oil level question - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 9 (permalink) Old 05-27-2011, 01:59 PM Thread Starter
Obed's Avatar
Motorcycle: 1992 GSX-R 600
oil level question
92 GSXR600W
Is there any reason that the oil level displayed in the window would not be accurate? Seems like a silly question, but I had to ask.
Not leaking externally, not leaking internally as far as I can tell (checked coolant), not blowing blue or white smoke (when off choke). Oil level was in the glass on its kickstand and when bike was upright. I changed the filter and drained the oil (looked good). Added 3.5 quarts 10w-40 as per manual (stamped 3000ml on case), ran for about 5 minutes. Checked oil after an hour sitting and not in glass, waited overnight, same thing. Added 0.25 quarts, waited, still not in the glass. Took it for a 10 mile spin and it never got hot or bogged or anything. Afraid to run it more; afraid to add more oil. My gut says that no matter what, the glass does not lie and to fill until I see it, but I wanted to confirm that line of thinking.
What am I missing?????
Thanks a bunch
Obed is offline
post #2 of 9 (permalink) Old 05-27-2011, 02:21 PM
Fortunae Nihil
RoamingBison's Avatar
Motorcycle: 1994 GSXR-1100W(R)
Re: oil level question
You are checking the level in the sight glass with the bike upright (balanced) and not on the side-stand (I trust)?
RoamingBison is offline
post #3 of 9 (permalink) Old 05-27-2011, 02:27 PM
Whitenoize's Avatar
Motorcycle: 1993 GSX-R1100W
The manual says to check it after the engine has warmed up ( balanced too ). EDIT
Whitenoize is offline
post #4 of 9 (permalink) Old 05-27-2011, 02:40 PM
Fortunae Nihil
Originally Posted by Whitenoize View Post
The manual says to check it after the engine has warmed up. I don`t doubt that checking cold it wouldn`t be visible.
I'm not sure I follow? Indeed, checking the oil level cold or warm (with the engine off, bike upright and level), it is quite visible (at least it is on mine).
post #5 of 9 (permalink) Old 05-27-2011, 02:46 PM
anthonyrr's Avatar
Motorcycle: 1993 gsxr 750
Definitely visible in the sight glass, hot or cold with the bike balanced.
I would add oil until I could see it. It shouldn't take much more from what you already have put in.
anthonyrr is offline
post #6 of 9 (permalink) Old 05-27-2011, 02:52 PM
Fortunae Nihil
I'll add that 'clean' oil is sometimes harder to see in the window. I've caught myself trying to add when it was already topped up!
post #7 of 9 (permalink) Old 05-27-2011, 10:43 PM Thread Starter
Obed's Avatar
Thanks guys. I appreciate the input and help.
The bike is upright and balanced, and I have checked both warm and cold.
I'll add a little bit at a time until I see it in the window.
Thanks again
Obed is offline
post #8 of 9 (permalink) Old 05-28-2011, 08:20 PM
wombat58's Avatar
Motorcycle: GSXR1100 WS
You may have overfilled the engine, so before you add more oil have a mate lean the bike away from you while you look in the sight glass. As RB said, new clean oil can be difficult to see until the level drops into view.
wombat58 is offline
post #9 of 9 (permalink) Old 05-29-2011, 01:10 AM
dbenney's Avatar
Motorcycle: k5 1000
something else to remember.... whenever you change the oil and filter you are installing a dry filter. when u start it up the first time the the filter will fill with oil. granteed these filters are small but when u only use about 3.5 qts of oil it doesnt take much for it to be low. I say have buddy lean it over to make sure its not full... if it checks out ok add away. never add by an amount, you can never get all the oil out of the system. jsut add oil while watching window and add til its full. jusst the way i do it and its never led me wrong.
Double bubble smoked screen, Goodridge braided SS front and rear brake lines, Galfer rear wave rotor, Galfer HH sintered rear pads, Yoshi slip on, Yoshi frame sliders and swingarm spools, exhaust servo removed, pair removed, PCIII, SpeedoDRD, OSF adjustable rearsets. GPR V1 damper
dbenney is offline
