Boredz V49 - Canucks optional :P - Page 171 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #3401 of 9999 (permalink) Old 11-13-2012, 11:38 PM
Goobersbro's Avatar
Motorcycle: 07 GSX-R 600
Re: Boredz V49 - Canucks optional :P
Originally Posted by 1/4milecrazy View Post
IIRC you are 230# and on stock springs running A pace??
You are more than likely hitting the hydraulic bottom of the forks.
Well when you put it that way it makes me sound like an idiot
Yes 230 nakeed so well over 250 geared up and yea running slow A pace suspension is top on my list
So for the front I am going to re spring and re valve any suggestions here guys? Hoping to put together a wish list for Christmas. I am thinking race tech
As for the rear shock I need to have it freshened up but should I also buy a new coil for it? Or is the rear okay? Also it is possible to have the rear freshened up correct?
|^^^^^^^^^^^^^| |___
|. SUZUKI RACING.---| ||'|";,__.
|_..._...___________| ||_|_|...,]
Goobersbro is offline
post #3402 of 9999 (permalink) Old 11-13-2012, 11:47 PM
AKA Pee Wee Herman
1/4milecrazy's Avatar
I have Ohlins 20mm FPK with 1.05 springs, 7 weight oil, I dont remember the oil level off hand, and GP fork extenders up front.
In the rear I have a 600 or 650 pound spring, on a stock shock revalved with a Racetech valve kit.
I love the way the bike feels, I am almost identical to you in weight and pace.
I would avoid fucking with the stock shock, the price to service or modify is just not justifiable compared to an after market shock which would be better anyway. I only did it because I only had to pay for parts.
Rich
CCS AM #795
T 1:35.38/L 1:14.06
Originally Posted by GixxerVixxen View Post
Mine might be an innie, but I promise you you don't want to get into a dick measuring contest with me, son. I'll win.
1/4milecrazy is offline
post #3403 of 9999 (permalink) Old 11-13-2012, 11:53 PM
Goobersbro's Avatar
K thanks so for the rear just look into going aftermarket?
What's the difference between the 20mm and 30mm valve kits?
I will ask the suspension shop all these questions but I don't want to get Bs'd
As for the springs how do you find out what size? Race tech had a calculator and I think it recommended .995s but stock are .900 I think I should do the next one up from .995
post #3404 of 9999 (permalink) Old 11-13-2012, 11:55 PM
AKA Pee Wee Herman
Oh and I have 5.5mm shims under the rear shock clevice.
Running 190/60 GPA rear with a 120/70 front
post #3405 of 9999 (permalink) Old 11-13-2012, 11:58 PM
Goobersbro's Avatar
What's the purpose of shimming the rear and buying the fork tube cap extensions to raise the front?
post #3406 of 9999 (permalink) Old 11-13-2012, 11:59 PM
AKA Pee Wee Herman
Yeah, I wouldnt bother with the stock shock.
I think to duplicate my rear shock would cost around $500.
I would also look into going a little stiffer with the fork springs, but that is just my opinion.
Price is one HUGE difference between the 20mm kit and the 30mm kit, the 20mm kit is just the valves themselves that have to be installed in the existing cartridges, the 30mm kit is full carts.
post #3407 of 9999 (permalink) Old 11-14-2012, 12:01 AM
AKA Pee Wee Herman
Raise the whole bike. Raising the rear increases swing arm angle, raising the front restores rake and trail after raising the rear. There is a LOT more to it than that though. Its all chassis geometry, its not easy but it makes a huge difference in the handling of the bike.
post #3408 of 9999 (permalink) Old 11-14-2012, 12:05 AM
Goobersbro's Avatar
Ah this makes sense being as how you can buy 20mm valves for like 120 and the 30mm is always the cartridge kit for 1200
Any difference between the ohlins and race tech with just springs and valves that you know of? They are about the same price
post #3409 of 9999 (permalink) Old 11-14-2012, 12:05 AM
Goobersbro's Avatar
Ah makes sense this will wait till further down the road lol
post #3410 of 9999 (permalink) Old 11-14-2012, 12:08 AM
AKA Pee Wee Herman
Here read these:
Suspension height question
Running Wide
post #3411 of 9999 (permalink) Old 11-14-2012, 12:27 AM
Boredz Crackhead
Mr. Fluffer's Avatar
Motorcycle: K9 600
I have to be up in 5 hrs. FML.
Sent from my iPhone using Motorcycle.com App
Mr. Fluffer is offline
post #3412 of 9999 (permalink) Old 11-14-2012, 12:29 AM
AKA Pee Wee Herman
You should probably be sleeping
post #3413 of 9999 (permalink) Old 11-14-2012, 12:39 AM
Boredz Crackhead
Motorcycle: K9 600
Yeah, probably.
post #3414 of 9999 (permalink) Old 11-14-2012, 12:41 AM
Sphincter Pincher
93goatfucker04's Avatar
Motorcycle: 04 GSX-R 600
sleep\\\
passinng out
93goatfucker04 is offline
post #3415 of 9999 (permalink) Old 11-14-2012, 08:13 AM
Question....WHen under hard braking how close to bottoming out should the shocks come? I had a weird incedent yesterday and after watching video I think what may have happend is I bottomed out the suspension on the front. Unfortanately the lap I had the incedent on I was recording from a different angle.
Anyways on almost every lap I was withink 3/4s of an inch from bottoming out if not less.
When you bottom out, the rear farily suddenly gets light and wants to come around. It can also cause the front to tuck on the brakes. 3/4 from bottom doesnt sound like bottom though on stock stuff. Not unless you have added way more oil to it and are hydraulic bottom
FWIW true bottom is seal against casting on our bikes.
If you cant afford cartridges like 25mm or 30mm then a revalve is sufficient. I ran them for a long time
for the rear shock either just go spring, or a full new JRi shock
YOu need at least a set of 1.0 spring, if not a 1.0 and a 1.5 IMO up front
I prefer GP suspensions 20mm kits
They are all similar though
:SFH : SBS : VHS :
WERA Expert #20
Moto_Joe is offline
post #3416 of 9999 (permalink) Old 11-14-2012, 08:18 AM
Goobersbro's Avatar
Sweet thanks for all the insight and links. This is about to get a little more expensive it looks like
post #3417 of 9999 (permalink) Old 11-14-2012, 08:59 AM
You have no idea .
I always get a little sad when a new rider talks about how expensive track days are.
You want to see expensive? Try getting fast
Moto_Joe is offline
post #3418 of 9999 (permalink) Old 11-14-2012, 09:00 AM
Managing MotoJoe
punkadilly's Avatar
Motorcycle: Crew Chief & #1 fan of WERA #20
getting fast & racing
Welcome to the wonderful world of budgeting peeps.
punkadilly is offline
post #3419 of 9999 (permalink) Old 11-14-2012, 09:23 AM
Goobersbro's Avatar
You have no idea .
Lol seems like every second you knock off lap times you should add like 20 dollars
post #3420 of 9999 (permalink) Old 11-14-2012, 09:25 AM
Managing MotoJoe
punkadilly's Avatar
$200 is more like it ... and that might be low
Closed Thread
