CHEC Message is on and Fuel pump won't prime - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 2 (permalink) Old 06-18-2017, 10:09 AM Thread Starter
Hey guys,
I just put all new fairings on my 2002 gsxr 600 and while I had it apart I synced the throttle bodies. When I put it all back together, I noticed I have the Chec message coming up where the temp usually goes. I took the bike down the road and i think the chec disappeared but the red light might have stayed on. I notice that when i turn the key and or flip the kill switch to on.. the fuel pump is not priming... any idea where to start or what to check to start ruling things out and try and get this error message to go away?? Electrical is not really my forte. Thanks in advance.
I also think the oil message popped up, but the oil was changed recently and the oil level is good. I double checked. I can't remember if it turns off when I turned the bike on or not.
Thanks!!
burudma10 is offline
post #2 of 2 (permalink) Old 06-18-2017, 12:19 PM
Re: CHEC Message is on and Fuel pump won't prime
I'm confused. You seem to suggest, that the bike starts, despite the CHEC and the absence of priming. Is that the case? If not, search the forum for words like CHEC, interlock, priming, etc. There are a lot of detailed threads on such issues. Start troubleshooting, by checking the fuses and going over all electrical connectors, making sure they're as they should be.
dpapavas is online now
