88 GSRX750 CDI Help - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 3 (permalink) Old 06-19-2017, 12:59 PM Thread Starter
Question 88 GSRX750 CDI Help
Can anyone help with my CDI dilemma?
The bike has a very poor spark and seems to have a strange CDI (Igniter) box. See pics.
Does anyone recognize this? Looks almost homemade! The connectors also don't line up and 'lock' with the loom plugs, so clearly not an original part.
I'd like to put the ignition back to standard and I am now looking for a standard ECU. I believe the part number is 32900-17D00 for a 1989 Slingshot 750? Just wondering whether anything else may have been changed when this 'odd' igniter was fitted?
Thanks
Reposted here, as I think it's the correct place.
asw200 is offline
post #2 of 3 (permalink) Old 06-19-2017, 08:26 PM
Re: 88 GSRX750 CDI Help
The picture below is from my 1989 GSXR 750. Sent you a PM.
Bparrishlvx is offline
post #3 of 3 (permalink) Old 06-19-2017, 11:05 PM
Gixxerider86's Avatar
very interesting, Id try to eliminate any other factors before assuming its the CDI. get good plugs, make sure ALL contact points and connections are clean, trim the spark plug wires where it plugs into the coils and where the plug boots screw onto it
Gixxerider86 is offline
