750 Engine rebuild? - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 10 (permalink) Old 01-02-2004, 04:02 PM Thread Starter
750 Engine rebuild?
How many Km's / miles untill a engine rebuild should be considered on a 97 750?
6sik6 is offline
post #2 of 10 (permalink) Old 01-02-2004, 04:11 PM
Motorcycle: 97 gsxr 750
Re: 750 Engine rebuild?
I've heard of one guy getting 50k miles on the clock before selling his bike and another guy got 99,999 km then his speedo stopped working. So if your bike has been maintained and in good running shape then it should go for a while.
gixxerman
gixxerman is offline
post #3 of 10 (permalink) Old 01-02-2004, 05:07 PM
Motorcycle: 04 1000
Dont fix it, until it breaks!
D
Riden420 is offline
post #4 of 10 (permalink) Old 01-02-2004, 05:19 PM Thread Starter
im just curious, cause ther are a couple that i was looking at.
there's a 97 with 35000 kms and a 96 with 48000kms thats been jetted. other than that they are both stock. they want $5000 CAD. for each, but im not sure if it would be a good idea to get one with such high kms.
6sik6 is offline
post #5 of 10 (permalink) Old 01-03-2004, 06:31 AM
Superbike
GSXR-Freak's Avatar
Motorcycle: 99 GSXR 750
I rebuilt mine the first time at 35K miles.
It really comes down to how much compression the motor has.
John
GSXR-Freak is offline
post #6 of 10 (permalink) Old 01-03-2004, 11:54 AM Thread Starter
did you do a compression test before you did it or could you feel the lag in the motor?
6sik6 is offline
post #7 of 10 (permalink) Old 01-03-2004, 11:56 AM
Superbike
GSXR-Freak's Avatar
I could tell when running with a 99 750 that had only 2K miles on it. They would pull me in the bottom and mid range, so i did a set and I was at like 118 - 121psi, min spec is like 135psi. So I rebuilt it.. It was a lot better after that.
John
post #8 of 10 (permalink) Old 01-03-2004, 02:11 PM Thread Starter
thanks for the info is there anything in particular
that you would suggest to look at before buying a bike
with those types of kms on it? im pretty sure i wont be able to ride it.
6sik6 is offline
post #9 of 10 (permalink) Old 01-03-2004, 02:15 PM
Superbike
GSXR-Freak's Avatar
well I would check to make sure it doesnt blow smoke when it runs. And that there is not a lot of play in the head bearings or swingarm bearings. That is doesnt make a lot of noise. and that over all it looks in good shape. Chain and sprockets are ok, and tires are not trashed.
John
post #10 of 10 (permalink) Old 01-03-2004, 04:36 PM Thread Starter
thanks, all that will be kept in mind when i go to check em out
thanks for the help!
6sik6 is offline
