left work). When I stopped for fuel and started the bike again the fault was gone, and it's not come back this morning either (it's above zero now).
Just wondering, could it be that valve in the exhaust frozen in place perhaps (is that SET or PAIR I forget)?
Anyhow, I ordered a deal mode switch from eBay thinking if it comes back I can check the fault code at least.
Has anyone else had problems in cold weather?
springfall2008 is offline
post #2 of 5 (permalink) Old 01-06-2017, 08:51 AM
It's the SET and it does sound like the most likely suspect (on grounds of being cycled pre-start, so that the fault can be identified and that its position and cable drive attracts muck, which can be frozen solid. Another possibility is the STVA, but that's gear-driven on most systems and therefore presumably less sensitive to frost.)
post #3 of 5 (permalink) Old 01-06-2017, 11:04 AM Thread Starter
Re: Frozen valve?
Should the mechanism be lubricated, I wondered as the heat of the exhaust is likely to burn it off?
post #4 of 5 (permalink) Old 01-06-2017, 11:42 AM
I have no direct experience with a SET valve, as my K4 doesn't have one, nor have I had much occasion to investigate it, for the same reason. I would guess that the throttle valve itself, will be mounted on sealed bearings and require cleaning at most, as far as periodic maintenance is concerned.
Any grease, assuming it will survive the heat, would likely serve as glue for carbon particles to accumulate and be baked solid, so I'd avoid it unless suggested by the manual. Keeping the exhaust stream clean by avoiding modifications that affect the AFR, or remapping after any such modifications might also help.
As I said, I'm just guessing; others with more experience will hopefully know more and if not, go with the manual. (The latter should perhaps take precedence, depending on your outlook on things.)
post #5 of 5 (permalink) Old 01-06-2017, 03:35 PM
Likes Diiiiiiiiiiiiiiicks
Re: Frozen valve?
It's more likely that the cables are binding or the mechanism doesn't like the temperature than it is the valve itself is stuck. You can always try removing the cables and move the valve by hand to note any binding, though.
springfall2008 likes this.
Just_Nick is online now
