Starter relay clicks but no crank starter issues - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 23 (permalink) Old 09-25-2007, 02:56 AM Thread Starter
CityHunt3R's Avatar
Motorcycle: GSX-R750
My bike just completelyt drained the battery the other week after sitting out parked for a work shift, I jump ojn bike at end of day and bike is completely dead then... I try to jump it off a car... the bike starts when jumper cables are on but when I disconnect, the bike shuts off. I get a used relay off ebay .. I connect it.. the starter relay just clicks .. no cranking at all relay just clicks and the dash fades,.... sighs .... any help would be greatly appreciated how do I know relay is good???? ho0w do u test a starter relay???
2001 GSX-R 750
CityHunt3R is offline
post #2 of 23 (permalink) Old 09-25-2007, 04:27 AM
Re: Starter relay clicks but no crank starter issues
I can't speak from experience, but I've heard that you should not under any circumstances jump a bike from a car battery...way to many cranking amps and can kill your starter. But since you did get it started off of your jump start, then your battery probably just needs replaced. If you replace the battery and that still doesn't fix it, then it's probably your stator
Duff8402 is offline
post #3 of 23 (permalink) Old 09-25-2007, 12:58 PM Thread Starter
CityHunt3R's Avatar
The stator would cause the relay to click and no crank.?
post #4 of 23 (permalink) Old 09-25-2007, 03:21 PM
Ogri 750's Avatar
Motorcycle: 2000 GSXR 750
Get the battery connected either to a normal bike battery charger, or even better, an optimiser. Reconnect it and try again.
If the battery voltage has fallen below a certain level, the bike won't charge it.
Ogri 750 is offline
post #5 of 23 (permalink) Old 09-25-2007, 04:40 PM Thread Starter
CityHunt3R's Avatar
Im sure its not the battery just got it earlier this year. The relay just keeps clicking repeatedly... no crank.
tested battery volt meter 12V, when i leave it over a day connected it drains batttery also... wth
post #6 of 23 (permalink) Old 09-25-2007, 04:42 PM
bigBkillah's Avatar
Motorcycle: 03 yz450f street legal sumo, 02 Gsxr 600/1070, Husky Sm510r
check the fuse under your seat. if you blew that you will hear the relay but no start
bigBkillah is offline
post #7 of 23 (permalink) Old 09-25-2007, 05:16 PM Thread Starter
CityHunt3R's Avatar
you mean the 30 fuse on the relay? thats the only fuse I can see under the seat.. it s fine not burnt out...
this
post #8 of 23 (permalink) Old 09-25-2007, 07:17 PM
I whine louder than a little girl
you really need to see what voltage your battery is holding if its below 12v it going to just click, you my want to make sure your battery connections are tight and not corroded, make sure to check the ground wire connection too, if its clicking your fuses are good
adamrich33 is offline
post #9 of 23 (permalink) Old 10-01-2007, 11:30 PM Thread Starter
CityHunt3R's Avatar
batery is over 12 volts.. the fuel pump relay is now clicking after I attempt to start, the dash goes dem... then the fuel pump primes again stops.. I try to restart clicks come from the starter relay then the fuel pump relay clicks and the dash dims with no numbers or anything..... WTF I m going to try to run line directly to starter to seee if its not the starter ...will the fuel pump relay cause bike not to crank?
post #10 of 23 (permalink) Old 10-02-2007, 12:37 AM
ZR28's Avatar
Motorcycle: 2001 GSXR 1000 2006 GSXR 1000
A GOOD battery should read 12.7 volts, if it's not then it will need to be charged. A battery that is low on voltage will cause the injectors not to fire.
ZR28 is offline
post #11 of 23 (permalink) Old 10-04-2007, 10:27 PM Thread Starter
CityHunt3R's Avatar
BAD battery, volts show 12 volt charge but battery cant hold load so yeah bad battery stupid cycle gear cheap battery
post #12 of 23 (permalink) Old 10-05-2007, 11:17 PM
ScooterBoy1000's Avatar
Motorcycle: 2006 GSXR-1000
if I was to bet money, #1= Battery bad, doesnt matter how long ago u bought it. You need a fully charged battery in the bike.Your bike does not have an alternator it has a generator. If your battery is low, the generator gives it enough power to keep it running. ćurn it off and its dead
ScooterBoy1000 is offline
post #13 of 23 (permalink) Old 05-20-2010, 06:23 PM
janahi69's Avatar
Motorcycle: Streetfighter GSX-R 750
HELP NEEDED HERE!!,
Hi people, I took my bike for a long drive yesterday, i stopped at a traffic light and turned the kill switch off so i can ask for directions... as soon as the traffic lights went green, i turned the red switch on and hit the ignition .. but the bike died on me .. i'm not sure whats wrong with it but it sounds like an electrical problem which i hate! .. i have checked my fuse box all my fuses were fine, I've checked the starter relay fuse it was fine too .. anyone has an idea what could be the problem ?? I would really appreciate it .. as i only have my bike that takes me everywhere
Cheers mates
janahi69 is offline
post #14 of 23 (permalink) Old 05-21-2010, 01:10 AM
ItsaGixa's Avatar
PEOPLE PLEASE CHECK YOUR BATTERY!!!!!!
If you measure across the terminals of the battery (with the engine running) you should get 13-14 ish volts
you will have 12-13 volts at the battery (with engine off) if you only have 12 then look at the generator
keep your multimeter across the terminals of the battery and attempt to start your bike, if the voltage drops down under load then you probably have a dead cell in the battery (thanks 4 years at Century batteries) in which case the bike wont start.
exact same thing happened to me about 3 weeks ago
2003 Suzuki GSXR-600 Blue/White Color Scheme
Wiley co Racing muffler
BugMans TRE
LED's
Cooling Fan switch
Custom Switch Plate
ItsaGixa is offline
post #15 of 23 (permalink) Old 05-21-2010, 10:18 AM
Lets go racing!
Chugs's Avatar
I've jumped my bike a few times with my truck never had any issues.
Chugs is offline
post #16 of 23 (permalink) Old 05-21-2010, 07:46 PM
He Who Touches Himself
Bagherra's Avatar
yeah, i've jumped my bike using my car and have had no problems.
Bagherra is offline
post #17 of 23 (permalink) Old 05-22-2010, 12:41 AM
ItsaGixa's Avatar
I dont really see how it could cause a problem as when you connect your battery to another vehicles you are parralelling....your battery will start to be charged by the other vehicles battery (if the potential is greater)
Some people talk about spikes and surges etc...but as long as the donor vehicle is in good working order it should never be a problem
ItsaGixa is offline
post #18 of 23 (permalink) Old 06-02-2010, 09:30 PM
Motorcycle: 2002 gsxr 600
so if it drops any amount of voltage, its bad?
belizean02gsxr6 is offline
post #19 of 23 (permalink) Old 06-02-2010, 10:50 PM
ItsaGixa's Avatar
If your measuring the battery and while your trying to start the bike the battery voltage drops below 10.9V then you have a stuffed battery
ItsaGixa is offline
post #20 of 23 (permalink) Old 06-03-2010, 03:06 PM
i had it charged @ autozone and when i put it on the bike it was @ 13.13 volts, then when i started it, it dropped to 12.7... is that normal...i rode it home which was about 3 miles and with the bike off it was 13.03
