Advice on stripped valve cover bolts - Suzuki GSX-R Motorcycle Forums Gixxer.com
 2Likes
  • 1 Post By Geesxara
  • 1 Post By nickr
post #1 of 16 (permalink) Old 04-21-2017, 01:05 AM Thread Starter
ANDRASTA's Avatar
Motorcycle: 1990 GSXR 1100
So a couple of my valve cover bolt threads are stripped.
I have a couple of options and was wondering what is best from experience.
I know APE makes some 8mm oversized bolts. Would I have to tap the holes first?
Also another option is to find a 7mm coil kit and do that.
Do I need to tap the holes for the oversized 8mm bolts?
What are the best options? Any advice is appreciated.
Thanks.
Sent from my SM-N900W8 using Tapatalk
ANDRASTA is offline
post #2 of 16 (permalink) Old 04-21-2017, 02:06 AM
Geesxara's Avatar
Motorcycle: 06 GSXR1000
Re: Advice on stripped valve cover bolts
7mm helicoil kit is your best option, you'll always be able to use stock VC bolts and wont have to figure out which ones go where.
The helicoil needs to be installed using red Loctite. It will make for a stronger thread that wont wear out like an aluminum hole after repeated use.
Plus tapping aluminum with a hand tap really makes for shitty threads due to galling and sideloading the tap by hand.
Keep in mind, if there's a dowel pin in any of those holes, you need to make sure that dowel pin will go in flush like original.
Those bolt holes are often stripped because the rubber washers and gasket got too thin, bolt bottomed out and got over tightened.
wicked86gsxr likes this.
Geesxara is offline
post #3 of 16 (permalink) Old 04-21-2017, 02:18 AM
On The Outside Looking In
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
That whole design was not a c-hair better than it had to be!
If cam cap threads weren't stripping out then the valve cover where the bolts got thru was popping/cracking.
No room for error there, I tell you.
With paper thin tolerances and soft materials, it's recipe for disaster in anything less than finesse-ful hands.
THE SRADIATOR is offline
post #4 of 16 (permalink) Old 04-21-2017, 07:57 AM
nickr's Avatar
Motorcycle: GSXR1100N, VFR750FK and GS650GT. Sold GSXR1000K6 to buy the 1100
I had a thread strip on the cam cap/cam cover retainer - I'm always very careful not to over torque the bolts too, as SRAD'R says, they're not over engineered !
As suggested above, I had a guy put a helicoil in, I let a pro (does thread repairs for a living)do it as I didn't want to chance ruining the cam cap (I would've managed it ok I think - but ...) - he did a great job, it's stronger than standard now - gave him some cash and it didn't cost much. I believe some people helicoil all of the c.cover mount threads if they've got a keeper.
nickr is online now
post #5 of 16 (permalink) Old 04-21-2017, 06:25 PM Thread Starter
ANDRASTA's Avatar
Thanks guys,
I think I should mention that I would have to be doing this repair while the head is on the bike so, am I able to tap the hole by hand or what would I need exactly??
Thanks.
ANDRASTA is offline
post #6 of 16 (permalink) Old 04-21-2017, 06:42 PM
johnnyGixxer711's Avatar
Motorcycle: 91 gsxr 711
You do not need to remove the head to repair the threads, You should remove the cam caps one at a time,drill and tap for helicoil.You don't want the shavings in the engine
I had all of mine done on a drill press so I knew the threads were all straight.This is not a very difficult repair
johnnyGixxer711 is offline
post #7 of 16 (permalink) Old 04-21-2017, 09:13 PM Thread Starter
ANDRASTA's Avatar
Thanks
I guess i am just worried about keeping everything straight while working on it. Dont want to go in crooked.
ANDRASTA is offline
post #8 of 16 (permalink) Old 04-21-2017, 09:36 PM
IMMITIGABLY VERBOSE DUDE
crispone's Avatar
http://ape-store.com/shopsite/page55.html
Get THESE!!! (APE is making a run of both the standard 7mm and 8mm oversize cam cover bolts.)
These are MUST HAVE even for stock builds in my opinion!
(PS: I see in retrospect you are aware of these already... as mentioned above, whether helicoil or drill/O.S. thread, if you are careful, you can do it in-frame as described above. The O.S. do seem to take a "good torque" and I've not had valve cover leak since using them... MUCH better than the stock hex/goofy-washer setup. We carefully placed a hole through shop towels and covered everything before doing any work, then shopvac'd the shavings thoroughly to remove any shavings. Using oil keeps stuff from "flying around", too... Good luck!)
-crisp
crispone is offline
post #9 of 16 (permalink) Old 04-22-2017, 11:02 AM
At the risk of PO some of my learn-ed colleagues, I'd stay away from those aluminum valve cover bolts. They twist off at about 10 ft lbs or so, many times before you can get them to seal.
Try these - Stainless Steel Single Suzuki Top Rocker Cover Bolt
darkirish58 is offline
post #10 of 16 (permalink) Old 04-22-2017, 03:16 PM Thread Starter
ANDRASTA's Avatar
Thanks man, did you still have to retap the hole? Are those bolts the same thread etc like the original?
ANDRASTA is offline
post #11 of 16 (permalink) Old 04-22-2017, 05:40 PM
crispone's Avatar
Good to know. I have not had issue with the aluminum ones and pleased with function and appearance, however, I did not know about these stainless units. Nice to see good options!
-crisp
crispone is offline
post #12 of 16 (permalink) Old 04-22-2017, 05:58 PM
nickr's Avatar
I fitted special m7 s/s bolts on mine too, I thought abought the Al ones, went with the s/s ones (even though I really like the idea of light weight bolts)- thought there would be 2 possible places to have stripped threads with Al bolts when clearances checked once a year. I think my repair was bored to 7.5mm and then tapped to m8, the helicoil was then fitted for an m7 thread - the cover bolt now has s/s threads and is smoother in action than the 7 others.
qnspider likes this.
nickr is online now
post #13 of 16 (permalink) Old 04-23-2017, 10:10 PM
They are the same thread. I didn't booger the cam cap threads so no tapping or helicoils for me. I only twisted off the Al bolts ... about half until I replaced them with SS
post #14 of 16 (permalink) Old 04-24-2017, 10:21 PM Thread Starter
ANDRASTA's Avatar
Thanks for the replies guys,
I guess my main worry is not tapping the bolt straight.
ANDRASTA is offline
post #15 of 16 (permalink) Old Yesterday, 01:42 AM
Wink Re: Advice on stripped valve cover bolts
I'm with most of the rest drill tap and Heli-coil, and don't use and aluminum bolt, engineers are not perfect but I am sure using a grade 5 stainless bolt is more than adequate now as you are fearing going in straight what i have done working on many things is you can use a carpenters square to use to give you a good reference I have a folding one that I made that is sometime just as useful for getting the perfect angle of reference you've got this... Just be creative in making sure your straight and most importantly take your time
qnspider is offline
post #16 of 16 (permalink) Old Yesterday, 01:52 AM
one more thought if you are concerned with metal shavings from drilling or taping you can use some grease or oil as you drill/tap and the shavings will stick with the bit or tap you are using and not spread as much... but if you do this make sure you clean out the threads with break parts cleaner before setting the heli-coil and also when you are all finished if you are going to set your torque on the bolts to the proper inch lbs... oil/grease contamination can play hell on the accuracy of your torque... BTW I prefer grease when i see the shavings in it i stop wipe it off reapply and continue my work helps tremendously for not getting metal shavings where you don't want them
qnspider is offline
