How a choke in a carburettor works....explanation! - Page 2 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #21 of 24 (permalink) Old 11-12-2012, 09:13 PM
ccmhunt's Avatar
Re: How a choke in a carburettor works....explanation!
Originally Posted by TwistedMister View Post
is that the perforated needle set up?
like to get me a good set of spares and try those some day, prolly when I hit the lotto..
I wonder who might have a set for you, maybe Walmart?
he said, it adds more air, he also said that in another thread a while back when I was going through my carbs when I thought fuel may be leaking out the choke o-rings..
he said "remember the choke adds more air"
I fear you blonds aren't going to do so well on the test...
You are, I suspect, referring to me, with the" he"?
ccmhunt is offline
post #22 of 24 (permalink) Old 11-13-2012, 01:57 AM
TwistedMister's Avatar
lol, yea I know I know, its a matter of budget, after the bike is completely done at that point I can think about spares.. I still have a set of marchesinis I want to repair and fit, finding parts for those is almost impossible, prolly have to find someone to make the inner bearing spacer for the rear and if the outer spacers aren't right I'll need to source those as well.
pretty sure it was you who mentioned the choke introducing more air...
TwistedMister is offline
post #23 of 24 (permalink) Old 11-14-2012, 06:12 AM
Ass Packer
TeflonTrout's Avatar
Motorcycle: '99 GSX-R750-SOLD for '13 Kawasaki KLR-650
LESS air. It's a valve (butterfly valves, like one the ones that open and close on giant superchargers mounted on drag race cars) that leaks when it's closed; on most carbs, either there is a valve that only controls the amount of fuel/air mix, but doesn't close all the way unless the choke is activated, or there is a completely separate choke valve that is closed when the choke is applied.
The airflow is significantly reduced, and like putting your...hand...over the end of a vacuum cleaner hose, any other openings that are present (like leaks in a vacuum cleaner hose) increase their flow to help offset the low pressure. Inside a carb, this usually includes the fuel atomizer (where the venturi is- a venturi sounds much more technical than it is; it's basically just a part of the air passage which has been narrowed in a mathematically designed way). More suction results from the lower volume of air being allowed into the motor, which draws more fuel out of the atomizer.
The other stuff, such as the idle speed adjustors, are secondary mechanisms that are turned on at the same time as the choke to make it more effective/prevent stalling. They are not the same mechanisms, but linked. It's a similar setup to acceleration pumps: on large car carburators, when you stomp the throttle there is a little piston that also jumps; it blasts a bunch of fuel into the carb to cover the slack as the normal jets are still adjusting to the instant change in fuel demand caused by you opening the butterfly valves in a hurry. Secondary fuel jets are often used to help with the choke, too. They work in concert with the throttle, but are not actually the throttle. The idle adjustors and secondary jets work in concert with the choke if they are designed to, but are not actually the choke.
Best high school class ever: Small engine repair
EDIT: More about venturis- imagine the top of an airplane wing. The low pressure area at the top of the wing is responsible for a lot of the lift, drawing the wing up into the low pressure area. A venturi is basically the same idea, but in a circle with the wing wrapped up like a ring with the top facing in. In the middle of the circle of low pressure is the fuel jet/atomizer- instead of drawing a wing up to provide lift, it draws gas out to provide fuel.
Welp, about to piss on over to the KLR adventure forum due to a change of steed. When I can afford a good GSX-R, I'll be back- I don't have time for fixing rat bikes anymore.
Last edited by TeflonTrout; 11-14-2012 at 06:17 AM. Reason: Added simplification of a venturi
TeflonTrout is offline
post #24 of 24 (permalink) Old 11-14-2012, 07:43 AM
ccmhunt's Avatar
Uhmmmmm, the question, I had originally posted, was how does it operate in OUR Carbs, And I gave the clues. I think you missed most of it in the other thread.
ccmhunt is offline
