Cant seem to ftgure out what i did wrong - Page 2 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #21 of 24 (permalink) Old 12-09-2012, 04:48 PM Thread Starter
Re: Cant seem to ftgure out what i did wrong
Originally Posted by ccmhunt View Post
Check valve lash, make sure you don't have a valve that isn't closing. Then do leak down, see if you are losing compression past a bent valve or bad seat interface, past rings, etc. Don't tear down aimlessly without reference.
Sent from my DROID3 using Motorcycle.com App
leak down, does that mean put a lil oil in cylinder and read compression and if i get movement that tells me the rings need some attention because the oil sealed enough to hold compression
i m not sure how to check valve lash.
draccocain is offline
post #22 of 24 (permalink) Old 12-09-2012, 04:50 PM Thread Starter
after putting oil in the compression gauge jumps then falls back down to 0 with each turn
post #23 of 24 (permalink) Old 12-10-2012, 06:27 AM
ccmhunt's Avatar
Again, buy or borrow a leak down test device. It allows you to set a constant air pressure to your cylinder. Connect to air source and to spark plug hole. Set that cylinder to TDC, and lock crank from turning. Take off carbs and pipe. Put in 100 psi, Listen for signs of air escaping in intake or exhaust.
ccmhunt is offline
post #24 of 24 (permalink) Old 12-10-2012, 09:53 AM Thread Starter
ok i ll try to get ahold of one thanx
