If you don't have a 96 or 97 Srad 750, or know alot about this,
Please move along, these are not the droids you're looking for.
And yes, I've read all the old posts on the 'search'.
For instance- one of the older posts mentions a 'flapper valve', removing it, plugging the vacuum line, etc.
Well my stock 97 SRAD750 has no flapper valve, NO electrical connections, etc.
It does Not have a rectangular airflow opening either.
Here is the pick of it without the air cleaner in
It is obvious to me that the sleeve looking opening prevents water from the Ram air going to the carbs,
There is a drain in the bottom of the air intake, previous owners have put electrical tape on mine?
The underside, no wires/electrical anywhere, no flapper valve
If I take out the 'sleeve' with a dremel tool, it negates the water intake prevention some, but I rarely ride in the rain anyways. The mod removes all that and opens up the intake area some.
Then people posted that the bike didn't run right after doing it.
The total surface are of that oval is MUCH smaller than the total of the intakes of the 4 x 39mm carbs.
Have you done this to a carbed Srad 750? What were your results?
TIA,
Todd
TIA,
Todd
