K6 v K7 weight - Suzuki GSX-R Motorcycle Forums Gixxer.com
 9Likes
post #1 of 56 (permalink) Old 07-08-2016, 09:41 AM Thread Starter
Motorcycle: K8 GSXR 1000
K6 v K7 weight
Hi. Has anyone on here ever actually put the CAT on a set of scales ? Just curious as to the main bulk of weight difference between 06&07.
Stevieramone is offline
post #2 of 56 (permalink) Old 07-08-2016, 10:55 AM
Pipe-laying Admin...
Anthony D's Avatar
Re: K6 v K7 weight
The K6 is lighter, especially since the K7 has a dual exhaust.
Anthony D is offline
post #3 of 56 (permalink) Old 07-08-2016, 11:00 AM
Likes Diiiiiiiiiiiiiiicks
Re: K6 v K7 weight
Did you do a search on exhausts and K7/K8 weight reduction? There are a number of threads on this very subject. Hope this helps
Just_Nick is online now
post #4 of 56 (permalink) Old 07-08-2016, 11:14 AM Thread Starter
Re: K6 v K7 weight
I know the k6 is lighter. I've owned both models. I've searched various threads but no-one has actually put just the CAT on scales. I'm just curious as my K7 came without the CAT and I wondered what the weight was. People have guessed it's weight at around 20lbs on some threads.
I don't think my K6 felt any lighter than my K7 without CAT. I think the twin pipes make the K7 look heavier ( if that makes sense )
post #5 of 56 (permalink) Old 07-08-2016, 12:08 PM
Re: K6 v K7 weight
There are some for sale on eBay, why not ask them how much it weighs?
I've seen 20 pound reductions for Taylor-made exhaust swaps (mufflers replaced and cat removed), but not 20 pounds for the catalytic converter alone.
Stevieramone likes this.
post #6 of 56 (permalink) Old 07-08-2016, 03:41 PM Thread Starter
Re: K6 v K7 weight
Haha. I might try my luck asking an eBay seller.
post #7 of 56 (permalink) Old 07-14-2016, 07:57 AM
Motorcycle: GSXR 1000 K6 & K8
Re: K6 v K7 weight
The CAT box weighs 3.75kg on it's own - I just measured it.
King Kenny is offline
post #8 of 56 (permalink) Old 07-14-2016, 08:22 AM
Giorgio_Rp's Avatar
Motorcycle: black GSX-R 1000 K6
Re: K6 v K7 weight
wow,that's a lot!!!
wet weight in stock form
K5/6 :200,5 Kg
K7/8: 212 Kg
Giorgio_Rp is offline
post #9 of 56 (permalink) Old 07-16-2016, 05:22 PM Thread Starter
Re: K6 v K7 weight
Thanks.
post #10 of 56 (permalink) Old 07-16-2016, 05:25 PM Thread Starter
Re: K6 v K7 weight
Is it just an illusion that the k7/8 feel so much heavier than k5/6 then? With the cat removed there's not much between them. Not sure if the twin outlets or bodywork just make the bike look fat.
post #11 of 56 (permalink) Old 07-16-2016, 06:24 PM
Re: K6 v K7 weight
Depends on the tires, the suspension, where the extra weight is located, if the rake is the same, etc.
post #12 of 56 (permalink) Old 07-26-2016, 08:20 PM
Motorcycle: 2007 GSXR 1000
Re: K6 v K7 weight
With the cat, exhaust valve cables and crap, it's about 10 pounds all told. The factory mufflers don't have much in them, no packing, just a couple baffles and a bit of pipe. They are lighter than they look but, obviously, all told, they'll weigh more than a single system, most likely. The K7 is still about a 450 pound bike with some fluids in so, it isn't svelte. The K6 is not really significantly lighter than this.
Ken7-1000 is offline
post #13 of 56 (permalink) Old 07-27-2016, 04:35 AM
Anthony D's Avatar
Re: K6 v K7 weight
The K6 1000 weighs 435# full of fluids. I would say 15# is pretty significant.
post #14 of 56 (permalink) Old 07-27-2016, 07:07 AM Thread Starter
Re: K6 v K7 weight
When reading the suzuki launch details for the k7 it seems that grams were shaved off bits and pieces so where does the excess weight come from. Is it only from cat and emissions junk?
post #15 of 56 (permalink) Old 07-27-2016, 07:42 AM
Anthony D's Avatar
Re: K6 v K7 weight
Here are more accurate specs...
2006 Suzuki GSX-R1000 wet weight - 435#
2007 Suzuki GSX-R1000 wet weight - 466#
That is a 31# difference...
post #16 of 56 (permalink) Old 07-28-2016, 11:34 AM Thread Starter
Re: K6 v K7 weight
That's a big jump in weight. Surely emissions can't count for all that?
post #17 of 56 (permalink) Old 07-28-2016, 12:04 PM
Anthony D's Avatar
Re: K6 v K7 weight
No, I think the bike in general gained weight.
post #18 of 56 (permalink) Old 07-28-2016, 12:16 PM
Re: K6 v K7 weight
^Other differences that may add weight: ISC, larger radiator, electronic steering damper, hydraulic clutch, 10 button rotors, projector high beam, protective cover on front of gas tank.
The service manual weights are K5/K6: 365 lb, K7/K8:379 lb. As I understand it, these weights are measured in a funny fashion, i.e. all "consumables" are removed. That means no gas, oil, coolant, brake fluid, or (I think) even brake pads. Not sure about fork fluid. But strangely the tires remain. So the weight values are a bit silly. But the weight difference ought to be meaningful.
post #19 of 56 (permalink) Old 07-28-2016, 01:07 PM
-JK750-'s Avatar
Motorcycle: K5 1000
Re: K6 v K7 weight
Originally Posted by BillV View Post
larger radiator
Do you know how much bigger is the K7 rad? I'm curious because I'm going to use K7 rad on my K5 1000 project.
-JK750- is online now
post #20 of 56 (permalink) Old 07-28-2016, 03:02 PM
Giorgio_Rp's Avatar
Re: K6 v K7 weight
As I was reading this I was sure that you wouldn't have mentioned the heavier projector type headlight but you proved me wrong. You don't mess with @BillV when it comes to specs...
