GSXR 750 2001 into GSXR 750 1996 engine swap - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 4 (permalink) Old 04-12-2010, 05:11 PM Thread Starter
Hello, I'm a owner of Suzuki GSXR 750 year 1996 and my engine has allready died. It is realy hard to buy a GSXR engine in my country and i got a chance to buy engine from GSXR 750 year 2001.
Can you help me and tell me what need to be changed? I do not want to use fuel injection because is too much expensive. I want to use my carburettors.
DriverMaster is offline
post #2 of 4 (permalink) Old 04-12-2010, 05:39 PM
Superbike
GSXR-Freak's Avatar
Motorcycle: 99 GSXR 750
Re: GSXR 750 2001 into GSXR 750 1996 engine swap
Your carbs will not fit on the new head without some major fab work. Your better off finding a FI setup with the motor.
John
GSXR-Freak is offline
post #3 of 4 (permalink) Old 04-12-2010, 06:21 PM
spdfrk9986's Avatar
I agree with GSXR Freak. If you are going to go thru the hastle to make that motor fit, you might as well make it FI. I did one a few years back, get a complete harness, guages, and fi system and airbox. Use a 98-99 FI fuel pump
spdfrk9986 is offline
post #4 of 4 (permalink) Old 04-12-2010, 06:54 PM
Superbike
GSXR-Freak's Avatar
The problem with keeping the carbs is that the intake spacing does not match up. You would have to fab up some intake manifolds to change the spacing from the 01 head so it would match the spacing of the 96 carbs.
Even if you got that to work, you would still have problems with the crank sensor not matching the ECU of the 96... So many things that you would have to make work, it would cost a LOT more in the long run.
Find a crashed 01 and rape it for what you need.
John
