Easiest way to mount an iPhone, GPS, camera on a sportbike - MOTO-D Racing - Page 3 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #41 of 67 (permalink) Old 04-19-2012, 05:14 PM
SRTchris's Avatar
Re: Easiest way to mount an iPhone, GPS, camera on a sportbike - MOTO-D Racing
Then I assume the Xshot cause is just a rubber soft bumper case. Or is hard plastic ?
SRTchris is offline
post #42 of 67 (permalink) Old 04-19-2012, 05:53 PM
Bow down bitches, I'm in the BLUE GROUP
Motorcycle: 05' 1000(track duty), 05' 600(sold), 07' 1000(daily commuter)
Pretty obvious I guess, on my my motorola photon I need to buy another case. Break the belt clip off, velcro the case and if needed tether with safety wire.
Clarencevic is offline
post #43 of 67 (permalink) Old 04-25-2012, 07:05 PM Thread Starter
Official Sponsor
MOTO-D's Avatar
Motorcycle: 2006 GSXR 750
The Xshot case is a custom hard case for the iPhone that has a tripod insert so all you need to to do is use a thumbscrew to tighten it to the base.
www.MOTODRACING.com
MOTO-D is offline
post #44 of 67 (permalink) Old 04-25-2012, 07:51 PM
Iphone case will not fit my phone though
post #45 of 67 (permalink) Old 06-13-2012, 09:12 AM
LaxBuddy21's Avatar
Motorcycle: 2012 GSXR 750 and 2012 FZ8
So I just got this mount the other day and I have mixed feelings about it. The positives are that it was easy to install and it mounts solid. I put velcro on my GPS and the mount and it holds well. Now for the negatives. I got the supramount that is supposed to hold the GPS unit but I cannot tighten it so that it does not rotate. The mount makes putting the key in annoying. The loctite tape that is on the threaded bolt came right off when I tried to screw it into the mount. The directions told me to take the nut of the stem bolt first but I ended up damaging it and not actually being able to get it off and then realized that the mount would fit over top of it anyway so I damaged my bike for nothing. Finally, I think it looks awkward on the bike when nothing is mounted to it. It would be much nicer if the mount platform could be removed easily so you didnt have this big empty thing just protruding from the bike. I am not sure whether I will keep it or not.
LaxBuddy21 is offline
post #46 of 67 (permalink) Old 06-13-2012, 12:08 PM Thread Starter
Official Sponsor
MOTO-D's Avatar
Hi Lax - I am not sure you installed this properly and the Supramount is a clamp adapter with a tripod insert specifically to work with phones.
Here is a picture of it clamping an iPhone 3 (works on any phone or device no wider than .75 inch).
I will send you an email and call to try and assist you.
The mount is very sturdy and I don't even notice it while on the track or street.
Unlike other options out there which point your phone down, our mount allows you to point the phone out for better visibility, pics, video, gps, etc.
Thanks!
MOTO-D is offline
post #47 of 67 (permalink) Old 06-14-2012, 07:21 AM
LaxBuddy21's Avatar
I read the instructions multiple times before installing. I mounted the supramount in the side hole per the instructions provided using the hardware provided. It just wont tighten enough to prevent horizontal rotation. Regardless, I have put the velcro on anyway.
post #48 of 67 (permalink) Old 07-25-2012, 12:08 AM
But what casevdo you use for your phone?
Jamilla is offline
post #49 of 67 (permalink) Old 07-25-2012, 09:31 AM Thread Starter
Official Sponsor
MOTO-D's Avatar
Place the rubber neoprene circle in between the supramount and the plate, it will now not move.
Thanks!
MOTO-D is offline
post #50 of 67 (permalink) Old 07-25-2012, 09:33 AM Thread Starter
Official Sponsor
MOTO-D's Avatar
For an iPhone 3 or 4, we have a special case that wraps the phone and has a tripod insert hole, you simply screw into it using the thumbscrews we provide.
For an Android, use the Supramount soft clamp, it holds the phone tight and has a tripod insert hole in its base, you simply screw into it using the thumbscrews we provide.
Thanks!
MOTO-D is offline
post #51 of 67 (permalink) Old 08-20-2012, 05:44 AM
I drilled and tapped my gps mount to my triple clamp, looked for something like that for ages...damn.
stonemason is offline
post #52 of 67 (permalink) Old 08-20-2012, 09:20 AM
Mr Creepy McCreep
tlee2989's Avatar
what is your alternatives for people with iphones that don't wanna use your case?
tlee2989 is offline
post #53 of 67 (permalink) Old 09-28-2012, 11:17 AM Thread Starter
Official Sponsor
MOTO-D's Avatar
Pictures of a MOTO-D camera mount on a Yamaha R1. Easiest way to mount an iPhone or Android on a motorcycle. Available from www.MOTODRACING.com
MOTO-D is offline
post #54 of 67 (permalink) Old 10-17-2012, 02:58 AM
what about vibrations? are iphone videos really watchable?
kabalza is offline
post #55 of 67 (permalink) Old 10-17-2012, 04:14 AM
Loves OG
BullAnt's Avatar
Motorcycle: 2013 GSX-R750
Good idea but looks way too bulky for my liking.
Sent from my iPad using MO Free
BullAnt is offline
post #56 of 67 (permalink) Old 11-06-2012, 04:34 PM Thread Starter
Official Sponsor
MOTO-D's Avatar
I never even notice it!
Easiest way to mount an iPhone on a sportbike motorcycle.
The GoPro has a tripod adapter which simply screws into the mount.
Contour Roam has a built in tripod insert, just screw in!
If this is to bulky for you, then you should check your riding position and get your but off the bike!
MOTO-D is offline
post #57 of 67 (permalink) Old 12-29-2012, 09:02 PM
NukleoN's Avatar
Motorcycle: 2009 GSX-R 750
Hmmm....not sure I want to give up the functionality of my front pin-stand. Also, I think you could probably design that top plate to be something other than a square. I know the square provides the most usable surface area, but maybe have an optional top plate that is a crescent shape, an ellipse or something less bulky for those who are only using maybe one item at a time?
Someone in this thread had the great idea to make that top plate removable. Doesn't look very good when nothing is mounted, and it would be very easy to make a removable top plate (then you could keep it square too since the whole thing would be removable).
I do like the very secure installation and the anodized options...but giving up my front-stand functionality...how hard is this thing to remove when one wants to use a front stand?
Check out my YouTube MotoVlog channel:
www.youtube.com/user/spacep0d
NukleoN is offline
post #58 of 67 (permalink) Old 12-29-2012, 09:09 PM Thread Starter
Official Sponsor
MOTO-D's Avatar
Quick installation 5 minutes, its rock solid when secured on, comes off just as easy.
MOTO-D is offline
post #59 of 67 (permalink) Old 12-30-2012, 01:06 AM
NukleoN's Avatar
Great to hear that, Moto-D. I guess the good thing is that I don't use a front-stand ALL that often, but having to remove the mount is a consideration holding me back from a quicker purchase.
Curious, what made you decide to go this route with the long bolt through the stem hole? Did you find other stem-hole mounts to be less-secure?
NukleoN is offline
post #60 of 67 (permalink) Old 05-19-2013, 12:01 PM
fruechte21's Avatar
Do you have a case for the iPhone 5? All I see on your website is up to the 4s.
Sent from Motorcycle.com Free App
fruechte21 is offline
