Piston ring re-use - Suzuki GSX-R Motorcycle Forums Gixxer.com
 4Likes
  • 1 Post By TheGeek
  • 1 Post By Just_Nick
  • 1 Post By beeboy
  • 1 Post By Teufel
post #1 of 7 (permalink) Old 03-18-2017, 03:22 PM Thread Starter
Motorcycle: SRAD 725. K1/K5/K7 hybrid project
Piston ring re-use
Hi All.
If I remove a damaged piston from a 1000 engine can I re-use the rings on a new piston (providing the tolerances etc are ok)? I ask because I read that due to the Nikasil bore it would be difficult to get new rings to seat properly. The crosshatching is clearly visible on the cylinder in question hence wondering if it would be better to use the rings that were in the engine. The piston was damaged to to valve contact.
Cheers,
Alan
AlanRush10 is offline
post #2 of 7 (permalink) Old 03-18-2017, 07:34 PM
Stupid. Who's with me?
TheGeek's Avatar
Re: Piston ring re-use
If you're that far into it, new rings all the way around.
Carnage likes this.
TheGeek is offline
post #3 of 7 (permalink) Old 03-19-2017, 04:39 AM Thread Starter
Ill do all 4. Was concerned about new ones sealing.
Cheers
Alan
post #4 of 7 (permalink) Old 03-22-2017, 12:06 PM
Likes Diiiiiiiiiiiiiiicks
Cheers
Alan
Technically you should hone all four bores and use new rings, but you can always just try to get away with new rings
AlanRush10 likes this.
post #5 of 7 (permalink) Old 03-22-2017, 03:35 PM
Motorcycle: b m
You better do some checking around before you hone cylinders. Better off installing new rings without the hone unless you got the right hone and the knowhow. The chrome type cylinder coatings can be very thin and if you f*ck em its all over.
Rings can get brittle with age. Not sure it would be a good idea to reuse. I'd be worried about a broken ring down the road if they survived the reinstall.
beeboy is offline
post #6 of 7 (permalink) Old 03-23-2017, 08:19 PM
Motorcycle: 06 GSXR 1000, GSX 1400, TS 185
I did exactly what you are talking about after piston had too much slap and badly damaged crown from hitting the valves.
I used all the same parts (rings/oil rings etc), replacing only the piston.
My bike makes 190 on the dyno and I have done about 20-25 track days since then without a problem.
Good Luck.
Teufel is offline
post #7 of 7 (permalink) Old 03-26-2017, 07:33 AM
Motorcycle: 1999 GSX-R 600
I did a rebuild of my motor 2 years ago, measured the rings they were within specs, so put it all back together, it chugged oil like a Russian chugs vodka... so took it all apart again and replaced the rings.
so if you ask me I would replace all rings now.
mortenmorfar is offline
