switched hot wire for phone charger on a K5 1000? - Suzuki GSX-R Motorcycle Forums Gixxer.com
  • 1 Post By Geesxara
post #1 of 17 (permalink) Old 04-20-2017, 07:48 PM Thread Starter
Drill baby, DRILL!!!
Todd_Sails's Avatar
Motorcycle: '05 GSX-R1000
Hey all,
Yes I did a quick search- I guess I didn't use the right key words
Like the title states, I'm installing a Ram style mount in my steering stem, that also has a usb port on it - that I would like to make a 'switched' lead.
I know it's been done.
If you've done this on a K5/K6, etc.
I'm thinking/hoping people such as Bill V The Encyclopedia, or others will chime in and suggest some of the best places to mount it to a switched lead- the easiest/least obtrusive.
The wire with the plug should reach bakc onder the tank to the battery;
But I'd like to use something near the front end/front of the tank and splice it in, and re-do the quick release plug on the wire- that's near the far end- I'll solder and repsplice it near the mount for when I take it off, etc.
Help a brutha out here...
K5 R1000
Yoshi Carbon exhaust
TRE mod
Todd_Sails is offline
post #2 of 17 (permalink) Old 04-20-2017, 07:56 PM
Geesxara's Avatar
Motorcycle: 06 GSXR1000
Re: switched hot wire for phone charger on a K5 1000?
Originally Posted by Todd_Sails View Post
Hey all,
One wire off the horn wire is a switched 12V and 10 amp fuse protected. Also located near the front, just splice it.
Todd_Sails likes this.
Geesxara is offline
post #3 of 17 (permalink) Old 04-20-2017, 08:06 PM Thread Starter
Todd_Sails's Avatar
BINGO!
Great idea!
I'm thinking that will work fine, thanks
post #4 of 17 (permalink) Old 04-20-2017, 08:08 PM
Drunk Again
tatersalad314's Avatar
Motorcycle: L5 600, '15 Victory Vegas 8-Ball
I'd use a connector like this https://www.posi-products.com/posiplug.html
tatersalad314 is offline
post #5 of 17 (permalink) Old 04-20-2017, 08:29 PM
Likes Diiiiiiiiiiiiiiicks
I would run a wire directly from the battery and use a relay that is triggered from a 12v ignition wire, such as the horn. That way you're not putting extra stress on the small wires in the harness, but it still only comes on when you turn on the ignition.
post #6 of 17 (permalink) Old 04-20-2017, 08:38 PM Thread Starter
Todd_Sails's Avatar
Those look nice, but it doesn't look like it will go on a wire thats already hooked to something.
Sounds good, not really sure what exactly you mean here though. If it's run off the battery, I'd have to use a ground that was only active with the key on?
Bill V? Any input?
post #7 of 17 (permalink) Old 04-20-2017, 08:52 PM
1Slowrider's Avatar
Motorcycle: SRAD
If you only want Billv's input on where to hack into your harness.....Pm him, and hold your breath. Lol
He's not into rigging as far as I have read.
1Slowrider is online now
post #8 of 17 (permalink) Old 04-20-2017, 08:55 PM
Drunk Again
Ah, but they do!
post #9 of 17 (permalink) Old 04-20-2017, 09:07 PM
maniac1886's Avatar
When I used to install aftermarket electronics in cars, the install bay showed me a great way for splicing wires. You remove about 1/4 in of the rubber coating around the wire. It's best done with a razor blade. Be careful to only remove the jacket and not cut any of the individual wires. Put the razor blade in the center of the wire and rotate it a bit to open up the center of the wire. It should create an "eye" similar in shape to the eye of a needle. Take the wire you plan to add to the harness, run it through the whole, then pinch the hole closed over the wire, and rap the newly added wire to the closed up eye. If that makes sense. This way, you never actually sever the original wire, and it's much much stronger than twist the wires, twist caps, and IMO, soldering.
maniac1886 is online now
post #10 of 17 (permalink) Old 04-20-2017, 09:10 PM
Drunk Again
That's how I like to do it. I only recently discovered the positap connectors when installing Rapid Bike and it came with this specific connector. Changed my life forever
post #11 of 17 (permalink) Old 04-20-2017, 09:13 PM
Bill V? Any input?
RELAY BASICS
post #12 of 17 (permalink) Old 04-21-2017, 06:33 AM Thread Starter
Todd_Sails's Avatar
Thanks again,
And YES, that type of connector you showed does in fact work like I'd need it to work on a wire already in use in a circuit.
I like your way too Maniac- both would work well.
Still waiting on my Bluetooth - for phone/gps only- I like the 'music' of my bike
post #13 of 17 (permalink) Old 04-21-2017, 07:04 AM
Stupid. Who's with me?
TheGeek's Avatar
Tons of switched power available up front. Hot lead to the high beam, hot lead to the low beam, hot lead from the key to the kill switch my, horn button, power to turn signals, etc. Take your pick.
TheGeek is offline
post #14 of 17 (permalink) Old 04-21-2017, 07:08 AM
maniac1886's Avatar
I don't see a fuse on that Power wire. Don't forget to fuse it. You can get inline fuse kits from the likes of autozone etc.. This may not be wholly accurate, but it makes me feel better to put the next amperage lower fuse in the addition than the circuit you are tapping (ie. 10 am phone charger fuse on an existing 15 amp circuit) . Thay way if something happens, you are more likely to lose power to your phone and less likely, to say, lose your headlight.
My. K7 has 2 little bulbs on either side if the headlight. The are parking lights, but turn on with the bike. I tapped that wire for switch power for my phone mount. I can't tell from pictures, but I don't think your bike has these bulbs.
File Type: jpeg f1aebef8-93fd-423c-ad8b-c413804d34c2_1.6a08ed8393b763e8a5df8aa713abc489.jpeg (14.7 KB, 24 views)
post #15 of 17 (permalink) Old 04-21-2017, 03:25 PM Thread Starter
Todd_Sails's Avatar
Yep, all good advice, thanks and keep the options coming too
post #16 of 17 (permalink) Old Yesterday, 11:54 AM
Wait, you haven't done it, yet? It takes like 20-40 minutes. Just do it.
post #17 of 17 (permalink) Old Yesterday, 12:12 PM Thread Starter
Todd_Sails's Avatar
I will, I will!
I'm still waiting for the RAM mount base for the steering stem;
and my Sena Bluetooth for my helmet.
When this is here, I'll 'Get-R- Done
