93 gsxr 750 no spark help please - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 13 (permalink) Old 05-16-2017, 10:30 AM Thread Starter
Hello everyone My Name is Joe I'm happy to be apart of this site I have been going threw some forums to try and get a grasp of what's wrong with my bike so I decided to create my own seeing that o notice slot of help on here and very educated people, also very generous people well here it goes, so I have a 93 suzuki gsx-r 750 that won't spark and the start button wont work I have tested all the safety switch cluch, side stand, cut off switch start button, I found th side stand switch did not read anything while testing it *using pocket meter* so I spliced them together Hoping thay solved the problem it didn't. I checked and replaced my ignition relay still nothing I replaced light and ignition fuse still nothing, I bought new coils still nothing so I tested the wires to the coils and I have no juice to them I can get the bike to turn over but it won't fire(no spark=no ignition=not running) so can please some one help me out of a jam I'm lost
Gsxr750r93 is offline
post #2 of 13 (permalink) Old 05-16-2017, 12:24 PM
Calamari
knowyourenemy66's Avatar
Motorcycle: 1995 GSXR 750
Re: 93 gsxr 750 no spark help please
Check your ignition switch. It will cause all kinds of headaches. I was having headlight/taillight issues. After testing switches, checking ground points, checking fuses, checking bulbs, checking wires, etc... Bike would crank and run fine. Lights were not working correctly. Finally figured out it was the ignition switch. Replaced switch, problem solved. Welcome!
knowyourenemy66 is offline
post #3 of 13 (permalink) Old 05-16-2017, 12:28 PM Thread Starter
Thank for writing me all my lights work when my ignition switch is on but I will take a peek at it
post #4 of 13 (permalink) Old 05-16-2017, 12:38 PM
On The Outside Looking In
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
Check your posting...it's posted in the wrong years forums.
You'll always find more answers among the crowd who actually owns them.
Anyone...anyone...SAM...anyone???
THE SRADIATOR is offline
post #5 of 13 (permalink) Old 05-16-2017, 12:43 PM Thread Starter
Sorry the forum does not have a year it just says gsxr 600 /750
post #6 of 13 (permalink) Old 05-16-2017, 01:07 PM
Or does it?:
Water Cooled Gixxers (11 Viewing)
Covering liquid cooled GSX-R models up to 1995
post #7 of 13 (permalink) Old 05-17-2017, 07:28 AM Thread Starter
That's not what I see it just says gsxr 600/ gsxr 750 general forum
post #8 of 13 (permalink) Old 05-17-2017, 07:32 AM Thread Starter
Hey bud thanks for helping it was actually the start button it was getting no power source it was blank so I tapped into how it should get power after doing so button work and also gave me spark now I notice when bike was running I have liquid thay appears to be an oil it look like it's coming from around the gear shifter idk if it's directly from the gear shifter or around there
post #9 of 13 (permalink) Old 05-17-2017, 07:35 AM Thread Starter
I honestly have to say I really did not know if this bike would run considering I only bought it for $500 I guess I made a pretty good even if it does need a little bit of work on it
post #10 of 13 (permalink) Old 05-17-2017, 07:36 AM Thread Starter
Thats what im under
File Type: jpg Screenshot_20170517-083545_1495024567483.jpg (12.1 KB, 3 views)
post #11 of 13 (permalink) Old 05-17-2017, 07:38 AM Thread Starter
Or does it?:
ok thanks for the heads up but that's not what it tells me
post #12 of 13 (permalink) Old 05-17-2017, 10:58 AM
Calamari
Post some pics so we can get a better idea. It may be the seal around the shifter shaft. Btw, when you post about your bike, hover over the "forums" tab. As you are hovering, drop down to the "Gixxer" tab. As you are hovering over the "Gixxer" tab, move right and down 4 places to "Water Cooled Gixxers". That will put you in the correct forum.
post #13 of 13 (permalink) Old 05-17-2017, 08:20 PM Thread Starter
so I found where they the leak is ... I believe it's gear oil because it's really coming out of the sprocket well behind it so what do you guys/lady's think it is (maybe a seal I hope) and is it pricey to fix
