96 gsxr 1100,Need fuel line diagram - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 9 (permalink) Old 04-15-2010, 01:49 PM Thread Starter
I bought this thing and need the correct line diagrams for the fuel lines.I had it running but i dont think there correct as bought.Thanks
kylewr84 is offline
post #2 of 9 (permalink) Old 04-15-2010, 02:00 PM
Sabba's Avatar
Re: 96 gsxr 1100,Need fuel line diagram
What exactly do you need?
There are 2 fuel lines running from the two outer tubes of the petcock to 2 carb t-connectors. It doesn't matter which way you hook them up to the petcock...
One line feeds carbs #1/#2, the other feeds #3/#4
Sabba is offline
post #3 of 9 (permalink) Old 04-15-2010, 02:05 PM Thread Starter
My bro was working on it and saw the two upper plastic/rubber connectors and questioned if they were to be connected also.
kylewr84 is offline
post #4 of 9 (permalink) Old 04-15-2010, 02:10 PM
Sabba's Avatar
Can you take some pics of what you're refering to?
You may be refering to the vent tubes...
Sabba is offline
post #5 of 9 (permalink) Old 04-15-2010, 02:14 PM Thread Starter
can at my home right now.They are on top of carbs unlike the other two which are located on the bottom of the carbs.I was pretty sure they didnt need hooked up on the top.I know it runs like crap and stuff but i think its in need of a carb sync bad
kylewr84 is offline
post #6 of 9 (permalink) Old 04-15-2010, 02:14 PM
Sabba's Avatar
Read through this thread...further down (post #4) it explains what all the lines are for (the labels in the picture are NOT correct)...
Carb Help
Sabba is offline
post #7 of 9 (permalink) Old 04-15-2010, 02:24 PM Thread Starter
THANKS AGAIN,seems i just need to tune carbs now.
kylewr84 is offline
post #8 of 9 (permalink) Old 04-15-2010, 02:26 PM
Fortunae Nihil
RoamingBison's Avatar
Motorcycle: 1994 GSXR-1100W(R)
The float overflow lines and breathers for the diaphragms are being confused with the fuel lines. Go to the online diagrams at bikebandit.com or ronayers.com and look up your model year to figure out whihc one is which.
RoamingBison is offline
post #9 of 9 (permalink) Old 04-16-2010, 12:06 AM
fireforeffect49's Avatar
Motorcycle: '98 GSX-R1117, '92 FXSTC
Upper ones are vents, ignore them. Fuel inlet spigots are on the bottoms between #1/#2 and #3/#4 just like Sabba said.
fireforeffect49 is offline
