Modding Christie Automotive's TRE mod - Suzuki GSX-R Motorcycle Forums Gixxer.com
 10Likes
post #1 of 49 (permalink) Old 09-09-2016, 02:13 PM Thread Starter
Motorcycle: GSXR 1000 k2
I've got this used TRE for cheap off ebay. The label on it fallen off at some point, but I know it was made by UK company Christie Automotive and is one of the "intelligent" ones that detect the neutral gear selection. I decided to make a small DIY project for my GSXR 1000 k2 and convert that TRE to a switchable one via DPDT switch. The principle is simple this switch has two positions - two separate routes of conducting, thus is always ON. First route will bypass the TRE mod when it is hooked up to my wiring loom, to achieve a "factory" mode, when the switch is flicked to the second position the route will lead through the TRE "black box" and timing retardation eliminator mod will be engaged.
That is the simple part, but before I splice and cut the TRE cables, can anyone tell by looking at this picture I made (see attachment), which of the two connectors is on the ECU side of the wiring ? That is quite important for properly routing the DPDT switch. You can also see the 3D printed housing that I will maybe paint to put on my handlebar and the waterproof switch beside it.
ShephardReborn is offline
post #2 of 49 (permalink) Old 09-09-2016, 03:29 PM
Re: Modding Christie Automotive's TRE mod
Uggh TRE was so 2004
post #3 of 49 (permalink) Old 09-09-2016, 04:00 PM Thread Starter
Wink Re: Modding Christie Automotive's TRE mod
I am making my 02 "period accurate". So far, I installed Yoshimura TRS slip-on, Japanese imperial flag brake reservoir cover and now planning to put in the TRE mod. To complete the image I shall also only ride in T-shirt and sunglasses, flip-flops whilst showing middle finger to all the people I overtake. Also rev the bike for no apparent reason at each traffic lights and especially in tunnels.
SWEET GSXR BROO!
post #4 of 49 (permalink) Old 09-09-2016, 07:18 PM
Yeah. But you still bought a TRE
post #5 of 49 (permalink) Old 09-09-2016, 07:30 PM
Samantha750's Avatar
And turbo's are soooo '80's
Today is all about NOS or haven't you seen "The Fast and Furious"?
I too have a TRE so come at me brah
Samantha750 is offline
post #6 of 49 (permalink) Old 09-09-2016, 07:53 PM Thread Starter
Cool Re: Modding Christie Automotive's TRE mod
Yeah, it costed virtually nothing. And I am curious what's the fuss about the TRE.
post #7 of 49 (permalink) Old 09-09-2016, 07:57 PM
I bought my TRE to cut down on the engine braking and it has.
post #8 of 49 (permalink) Old 09-10-2016, 05:28 AM
Eliminate the TRE through the ECU. With how little this costs to do,along with the added benefit of changing several other "locked" parameters it's a no brainer.
Of course,now that I went and opened my mouth,I can't find which company flashes the K1/2 1K. I know there is at least one.
Maybe @-JK750- can chime in here?
post #9 of 49 (permalink) Old 09-10-2016, 08:23 AM
-JK750-'s Avatar
Motorcycle: K5 1000
^I don't know about these older ECUs. Mr Hollywood might know the answer...
-JK750- is offline
post #10 of 49 (permalink) Old 09-10-2016, 10:25 AM Thread Starter
Nobody actually answered my original question...
post #11 of 49 (permalink) Old 09-10-2016, 10:41 AM
-JK750-'s Avatar
Motorcycle: K5 1000
Here's a pic of a sensor.
-JK750- is offline
post #12 of 49 (permalink) Old 09-10-2016, 10:47 AM
Likes Diiiiiiiiiiiiiiicks
You couldn't just pull up a service manual or look in your bike?
post #13 of 49 (permalink) Old 09-10-2016, 10:54 AM
SSGSXR's Avatar
Motorcycle: GSX-R1000 K2
Look in here...
TRE
SSGSXR is offline
post #14 of 49 (permalink) Old 09-10-2016, 11:18 AM Thread Starter
Thanks. That is exactly what I needed
post #15 of 49 (permalink) Old 09-10-2016, 08:03 PM
Motorcycle: K1 1000, K7 750
The TR is gone over about 50% throttle. Trust productsville to screw up Suzuki engineers good work.
A TRE for a top speed limiter may be a requirement in some situations. You could use a switch to change the GPS from 6th to 5th if you are going to try and exceed 186mph.
Or try and find someone to flash the ECM as oldgixxer mentioned.
kwaka10r is offline
post #16 of 49 (permalink) Old 09-11-2016, 02:12 PM
HeJason's Avatar
Motorcycle: 02 GSXR turbo 1k, 02 GSXR 1070, 86 GSXR 750 (92 1216 motor), 89 FZR 1000 (1070 motor), 94 GSXR 750 (95 1146 motor), BigBore 00 Busa
I havent been able to find anyone to flash a 01/02 ECU yet, commercially at least.
HeJason is offline
post #17 of 49 (permalink) Old 09-11-2016, 10:13 PM
SSGSXR's Avatar
Cost my less than $5 to make and install one myself (switch, 6800 Ohm resistor and 4 short lengths of wire)
On my K2 1K which I ride 95% of the time on street, its makes a very noticeable difference and you spend "Alot" more time feathering the throttle in the 0% to 50% range on the street......
With the switch I have compared it numerous times On and Off and it was well worth my $5 investment...
If you haven't done it, your missing out...
SSGSXR is offline
post #18 of 49 (permalink) Old 09-12-2016, 08:42 AM
Time and time again, people just don't get it.
Let me put it another way.
Marc Marquez, Valentino Rossi, Jorge Lorenzo, Danni Pedrosa and all the other MotoGP riders have timing retard and other schemes to manage the power of a MotoGP bike in the lower gears.
But it seems many people on gixxer.com and elsewhere think they are better riders than the world's elite MotoGP riders and also know better than the engineers that help those riders go around race tracks and set lap records.
oldgixxer likes this.
kwaka10r is offline
post #19 of 49 (permalink) Old 09-12-2016, 09:20 AM
Well said.
Kwaka,do you remember the "wheelie wire" mod on the old oil-cooled and WC 1100's?
post #20 of 49 (permalink) Old 09-12-2016, 06:28 PM
Well said.
Was that the "pink wire" mod OG?
I thought it was the same as the timing retard on the later GSX-Rs. Was it something else?
kwaka10r is offline
