New gen gauge swap info/instructions - Page 20 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #381 of 467 (permalink) Old 03-20-2012, 08:34 PM
Re: New gen gauge swap info/instructions
not resistors you need to swap the signal.. one could use a micro chip that is basically a bunch of not gates i think.. been a while since i thought of it. look in the posts i was playing with a relay to do it then thought a mc would be better
TT750 is offline
post #382 of 467 (permalink) Old 04-24-2012, 05:41 PM
Ebo
Motorcycle: Gsxr srad 600 1997
Yeah tried resistors didnt work lol apart from that its wired up in kph which is a bit gutting like as i cant get it to change to mph.
Any help for the fuel light would be appreciated as i dont fancy getting lungfull evertime i check the remaining fuel.
Ebo is offline
post #383 of 467 (permalink) Old 04-25-2012, 09:59 AM
the signal has to be swapped for the fuel light to work... easiest way to explain is the micro controler in the clocks looks for signal from upper and lower sensors. Its no voltage or 12v. so you need to swap the signal from the sensors to the clocks. when the clocks is expecting to see 12v your sensors are actually supplying no signal. you could use a microcontroler that is a simple chip with gates in it.
To swap from kph to mph you need to hold the 2 selection buttons on the clocks i think. they will swap between.
99 750 srad.... my other hot blooded woman
TT750 is offline
post #384 of 467 (permalink) Old 05-27-2012, 08:01 AM
Ebo
Ive asked about but am for the moment at a loss everyone local just look vacantly and scratch theyre heads.. I have ran outta fuel once but i was at my mates house thankfully
My clocks seem to be off a kph model as i cant get them to change arghhh
What other gauges will fit? Like the thought of a uk speck with gear indicator etc
Cheers ebo
Ebo is offline
post #385 of 467 (permalink) Old 05-27-2012, 12:02 PM
To get into mph you hold the 2 buttons in or something . the clocks i have are off a us bike i had to swap the other way.
TT750 is offline
post #386 of 467 (permalink) Old 05-30-2012, 01:51 PM
Ebo
Ive pressed and poked man gonna take a run out to the suzuki shop n see if they can set it for me
Ebo is offline
post #387 of 467 (permalink) Old 06-25-2012, 05:40 PM
Ebo
Won a k7 dash on ebay new mission trying to get the gear and shift light working also hopefully theyre in mph
Ive found a few posts on how to wire up aftermarket shift and gear indicator.
Searching for a k7 dash wireing diagram atm anyone else done or seen one done? Lol
Ebo is offline
post #388 of 467 (permalink) Old 06-27-2012, 08:09 AM
lol cool!!!! hahaha thas not my middle finger by the way.
ashleyecaf is offline
post #389 of 467 (permalink) Old 12-08-2012, 08:55 AM
biff10's Avatar
Any updates on a kit for this swap??????
biff10 is offline
post #390 of 467 (permalink) Old 12-14-2012, 09:41 AM
biff10's Avatar
I got mine in and the speed is way off. any fix for that??? I still have a fuel light on and the check is on. Is anyone working on these problems????
biff10 is offline
post #391 of 467 (permalink) Old 12-28-2012, 09:11 AM
Ebo
Na guess your on yer loansome man i never got temp fuel or check off on the k1 clocks. And nor did i ever get a wireing diagram gonna start investagateing it k7 swap again soon
Ebo is offline
post #392 of 467 (permalink) Old 12-28-2012, 09:40 AM
froudy's Avatar
Motorcycle: Bandit 1200 and GSX1400
Fit a Speedo Healer to calibrate the clocks.
http://www.healtech-electronics.com/
froudy is offline
post #393 of 467 (permalink) Old 08-06-2013, 12:34 PM
This is one of my first posts, I usually get info from all of the specialist in this forum but never have something to offer.
So here I go, what I’m shearing is not my knowledge that I’m offering but this is a very interesting thread but it seems like a long battle lost.
