03 gsxr 600 alstare - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 6 (permalink) Old 06-12-2011, 05:48 PM Thread Starter
03 gsxr 600 alstare
i have recently bought a wrecked 03 gsxr 600 alstare i have everything working but the fuel pump i bought a "working" fuel pump off ebay and i have hooked it up and i have not fuel pressure i un pulged the pump and check the electrical current at the plug for the ecu and i am getting 12.85 volts but i hard wire the y/r and b/w wire and i get nothing should i hear it spool up or anything? might i have been sold a faulty pump or am i doing something WRONG?
i would appreciate help i geel dumb founded right now
camarolover98 is offline
post #2 of 6 (permalink) Old 06-12-2011, 06:10 PM
Rectum Rupticus
coopgt1's Avatar
Motorcycle: 2003 GSXR 750
Re: 03 gsxr 600 alstare
Did you check the clutch and side stand safety switches ? Are you in neutral ?
coopgt1 is offline
post #3 of 6 (permalink) Old 06-12-2011, 06:32 PM Thread Starter
yeah every thing is in working order clutch is pulled kickstand side switch is functioning and in neutral starter will tun engine is turn over but no gas flow i have it disconected from the fuel rail i have power to the fuel pump harness but i cant even get the fuel pump to spool up when i hot wire it :/
post #4 of 6 (permalink) Old 06-13-2011, 01:18 AM
Lets go racing!
Chugs's Avatar
check tip over sensor?
Chugs is offline
post #5 of 6 (permalink) Old 06-13-2011, 04:53 AM Thread Starter
i did that as well i had a check engine F1 light and put it into dealer mode and i had it upside down once i took care oif that the pump still not working i have checked fuses every thing possible that i could think of
should i just go out and buy another fuel pump?
post #6 of 6 (permalink) Old 06-13-2011, 06:13 PM
Rectum Rupticus
coopgt1's Avatar
Dumb question time . Do the GSXR's have a fuel pump relay ? If they do you may want to check that also .
coopgt1 is offline