Check this on our causing site:
http://www.tlplanet.com/forums/showt...t=88709&page=7
For what I understand this Joe solves the issue, at least for the Fi units. It also make a k5 gauge work!!! And if I’m not mistaken already tested in a Fi Gixxer.
Hope this revives the battle and we can finally win this!
Luky0707 is offline
post #394 of 467 (permalink) Old 09-24-2013, 06:46 PM
Nero606's Avatar
Motorcycle: Suzuki GSX-R 750 SRAD 1996.
My apologies for OT, but does anyone have stock gauges for SRAD 750 96' and is willing to sell and ship them to Croatia (Europe).
My gauges are destroyed and I need Tachometer at least
Is there a way to connect tachometer directly to the ECU or ignition coil?
Circuit board is fried but tachometer looks fine. It has four pins (sign on circuit board is cos+ , cos- and sin+,sin-), all other tachometers I have seen have only three wires (+,- and signal from ignition coil).
Sorry for my bad english.
Nero606 is offline
post #395 of 467 (permalink) Old 10-17-2013, 12:28 AM
Can someone help me out with teh fuel level lights? I can run relays, but I'd rather have something that consumes less power won't be affected by a harsh ride (bumps)... I've got no fear of a soldering iron, but I am not an EE -- tell me which parts to buy/how to connect, and I can follow the schematics/instructions... I figure I could use a few transistors to get this done, but no clue which ones.
justdave is offline
post #396 of 467 (permalink) Old 10-21-2013, 06:50 PM
to sort the Fuel Light issue, you need "pull-up" resistors for each of the fuel wires. iirc the Y-k1 clocks had 2 fuel sender wires (A and B) and the k2-k3 had a single fuel sender wire. so depending on your clocks will depend if you need to wire a pull up resistor for fuel A and one for fuel B sender or just for the one wire that will be use.
**the Y-K1 bikes used a FLLR (fuel level light resistor) which was the pull up resistors for the 2 fuel sender wires. But you could make your own pull up from a resistor on each circuit connected to 12v (will need to check what the ohms is)
i'm in the mids of programming an arduino to sort out the Temp/Error light issue due to clock not receiving the data information from the ECU. The bench test is working so far and i'm waiting for a few bits to start making up to attach to the bike. so i can do a direct plug in to my clock harness so i dont have to re-pin my harness plug.
The FLLR from a Y model
using some open coding from some peeps over on an SV forum, someone wrote a code to send the clock a temp number manually programmed into the arduino coding
someone did some coding for there SV project and i added the coding needing for the GSXR clocks and also allow it to getting a reading from an analog input on the arduino board which in turn was connected to the thermistor
blagger is offline
post #397 of 467 (permalink) Old 10-21-2013, 06:53 PM
its not totally spot on with the reading but that could be due to my multimeter temp sensor being more sensitive but as long as its in the right ball park
also
got a mini arduino board to put the program on and to wire into the bike
blagger is offline
post #398 of 467 (permalink) Old 10-22-2013, 12:31 AM
After talking with a local gsxr rider, I got a teensy board, and some code and wired it into a 2001 750 gauge. the one thing I didn't sort out is the fuel level issue. Some posts say to use a set of relays to fix the fuel light; other posts say I need a resistor. What is needed to put a 2001 gauge in a 98?
justdave is offline
post #399 of 467 (permalink) Old 10-22-2013, 12:40 PM
Y-K1 600/750 used an external FLLR (resistors) so you need 2x 70 ohms resistors iirc from the book, both coming from a 12v + feed and then one goes to the fuel A wire and the other goes to the fuel B wire and they pull up the signal high.
i'm not to sure about the k2-3 600/750 as they never had the external FLLR so i dunno if there was something in the clock and also they only had the one fuel sensor wire
blagger is offline
post #400 of 467 (permalink) Old 10-22-2013, 06:05 PM
like to add that my working is based for the carbie version of the srads and having to program the arduino to emulate the later model ECU to send out the temp to the dash
blagger is offline
